01-05-2016, 20:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,802 | nokia 107 network problem i got nokia 107 with security code after flashing it detect sim card but detect network and cannot call here is log If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC BAUD_R: 3000000 FL_ID : 20000488, Numonyx M36L0R7040U 128Mb ShutDown Done Rebooting Mobile MCU SW : V 02.70 08-08-13 RM-961 (c) Nokia PPM SW : V 02.70 08-08-13 RM-961 (c) Nokia IA Platform: Infineon XG110 Prd.Code: 059T2B8 Bpr.Code: 059S7H5 Prod.Sn : E5959C8BI HW Vers : 2000 UEM : 1328 UPP : 8850 [2292] LCD Type: TINAMA:BARACOAv8A NT39121 IMEI : 359587-05-774804-1 SL Conf : 001-01-00000000000 SL Prof : 000000000004000-2 SL Var : 00003595870577480400 SL Aux : 000B0000 HW Sig : 595E1FD6B5F874D1 Box Id : FFFFFFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: GSM Test Equipment so it hw or sw |
01-17-2016, 13:12 | #4 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,802 | i tried 5 different software all same result no network when i make manual search network founnd in list but when selecting its tke long time then cannot register on network Code: If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC BAUD_R: 3000000 FL_ID : 20000488, Numonyx M36L0R7040U 128Mb ShutDown Done Rebooting Mobile If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD110, Ok IF_EBL: Default_RAM_Bootloader 10.24, Mode: CC BAUD_R: 3000000 FL_ID : 20000488, Numonyx M36L0R7040U 128Mb MCU FLASH BUNDLE: rm961_02.700 Flash File: hw_b1_rm961_02.700.fls Erase Area: 0x00000000 - 0x0001FFFE, Erased: 00:01 Write Area: 0x00000000 - 0x00005FFE, Written: 00:00 Erase Area: 0x00800000 - 0x00BFFFFE, Erased: 00:38 Write Area: 0x00800000 - 0x00BEFFFE, Written: 00:31 Erase Area: 0x00C5D000 - 0x00E5FFFE, Erased: 00:18 Write Area: 0x00C5D000 - 0x00DFB6FE, Written: 00:13 Warning, Checksum Mismatch: B26A > AFFC PPM FLASH BUNDLE: rm961_02.70ic Flash File: hw_b1_rm961_02.70ic.fls Erase Area: 0x00100000 - 0x007FFFFE, Erased: 01:07 Write Area: 0x00100000 - 0x0067183E, Written: 00:42 Warning, Checksum Mismatch: C292 > 361B CNT FLASH BUNDLE: rm961_nai02.70ic Flash File: hw_b1_rm961_nai02.70ic.fls Erase Area: 0x00E60000 - 0x00F5FFFE, Erased: 00:09 Write Area: 0x00E60000 - 0x00F5EDFE, Written: 00:07 Warning, Checksum Mismatch: 4A7A > CF54 Flashing Done: 04:03 ShutDown Done |
