08-11-2009, 09:00 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Pilipinas Kong Mahal !
Member: 440356 Status: Offline Thanks Meter: 42 | m620 flashing error... need help... pls give some idea mates 1st Boot Ok, McuId: 00030021, Rom: 00030021, 13-1.2 (Vision X122A) 2nd Boot Ok, McuId: 00030021, Rom: 00030021, 7-2.0 Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_v24_s05_2.sre Flash1: Fl_Id: 00010000_227E3D00 - Spansion SxxWS512P Baud Rate Set: 460800 bps Flashing NOR part... ErClos: rplyCLOS-erreom. Bad response: 0x002C, 6572 ErClos: rplyCLOS-erreom. Bad response: 0x002C, 6572 Write Failed at: 0x21704000 i tried different versions but its always stock there... |
The Following User Says Thank You to hazard23 For This Useful Post: |
08-11-2009, 23:18 | #3 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Algeria
Member: 56090 Status: Offline Thanks Meter: 162 | same problem with M620 that i can flash only CTS but can't flash MCU (error like above messages) and pc can detect phone with usb cable by pressing * and PWR... anu suggestion is the flash ic Spansion SxxWS512P faulty Salam |
The Following 2 Users Say Thank You to abdoune For This Useful Post: |
08-11-2009, 23:27 | #4 (permalink) |
Member: 56090 Status: Offline Thanks Meter: 162 | I can erase NOr but can't flash Muc file see log: 1st Boot Ok, McuId: 00030021, Rom: 00030021, 13-1.2 (Vision X122A) 2nd Boot Ok, McuId: 00030021, Rom: 00030021, 7-2.0 Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_v24_s05_2.sre Flash1: Fl_Id: 00010000_227E3D00 - Spansion SxxWS512P Baud Rate Set: 460800 bps Erase Done: 0x20000000-0x23FDFFFF, 514 sector(s), Time: 00:45 NOR Erase Complete, Time: 01:59 ------------------- 1st Boot Ok, McuId: 00030021, Rom: 00030021, 13-1.2 (Vision X122A) 2nd Boot Ok, McuId: 00030021, Rom: 00030021, 7-2.0 Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_v24_s05_2.sre Flash1: Fl_Id: 00010000_227E3D00 - Spansion SxxWS512P Baud Rate Set: 460800 bps Flashing NOR part... ErClos: rplyCLOS-erreom. Bad response: 0x002C, 6572 ErClos: rplyCLOS-erreom. Bad response: 0x002C, 6572 Write Failed at: 0x2001E0A0 Salam |
The Following User Says Thank You to abdoune For This Useful Post: |
08-12-2009, 04:34 | #5 (permalink) |
Major Poster Join Date: Sep 2006 Location: Leyte, Phillipines Age: 36
Member: 357476 Status: Offline Thanks Meter: 26 | flashing using this files: (dl at support area) M620XEHI1_binary.zip M620XEHI1_CTS.zip use good battery or better use rps...(4.7v) |
The Following User Says Thank You to cristafari007 For This Useful Post: |
10-05-2009, 09:59 | #6 (permalink) | |
Registered User Join Date: Feb 2008
Member: 710756 Status: Offline Sonork: 1625061 Thanks Meter: 9 | Quote:
That is the solution I also work with. thank you brother | |
10-05-2009, 10:31 | #7 (permalink) |
Freak Poster Join Date: Mar 2008 Location: VIET NAM
Member: 734429 Status: Offline Thanks Meter: 34 | try agin here : 1.use Tool:M620 optiflash 2.FW repair:M620ASIA1+cts.zip 3.FW :M620DXHE2.zip dowload from support 100% will be ok.tested |
The Following User Says Thank You to ANH BO For This Useful Post: |
10-09-2009, 16:32 | #9 (permalink) |
Insane Poster Join Date: Dec 2005 Location: Saudi Arabia Age: 35
Member: 211488 Status: Offline Thanks Meter: 14 | HI ALL, TRY TO REPAIRE IT 1.use Tool:M620 optiflash 2.FW repair:M620ASIA1+cts.zip 3.FW :M620DXHE2.zip dowload from support AND FLASH IT RJ45 AND USB IN ANOTHER TOOL SAMS B/R |
The Following User Says Thank You to shetos17 For This Useful Post: |
10-10-2009, 03:26 | #10 (permalink) |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | try to flash firmware the problem of your phone is firmware used this file tested don not flash in eeprom |
The Following User Says Thank You to lilong_lee For This Useful Post: |
10-10-2009, 04:33 | #12 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | if you have ustpro2 used to flash your problem solve nspro also used this |
m620 otp error need help | /\/\A/\/| | UST Pro II | 10 | 03-30-2010 17:45 |
6280 dead.. flashing error need help | bakhshalvi007 | HWK | 4 | 11-11-2007 13:14 |
Ngage QD flashing error...need help ? | the_frightener | Griffin | 2 | 06-03-2006 16:00 |
9210c flash error Need help | segsm | Twisterflasher | 3 | 12-01-2004 18:05 |
