11-08-2013, 15:55 | #1 (permalink) |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | Nokia 105 flashing problem set is restarting with sim set is also new info is ok but flashing always stop with this error |
11-08-2013, 15:57 | #2 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Lahore
Member: 1611524 Status: Offline Sonork: 100.1637126 Thanks Meter: 385 | there is no releas officail firmwware wait for officail firmware then try br GSM.SOLVE |
The Following User Says Thank You to GSM.solve For This Useful Post: |
11-08-2013, 16:01 | #3 (permalink) |
Product Supporter Join Date: Aug 2007 Location: karachi
Member: 572216 Status: Offline Sonork: 100.1612300 Thanks Meter: 3,737 | no loader have form any tool this time for this mobile.so you can not flash with any tool this phone.only you can remove user code.also Nokia not release official firmware. br |
11-08-2013, 16:06 | #5 (permalink) | |
Member: 953334 Status: Offline Sonork: 100.1614005 Thanks Meter: 15,424 | flashing is supported see new update info Quote:
11-09-2013, 21:39 | #8 (permalink) |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | The info in the window does not indicate flashing but "check" process. Now, what you have there is probably due to poor connectivity between cable and phone. This is usually common when checking phones like nokia 1280 and 103 and even 1616. I will advise you check the cable and also the inner part of the phone especially under the LCD for any dampness. |
11-10-2013, 00:09 | #9 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Hate stupidity
Member: 904530 Status: Offline Thanks Meter: 517 | not need to argue just look to vpl with notepad: <?xml version="1.0" encoding="UTF-8" ?> <VariantPackingList> <Tracking> <OriginalFileName>RM732_059C435_04.35_001.vpl</OriginalFileName> <TimeStamp>2011-03-22T09:06:00Z</TimeStamp> <Origin></Origin> </Tracking> <Variant> <VariantIdentification> <Description>BTR EU Basic Transceiver for SW 04.35</Description> <TypeDesignator>RM-732</TypeDesignator> <ProductCode>059C435</ProductCode> </VariantIdentification> <SwVersion>04.35</SwVersion> <VariantVersion>001</VariantVersion> <FileList> <File> <Name>RM732_059C435_04.35_001.dcp</Name> <FileType>Dcp</FileType> <Signed>true</Signed> <Optional>false</Optional> <Crc>EE509D10</Crc> |
11-10-2013, 05:54 | #11 (permalink) |
Banned Join Date: Jul 2011 Age: 32
Member: 1609044 Status: Offline Thanks Meter: 892 | for this problem you can use atf cause atf can read flash file from set infineon tab so find runing set do read flash from runing set & write to fault phone problem solved |
11-10-2013, 12:56 | #13 (permalink) |
Freak Poster Join Date: Oct 2012 Location: Mymensingh,Dhaka,Bangladesh
Member: 1821096 Status: Offline Sonork: 100.1650210 Thanks Meter: 346 | Nokia 105 Flashingh UI Done 100000000% Done Nokia 105 ui Settings Easy Flashingh Tools By Liton_Bkash Infinity best by [email protected] - Download - 4shared |
The Following 3 Users Say Thank You to Liton_Bkash For This Useful Post: |
11-11-2013, 13:32 | #15 (permalink) |
Freak Poster Join Date: Jan 2010 Location: JANGAON-AP
Member: 1197753 Status: Offline Sonork: [email protected] Thanks Meter: 32 | cyclone box best in all new models |