01-17-2016, 13:42 | #6 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,802 | i tried flashing many times now i get network but cannot make calls or sms when make manual scann for network i can find them but no call so is that sw or hw fault |
01-18-2016, 17:59 | #9 (permalink) |
Freak Poster Join Date: Dec 2011 Location: Russia, North Ural Age: 68
Member: 1702061 Status: Offline Sonork: 100.1651562 Thanks Meter: 306 | Take 2 -3 sim cards from different gsm providers and check it all. If all the same as with first sim card, it nean - hardware problem. |
01-19-2016, 18:35 | #12 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,802 | i got pm from working phone i wrote it with 2 error [CODE]PM File: Rm-961_wwwww355739060298043.pm Group Id: [4] Rec: 0 Len: 1 ...... Ok 1 Group Id: [4] Rec: 1 Len: 20 ..... Ok 1 Group Id: [4] Rec: 2 Len: 22 ..... Ok 1 Group Id: [4] Rec: 3 Len: 10 ..... Ok 1 Group Id: [4] Rec: 4 Len: 8 ...... Ok 1 Group Id: [4] Rec: 5 Len: 8 ...... Ok 1 Group Id: [4] Rec: 6 Len: 8 ...... Ok 1 Group Id: [4] Rec: 9 Len: 5 ...... Ok 1 Group Id: [5] Rec: 0 Len: 78 ..... Ok 1 Group Id: [11] Rec: 0 Len: 4 ...... Ok 1 Group Id: [11] Rec: 1 Len: 4 ...... Ok 1 Group Id: [11] Rec: 2 Len: 4 ...... Ok 1 Group Id: [11] Rec: 3 Len: 4 ...... Ok 1 Group Id: [11] Rec: 4 Len: 1 ...... Ok 1 Group Id: [11] Rec: 5 Len: 6 ...... Ok 1 Group Id: [11] Rec: 6 Len: 4 ...... Ok 1 Group Id: [11] Rec: 7 Len: 4 ...... Ok 1 Group Id: [11] Rec: 8 Len: 2 ...... Ok 1 Group Id: [11] Rec: 9 Len: 1 ...... Ok 1 Group Id: [11] Rec: 10 Len: 4 ...... Ok 1 Group Id: [11] Rec: 11 Len: 14 ..... Ok 1 Group Id: [11] Rec: 12 Len: 2 ...... Ok 1 Group Id: [11] Rec: 13 Len: 1 ...... Ok 1 Group Id: [11] Rec: 14 Len: 1 ...... Ok 1 Group Id: [11] Rec: 15 Len: 1 ...... Ok 1 Group Id: [11] Rec: 16 Len: 8 ...... Ok 1 Group Id: [11] Rec: 17 Len: 1 ...... Ok 1 Group Id: [11] Rec: 18 Len: 1 ...... Ok 1 Group Id: [11] Rec: 19 Len: 4 ...... Ok 1 Group Id: [11] Rec: 20 Len: 2 ...... Ok 1 Group Id: [11] Rec: 21 Len: 2 ...... Ok 1 Group Id: [11] Rec: 22 Len: 1 ...... Ok 1 Group Id: [11] Rec: 23 Len: 8 ...... Ok 1 Group Id: [11] Rec: 24 Len: 1 ...... Ok 1 Group Id: [11] Rec: 25 Len: 2 ...... Ok 1 Group Id: [11] Rec: 26 Len: 2 ...... Ok 1 Group Id: [11] Rec: 27 Len: 2 ...... Ok 1 Group Id: [11] Rec: 28 Len: 2 ...... Ok 1 Group Id: [11] Rec: 29 Len: 2 ...... Ok 1 Group Id: [11] Rec: 30 Len: 4 ...... Ok 1 Group Id: [11] Rec: 31 Len: 4 ...... Ok 1 Group Id: [11] Rec: 32 Len: 4 ...... Ok 1 Group Id: [11] Rec: 33 Len: 4 ...... Ok 