07-30-2008, 20:58 | #1 (permalink) |
Freak Poster Join Date: May 2005 Age: 43
Member: 149311 Status: Offline Thanks Meter: 4 | n73 problem unlock help 1ST BOOT : C0,0C [Rm-133] OMAP ID : 17100708 OMAP MODE : 00 OMAP PBID : 30BDAB26834206CE1F20480E4CDA4820CDFDF16B OMAP HASH : 49A97E826B93BA20B7ED0B082475C005 OMAP ROID : 1DFD66132C872FD4 RAPx ID : 000000010000022600010006010C192101003000 EM 1 ID : 00000295 EM 2 ID : 00000B22 RAPx PBID : 22A00002E58146503A9788E5287DFBAB4AC9DDF3 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 1.30.0 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.31.0 CMT VPP : Internal CMT ALG Boot OK IMAGE : N73_4.0727.2.2.1_western_C00_PRD_cc.fpsx CMT NOR Erase Area: 0x00080000-00731421 CMT NOR Erase Area: 0x00000000-0005FFFF CMT NOR Erase Area: 0x001E0000-001FFFFF CMT NOR Erase Area: 0x00880000-00FEFFFF ERR: CMT FLASH ERASE PGM STAT NO VPP C7012D0103CD00B372 Process Failed, Repowering Mobile |
09-09-2008, 11:15 | #5 (permalink) |
Freak Poster Join Date: Apr 2001 Location: London
Member: 4091 Status: Offline Thanks Meter: 3 | I have the similar problem. Tried to ulock with BB5Box and I know have a dead N73. I have feeling that the test point disconnected before unlocking was finished. Any help will be greatly appreciated. Tried to flash with HWK but got same results as maniek27. BB5Box Log below. ------ Operation: UNLOCK V1 Date: 07-09-2008 Time: 21:33:13 ------ Connecting to BB5 Box ... Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-133 Version: V_05wk47v34.1_05-10-06_RM-133_(c)_Nokia. IMEI: 357651011671558 SP LOCK status: Config Key: 2342000000000000 Block 1: CLOSED Type 5 Data: 23420F Block 2: CLOSED Type 5 Data: 23420F Block 3: CLOSED Type 5 Data: 23594F Block 4: CLOSED Type 5 Data: 23594F Keyboard wrong codes counter: 0 wrong tries from max. 3 tries Cable wrong codes counter: 0 wrong tries from max. 10 tries Set Full Factory Defaults ... Reset phone ... Full Factory Defaults set OK Create autobackup of PM 308 Reading PM Field 308 Subfield 1 with length 8192 bytes Saving autobackup to file: RM-133_357651011671558_Locked_Keycnt_0_Fbuscnt_0__V_0 5wk47v34.1_05-10-06_RM-133_(c)_Nokia..bin Checking if model/version is supported for unlock ... Please connect testpoints Testpoints connected OK Keep Testpoints connected until unlock finish! Unlocking phone ... Try unlocking using keyboard codes ... Try number (Keyboard): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Keyboard): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using keyboard codes fail. Try unlocking using cable codes ... Try number (Cable): 1 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 2 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 3 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 4 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 5 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 6 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 7 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 8 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 9 Sending SP code: #pw+012345678901234+7# Response byte: 55 Try number (Cable): 10 Sending SP code: #pw+012345678901234+7# Response byte: 55 Unlock using cable codes fail. Reading again SP Locks ... ERROR: 11160001 ERROR: 30020111 |
09-09-2008, 11:39 | #7 (permalink) | |
No Life Poster Join Date: Sep 2007
Member: 582790 Status: Offline Thanks Meter: 378 | Quote:
for flashing flash this phone with jaf and for unlocking bb5 box or mtbox, advance bb5 etc | |
n73 problem plz HELP!!! | Misbahullah | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 11 | 01-22-2010 18:27 |
N73 - problem unlock, Response byte: 08 | Dmitry Erokhin | BB5BOX | 5 | 11-01-2007 22:05 |
n73 problem pl help | ruvanw1979 | UID - Box | 0 | 09-20-2007 11:36 |
N73 problem plz help | elkawasmy | Nokia Hardware & Hardware Repair | 2 | 05-24-2007 04:54 |
Motorolla C139 problem unlocking.. Help!!! | arimob | Smart-Clip | 12 | 08-01-2006 17:05 |
