11-29-2007, 11:03 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Dombivli (E) Age: 48
Member: 124938 Status: Offline Thanks Meter: 69 | NTLDR is nissing after installing 2.0.5 (4) I was using Cloned HWK which was dead for unknown reason, so I had purchased original HWK with UFS3. As per the instructions given by my vendor, I installed requisted files in my laptop with vista ultimate, everything went fine but upon installing 2.0.5 (7) it halts at error message related to prefetch and reboots my laptop so I didn't installed it and everything worked fine on my laptop. Then, I decided to installed it in my desktop with WinXP SP2 where the cloned installation exist. First I uninstalled sarassoft suite and then clean my prefetch folder. Then installed v2.0.5, 1, 2, 3 and when installing 4 it halts with Access Voilation Error and system was rebooted. Then, NTLDR is missing Press CTRL+ALT+DEL to restart. Formated my PC with Fresh installation of WinXP, I did the same thing. But again. NTLDR is missing Press CTRL+ALT+DEL to restart. really it is very tough to install HWK suite as compared with JAF and Cruiser. To all @sarassoft, Tell me how many times I have to install WinXP to make this software work. The cloned thing is in the garbage now and had no relation with my pc anymore. Everytime I install this I have to keep my finger cross for next reboot and error. Till today I installed WinXP 3 times. Please do the needful and provide me a good solution. Thanks Aju |
The Following User Says Thank You to ajubaba For This Useful Post: |
11-29-2007, 12:28 | #2 (permalink) |
Crazy Poster Join Date: Jan 2006 Location: Serbia
Member: 220074 Status: Offline Thanks Meter: 5 | I had the same probl ntldr is missing,but solved it with reinstalation of WinXP.Try delete C partition,than create it again,than quick format in NTFS file sistem and instal WinXP.I solved my probl by doing that@ |
11-29-2007, 12:58 | #4 (permalink) | |
Insane Poster Join Date: Aug 2006 Location: Vojvodina Age: 45
Member: 331495 Status: Offline Thanks Meter: 1 | Quote:
1. Insert your XP Installtion disk, go to Recovery Console 2. Copy x:\i386\ntldr c:\ 3. Copy x:\i386\ntdetect.com c:\ 4. bootcfg /scan 5. bootcfg /add 6. fixboot 7. fixmbr 8. exit | |
11-30-2007, 07:52 | #6 (permalink) | ||
Member: 124938 Status: Offline Thanks Meter: 69 | Quote:
Also @all members those who have this problem, try the method which I had used it worked for me. Regarding the suggestion given by KrKr Quote:
Thanks all for your replies. But to odia this is an humble request that please do not perform this kind of security which deletes the main booting files of WinXP. I know that this step is just to avoid cracked or cloned devices but for those who purchased orginal are suffering 'cause we have to loose the data in C drive as we had installed all the nokia flash files in it of around 10 GB+. and It takes time to install it again and again. So please think over it. And be kind enough for genuine users. Thanks Aju | ||
11-30-2007, 09:36 | #7 (permalink) |
No Life Poster Join Date: Nov 2007 Location: tunisia elmanar sfax
Member: 636518 Status: Offline Thanks Meter: 175 | hi friend ..there s a simple solution : -install ufs suite -run SBM REPAIR (( he will check and repair your system)) ........... now your pc is ok ....................................... ............tsted 1000/100........................................... join me at msn ([email protected]) i will apload you (SBM repair) |
11-30-2007, 15:04 | #8 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2002 Age: 48
Member: 8879 Status: Offline Sonork: 100.84016 Thanks Meter: 327 | Quote:
OR, you could jsut rapidshare it and uplaod link here? For all users to enjoy of course! | |
11-30-2007, 16:35 | #9 (permalink) | |
Freak Poster Join Date: May 2005 Location: Hampshire..U K
Member: 149813 Status: Offline Thanks Meter: 50 | Quote:
Free for all http://rapidshare.com/files/73345965...r_HWK.rar.html BR | |
11-30-2007, 17:27 | #10 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | We thought over it, which is why only the boot files where removed, we could have removed the whole partition, if you chose to format your HDD, then you chose to lose data, we did not make you format. But on further thoughts even boot file deletion was removed from 2.0.6. Odia. |
12-01-2007, 08:16 | #11 (permalink) | |
NTLDR is not restored by bootcfg, fixboot commands in recovery console. So an user has to format and reinstall the WinXP and this is because of NTLDR and NTDETECT.COM files deleted by sarassoft (May be you may have an alternate method to restore this). But anyways, as I said, I love this product and this was my start product of my carrier. One product which covers Samsung, Sony, Nokia and Motorola. Aju | |
12-01-2007, 09:18 | #12 (permalink) | |
I know it is working like that becase I did it several times. | |
12-12-2007, 11:46 | #13 (permalink) |
Insane Poster Join Date: Nov 2007
Member: 625409 Status: Offline Thanks Meter: 28 | -install ufs suite -run SBM REPAIR (( he will check and repair your system)) ........... now your pc is ok ....................................... ............tsted 1000/100........................................... join me at msn ([email protected]) i will apload you (SBM repair)[/quote] |
PROBLEM SOLVED WHEN HWK install 2.0.5 -> PC turn off | ..::: Naveed :::.. | HWK | 10 | 06-28-2007 12:01 |
PROBLEM HWK install 2.0.5 -> PC turn off | monjack | HWK | 14 | 06-23-2007 10:13 |