1 Group Id: [11] Rec: 34 Len: 4 ...... Ok 1 Group Id: [11] Rec: 35 Len: 4 ...... Ok 1 Group Id: [11] Rec: 36 Len: 4 ...... Ok 1 Group Id: [11] Rec: 37 Len: 16 ..... Ok 1 Group Id: [11] Rec: 38 Len: 4 ...... Ok 1 Group Id: [11] Rec: 39 Len: 2 ...... Ok 1 Group Id: [11] Rec: 40 Len: 4 ...... Ok 1 Group Id: [11] Rec: 41 Len: 2 ...... Ok 1 Group Id: [11] Rec: 42 Len: 2 ...... Ok 1 Group Id: [11] Rec: 43 Len: 1 ...... Ok 1 Group Id: [11] Rec: 44 Len: 1 ...... Ok 1 Group Id: [11] Rec: 45 Len: 4 ...... Ok 1 Group Id: [11] Rec: 46 Len: 4 ...... Ok 1 Group Id: [11] Rec: 47 Len: 4 ...... Ok 1 Group Id: [11] Rec: 48 Len: 4 ...... Ok 1 Group Id: [11] Rec: 49 Len: 4 ...... Ok 1 Group Id: [11] Rec: 50 Len: 4 ...... Ok 1 Group Id: [11] Rec: 51 Len: 4 ...... Ok 1 Group Id: [11] Rec: 52 Len: 4 ...... Ok 1 Group Id: [11] Rec: 53 Len: 4 ...... Ok 1 Group Id: [11] Rec: 54 Len: 4 ...... Ok 1 Group Id: [11] Rec: 55 Len: 4 ...... Ok 1 Group Id: [11] Rec: 56 Len: 4 ...... Ok 1 Group Id: [11] Rec: 57 Len: 4 ...... Ok 1 Group Id: [11] Rec: 58 Len: 4 ...... Ok 1 Group Id: [11] Rec: 59 Len: 4 ...... Ok 1 Group Id: [11] Rec: 60 Len: 4 ...... Ok 1 Group Id: [11] Rec: 61 Len: 4 ...... Ok 1 Group Id: [11] Rec: 62 Len: 4 ...... Ok 1 Group Id: [11] Rec: 63 Len: 4 ...... Ok 1 Group Id: [11] Rec: 64 Len: 2 ...... Ok 1 Group Id: [11] Rec: 65 Len: 4 ...... Ok 1 Group Id: [11] Rec: 66 Len: 2 ...... Ok 1 Group Id: [11] Rec: 67 Len: 1 ...... Ok 1 Group Id: [11] Rec: 68 Len: 16 ..... Ok 1 Group Id: [11] Rec: 69 Len: 4 ...... Ok 1 Group Id: [11] Rec: 70 Len: 2 ...... Ok 1 Group Id: [11] Rec: 71 Len: 2 ...... Ok 1 Group Id: [11] Rec: 72 Len: 2 ...... Ok 1 Group Id: [11] Rec: 73 Len: 2 ...... Ok 1 Group Id: [11] Rec: 74 Len: 2 ...... Ok 1 Group Id: [11] Rec: 75 Len: 2 ...... Ok 1 Group Id: [11] Rec: 76 Len: 2 ...... Ok 1 Group Id: [11] Rec: 77 Len: 2 ...... Ok 1 Group Id: [11] Rec: 78 Len: 2 ...... Ok 1 Group Id: [11] Rec: 79 Len: 2 ...... Ok 1 Group Id: [11] Rec: 80 Len: 2 ...... Ok 1 Group Id: [11] Rec: 81 Len: 2 ...... Ok 1 Group Id: [11] Rec: 82 Len: 2 ...... Ok 1 Group Id: [11] Rec: 83 Len: 2 ...... Ok 1 Group Id: [11] Rec: 84 Len: 2 ...... Ok 1 Group Id: [11] Rec: 85 Len: 2 ...... Ok 1 Group Id: [11] Rec: 86 Len: 2 ...... Ok 1 Group Id: [11] Rec: 87 Len: 2 ...... Ok 1 Group Id: [11] Rec: 88 Len: 2 ...... Ok 1 Group Id: [11] Rec: 89 Len: 2 ...... Ok 1 Group Id: [11] Rec: 90 Len: 2 ...... Ok 1 Group Id: [11] Rec: 91 Len: 2 ...... Ok 1 Group Id: [11] Rec: 92 Len: 2 ...... Ok 1 Group Id: [11] Rec: 93 Len: 2 ...... Ok 1 Group Id: [11] Rec: 94 Len: 2 ...... Ok 1 Group Id: [11] Rec: 95 Len: 2 ...... Ok 1 Group Id: [13] Rec: 0 Len: 70 ..... Ok 1 Group Id: [13] Rec: 1 Len: 70 ..... Ok 1 Group Id: [13] Rec: 2 Len: 70 ..... Ok 1 Group Id: [13] Rec: 3 Len: 70 ..... Ok 1 Group Id: [13] Rec: 4 Len: 70 ..... Ok 1 Group Id: [13] Rec: 5 Len: 70 ..... Ok 1 Group Id: [13] Rec: 6 Len: 70 ..... Ok 1 Group Id: [13] Rec: 7 Len: 70 ..... Ok 1 Group Id: [13] Rec: 8 Len: 70 ..... Ok 1 Group Id: [13] Rec: 9 Len: 70 ..... Ok 1 Group Id: [13] Rec: 10 Len: 70 ..... Ok 1 Group Id: [13] Rec: 11 Len: 70 ..... Ok 1 Group Id: [13] Rec: 12 Len: 70 ..... Ok 1 Group Id: [13] Rec: 13 Len: 70 ..... Ok 1 Group Id: [13] Rec: 14 Len: 70 ..... Ok 1 Group Id: [13] Rec: 15 Len: 70 ..... Ok 1 Group Id: [13] Rec: 16 Len: 70 ..... Ok 1 Group Id: [13] Rec: 17 Len: 70 ..... Ok 1 Group Id: [13] Rec: 18 Len: 70 ..... Ok 1 Group Id: [13] Rec: 19 Len: 70 ..... Ok 1 Group Id: [13] Rec: 20 Len: 70 ..... Ok 1 Group Id: [13] Rec: 21 Len: 70 ..... Ok 1 Group Id: [13] Rec: 22 Len: 70 ..... Ok 1 Group Id: [13] Rec: 23 Len: 70 ..... Ok 1 Group Id: [13] Rec: 24 Len: 70 ..... Ok 1 Group Id: [13] Rec: 25 Len: 70 ..... Ok 1 Group Id: [13] Rec: 26 Len: 70 ..... Ok 1 Group Id: [13] Rec: 27 Len: 70 ..... Ok 1 Group Id: [13] Rec: 28 Len: 70 ..... Ok 1 Group Id: [13] Rec: 29 Len: 70 ..... Ok 1 Group Id: [13] Rec: 30 Len: 70 ..... Ok 1 Group Id: [13] Rec: 31 Len: 70 ..... Ok 1 Group Id: [13] Rec: 32 Len: 70 ..... Ok 1 Group Id: [13] Rec: 33 Len: 70 ..... Ok 1 Group Id: [13] Rec: 34 Len: 70 ..... Ok 1 Group Id: [13] Rec: 35 Len: 70 ..... Ok 1 Group Id: [13] Rec: 36 Len: 70 ..... Ok 1 Group Id: [13] Rec: 37 Len: 70 ..... Ok 1 Group Id: [13] Rec: 38 Len: 70 ..... Ok 1 Group Id: [13] Rec: 39 Len: 70 ..... Ok 1 Group Id: [13] Rec: 40 Len: 70 ..... Ok 1 Group Id: [13] Rec: 41 Len: 70 ..... Ok 1 Group Id: [13] Rec: 42 Len: 70 ..... Ok 1 Group Id: [13] Rec: 43 Len: 70 ..... Ok 1 Group Id: [13] Rec: 44 Len: 70 ..... Ok 1 Group Id: [13] Rec: 45 Len: 70 ..... Ok 1 Group Id: [13] Rec: 46 Len: 70 ..... Ok 1 Group Id: [13] Rec: 47 Len: 70 ..... Ok 1 Group Id: [13] Rec: 48 Len: 70 ..... Ok 1 Group Id: [13] Rec: 49 Len: 70 ..... Ok 1 Group Id: [13] Rec: 50 Len: 70 ..... Ok 1 Group Id: [13] Rec: 51 Len: 70 ..... Ok 1 Group Id: [13] Rec: 52 Len: 70 ..... Ok 1 Group Id: [13] Rec: 53 Len: 70 ..... Ok 1 Group Id: [13] Rec: 54 Len: 70 ..... Ok 1 Group Id: [13] Rec: 55 Len: 70 ..... Ok 1 Group Id: [13] Rec: 56 Len: 70 ..... Ok 1 Group Id: [13] Rec: 57 Len: 70 ..... Ok 1 Group Id: [13] Rec: 58 Len: 70 ..... Ok 1 Group Id: [13] Rec: 59 Len: 70 ..... Ok 1 Group Id: [13] Rec: 60 Len: 70 ..... Ok 1 Group Id: [13] Rec: 61 Len: 70 ..... Ok 1 Group Id: [13] Rec: 62 Len: 70 ..... Ok 1 Group Id: [13] Rec: 63 Len: 70 ..... Ok 1 Group Id: [13] Rec: 64 Len: 70 ..... Ok 1 Group Id: [13] Rec: 65 Len: 70 ..... Ok 1 Group Id: [13] Rec: 66 Len: 70 ..... Ok 1 Group Id: [13] Rec: 67 Len: 70 ..... Ok 1 Group Id: [13] Rec: 68 Len: 70 ..... Ok 1 Group Id: [13] Rec: 69 Len: 70 ..... Ok 1 Group Id: [13] Rec: 70 Len: 70 ..... Ok 1 Group Id: [13] Rec: 71 Len: 70 ..... Ok 1 Group Id: [13] Rec: 72 Len: 70 ..... Ok 1 Group Id: [13] Rec: 73 Len: 70 ..... Ok 1 Group Id: [13] Rec: 74 Len: 70 ..... Ok 1 Group Id: [13] Rec: 75 Len: 70 ..... Ok 1 Group Id: [13] Rec: 76 Len: 70 ..... Ok 1 Group Id: [13] Rec: 77 Len: 70 ..... Ok 1 Group Id: [13] Rec: 78 Len: 70 ..... Ok 1 Group Id: [13] Rec: 79 Len: 70 ..... Ok 1 Group Id: [13] Rec: 80 Len: 70 ..... Ok 1 Group Id: [13] Rec: 81 Len: 70 ..... Ok 1 Group Id: [13] Rec: 82 Len: 70 ..... Ok 1 Group Id: [13] Rec: 83 Len: 70 ..... Ok 1 Group Id: [13] Rec: 84 Len: 70 ..... Ok 1 Group Id: [13] Rec: 85 Len: 70 ..... Ok 1 Group Id: [13] Rec: 86 Len: 70 ..... Ok 1 Group Id: [13] Rec: 87 Len: 70 ..... Ok 1 Group Id: [13] Rec: 88 Len: 70 ..... Ok 1 Group Id: [13] Rec: 89 Len: 70 ..... Ok 1 Group Id: [13] Rec: 90 Len: 70 ..... Ok 1 Group Id: [13] Rec: 91 Len: 70 ..... Ok 1 Group Id: [13] Rec: 92 Len: 70 ..... Ok 1 Group Id: [13] Rec: 93 Len: 70 ..... Ok 1 Group Id: [13] Rec: 94 Len: 70 ..... Ok 1 Group Id: [13] Rec: 95 Len: 70 ..... Ok 1 Group Id: [13] Rec: 96 Len: 70 ..... Ok 1 Group Id: [13] Rec: 97 Len: 70 ..... Ok 1 Group Id: [13] Rec: 98 Len: 70 ..... Ok 1 Group Id: [13] Rec: 99 Len: 70 ..... Ok 1 Group Id: [13] Rec: 100 Len: 70 ..... Ok 1 Group Id: [13] Rec: 101 Len: 70 ..... Ok 1 Group Id: [13] Rec: 102 Len: 70 ..... Ok 1 Group Id: [13] Rec: 103 Len: 70 ..... Ok 1 Group Id: [13] Rec: 104 Len: 70 ..... Ok 1 Group Id: [13] Rec: 105 Len: 70 ..... Ok 1 Group Id: [13] Rec: 106 Len: 70 ..... Ok 1 Group Id: [13] Rec: 107 Len: 70 ..... Ok 1 Group Id: [13] Rec: 108 Len: 70 ..... Ok 1 Group Id: [13] Rec: 109 Len: 70 ..... Ok 1 Group Id: [13] Rec: 110 Len: 70 ..... Ok 1 Group Id: [13] Rec: 