10-13-2008, 13:30 | #1 (permalink) |
No Life Poster Join Date: May 2004 Location: the past, which is your future Age: 45
Member: 65216 Status: Offline Thanks Meter: 23 | Msl mismatch help!! UFS_USB V2.8 (c) SarasSoft 2007., S/n: XXX HID: 1E5079370027002D HWK: A1.04-PRO1 Licence: True Loaded Settings from: Sams.ini Phone Must be with Battery and Powered On ! MSL : Active MSL : Bypass Failed Old IMEI: 004400-01-693000-8 IMEI Rebuild Aborted Phone Must be with Battery and Powered On ! MSL : Active MSL : Bypass Failed Old IMEI: 004400-01-693000-8 IMEI Rebuild Aborted Using MSL S/N: R2XQ552906E 1st Boot Ok, McuId: 000200A3, Rom: 000200A3, 6-1.1 (Trident HPE) 2nd Boot Ok, McuId: 000200A3, Rom: 000200A3, 4-1.1 Fll Boot Ok, Vers: 5.13, fl_sceptrehp_sgh_hw1_v24_s07_m01_1.sre Flash1: Fl_Id: 00EC0000_22FD0000 - Samsung KBJ17KC00M-B Flash2: Fl_Id: 00EC0000_00340000 - Samsung KBH1xPE00M-N 1G Baud Rate Set: 460800 bps Image File: U600B__E2P_ok.s3t Flashing NOR part... Write Done, 131096 byte(s), Time: 00:27 Read Done, St: 0x20000000, 65536 byte(s), Time: 00:01, 0 Flashing NOR part... Write Done, 65552 byte(s), Time: 00:03 Phone Must be with Battery and Powered On ! MSL Repair Failed: MSL S/N Mismatch --------------------- i put the SN printed in back label, how can i check that its OK or not? also tried with NS and UST and msl problem remains. please help, its urgent |
10-13-2008, 13:42 | #2 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | I think someone put the PCB into a different housing, MSL is wrong, at the moment we cannot check the original MSL only know if the one entered is wrong. Odia. |
10-13-2008, 14:05 | #3 (permalink) |
Member: 65216 Status: Offline Thanks Meter: 23 | what solution can i have? i also read the e2p from a working u600b and tried to write its imei and msl and same result. phone was working OK before ust crap broke it via regular flash and imei was the same as in the back label. can u make SN out of imei number?? please help me out |
n70 product selection mismatch help??? | .:Baby @ngel:. | Nokia Base Band 5 ( BB-5 ) | 0 | 10-15-2009 12:58 |
n70 mismatch help pls. | venuno | Nokia Base Band 5 ( BB-5 ) | 0 | 06-13-2009 11:57 |
6085 mismatch help | leomuns | Nokia Hardware & Hardware Repair | 8 | 11-24-2008 06:37 |
MSL S/N Mismatch HELP | gsmuy | NSPRO | 3 | 10-13-2008 14:40 |
Samsung SPH-i500 MSL unlock Help | vish0402 | Various CDMA/TDMA Cell Phones | 1 | 05-08-2005 17:50 |
