07-04-2007, 06:10 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | need 100% working TP for Sams C260 + UFSHWK |
The Following User Says Thank You to IkaMazini For This Useful Post: |
07-04-2007, 16:54 | #6 (permalink) |
No Life Poster Join Date: Aug 2003 Location: BiH
Member: 37090 Status: Offline Thanks Meter: 42 | Tested with C140 (have no C260 at hand) - Info log: ----------- Software: C140BOGC3 Hardware: MP 0.800 IMEI: 355xxx-xx-xxxxxx-6 MSL : Active S/N : RVTP375407 MSL : Deactivated Lock Level: 01h SProv Code: ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh IMSI Mask : 21h 90h 10h 00h 00h 00h 00h 00h PCK : 0 NCK : 0 SCK : 0 SPCK: 0 MCK : 0 - Unlock log: ------------- MSL : Active S/N : RVTP375407 MSL : Deactivated Clear SPLocks Done, Time: 0:04 Clear SimLock Done, Time: 0:02 Clear UserLock Done, Time: 0:01 Unlock Done, Time: 0:08 - Read E2P log: --------------- 1st Boot Ok, McuId: 000603EE, Rom: 00004B45, 5-1.0 (Trident 2) 2nd Boot Ok, McuId: 000603EE, Rom: 00004B45, 2-1.1 Fll Boot Ok, Vers: 5.11, fl_sceptre3_nice_std_v24.sre Flash1: Fl_Id: 00B00000_008D0000 - Sharp LRS18CK Baud Rate Set: 460800 bps Read Done, St: 0x00000000, 131072 byte(s), Time: 0:04, 0 Read Done, St: 0x00600000, 2097152 byte(s), Time: 1:05, 0 E2P Saved as C:\Program Files\SarasSoft\UFS\UFS_SAMs\C140\C140__E2P.s3t |
The Following User Says Thank You to XisiX For This Useful Post: |
07-04-2007, 17:42 | #9 (permalink) |
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | Thx my friend, this solution 100000001% working. [QUOTE=XisiX;2556342]Tested with C140 (have no C260 at hand) - Info log: ----------- Software: C140BOGC3 Hardware: MP 0.800 IMEI: 355xxx-xx-xxxxxx-6 MSL : Active S/N : RVTP375407 MSL : Deactivated Lock Level: 01h SProv Code: ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh ffh IMSI Mask : 21h 90h 10h 00h 00h 00h 00h 00h PCK : 0 NCK : 0 SCK : 0 SPCK: 0 MCK : 0 - Unlock log: ------------- MSL : Active S/N : RVTP375407 MSL : Deactivated Clear SPLocks Done, Time: 0:04 Clear SimLock Done, Time: 0:02 Clear UserLock Done, Time: 0:01 Unlock Done, Time: 0:08 ........................................... |
07-10-2007, 16:38 | #14 (permalink) |
Insane Poster Join Date: Apr 2007 Location: Bulgaria Age: 46
Member: 481337 Status: Offline Thanks Meter: 6 | The cable for C140 works with C260. I unlocked over 20-30 C260's with my C140 cable. The pinouts are SAME for C140 and C260, but the positions of the TPs on the phone are on differnet places. On C140 they are vertical, and on C260 they are in horizontal position. So you need to CUT the cable PCB. After that you can use the cable, but you must fix the PCB to the phone with your hand, because after the cut you cannot fix it to the phone's pannel and it is moving if you do not hold it... Works 100% |
07-12-2007, 14:15 | #15 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 44
Member: 173810 Status: Offline Thanks Meter: 2 | dear mates im geting mad here with c260 i have COM CABLE 4 E770 ;E860,rj45 samsun r2xx cable how to connect them to phone is trying to kill my brain. after reading all this post i realise there is tp to it does it maen i have to cut the edge of the cable to connect it to phone? plz help me to locate and understand it i need it urgently thank any one who will help out |
Cable Compatible For Sam C260 For Z3X Box | IPMART | ipmart WebShop | 0 | 08-24-2009 10:50 |
please help need unlock cable for sam c260/c140 with com or usb | nassimo | Trident/AGERE Platform | 4 | 08-15-2008 15:40 |
S.O.S. I need 100% working pinouts for 8800+ | IkaMazini | Infinity-Box | 1 | 10-27-2007 17:30 |
need pinout rj-45 for sams c260 | IkaMazini | HWK | 0 | 06-08-2007 16:24 |
Need 100% working scheme for EMMIBOX with BIC43E08. | Bogi | Motorola Old Legacy (EMMI) | 3 | 09-01-2001 22:06 |