111 Len: 70 ..... Ok 1 Group Id: [13] Rec: 112 Len: 70 ..... Ok 1 Group Id: [13] Rec: 113 Len: 70 ..... Ok 1 Group Id: [13] Rec: 114 Len: 70 ..... Ok 1 Group Id: [13] Rec: 115 Len: 70 ..... Ok 1 Group Id: [13] Rec: 116 Len: 70 ..... Ok 1 Group Id: [13] Rec: 117 Len: 70 ..... Ok 1 Group Id: [13] Rec: 118 Len: 70 ..... Ok 1 Group Id: [13] Rec: 119 Len: 70 ..... Ok 1 Group Id: [13] Rec: 120 Len: 70 ..... Ok 1 Group Id: [13] Rec: 121 Len: 70 ..... Ok 1 Group Id: [13] Rec: 122 Len: 70 ..... Ok 1 Group Id: [13] Rec: 123 Len: 70 ..... Ok 1 Group Id: [13] Rec: 124 Len: 70 ..... Ok 1 Group Id: [13] Rec: 125 Len: 70 ..... Ok 1 Group Id: [13] Rec: 126 Len: 70 ..... Ok 1 Group Id: [13] Rec: 127 Len: 70 ..... Ok 1 Group Id: [13] Rec: 128 Len: 70 ..... Ok 1 Group Id: [13] Rec: 129 Len: 70 ..... Ok 1 Group Id: [13] Rec: 130 Len: 70 ..... Ok 1 Group Id: [13] Rec: 131 Len: 70 ..... Ok 1 Group Id: [13] Rec: 132 Len: 70 ..... Ok 1 Group Id: [13] Rec: 133 Len: 70 ..... Ok 1 Group Id: [13] Rec: 134 Len: 70 ..... Ok 1 Group Id: [13] Rec: 135 Len: 70 ..... Ok 1 Group Id: [13] Rec: 136 Len: 70 ..... Ok 1 Group Id: [13] Rec: 137 Len: 70 ..... Ok 1 Group Id: [13] Rec: 138 Len: 70 ..... Ok 1 Group Id: [13] Rec: 139 Len: 70 ..... Ok 1 Group Id: [13] Rec: 140 Len: 70 ..... Ok 1 Group Id: [13] Rec: 141 Len: 70 ..... Ok 1 Group Id: [13] Rec: 142 Len: 70 ..... Ok 1 Group Id: [13] Rec: 143 Len: 70 ..... Ok 1 Group Id: [13] Rec: 144 Len: 70 ..... Ok 1 Group Id: [13] Rec: 145 Len: 70 ..... Ok 1 Group Id: [13] Rec: 146 Len: 70 ..... Ok 1 Group Id: [13] Rec: 147 Len: 70 ..... Ok 1 Group Id: [13] Rec: 148 Len: 70 ..... Ok 1 Group Id: [13] Rec: 149 Len: 70 ..... Ok 1 Group Id: [13] Rec: 150 Len: 70 ..... Ok 1 Group Id: [13] Rec: 151 Len: 70 ..... Ok 1 Group Id: [13] Rec: 152 Len: 70 ..... Ok 1 Group Id: [13] Rec: 153 Len: 70 ..... Ok 1 Group Id: [13] Rec: 154 Len: 70 ..... Ok 1 Group Id: [13] Rec: 155 Len: 70 ..... Ok 1 Group Id: [13] Rec: 156 Len: 70 ..... Ok 1 Group Id: [13] Rec: 157 Len: 70 ..... Ok 1 Group Id: [13] Rec: 158 Len: 70 ..... Ok 1 Group Id: [13] Rec: 159 Len: 70 ..... Ok 1 Group Id: [13] Rec: 160 Len: 70 ..... Ok 1 Group Id: [13] Rec: 161 Len: 70 ..... Ok 1 Group Id: [13] Rec: 162 Len: 70 ..... Ok 1 Group Id: [13] Rec: 163 Len: 70 ..... Ok 1 Group Id: [13] Rec: 164 Len: 70 ..... Ok 1 Group Id: [13] Rec: 165 Len: 70 ..... Ok 1 Group Id: [13] Rec: 166 Len: 70 ..... Ok 1 Group Id: [13] Rec: 167 Len: 70 ..... Ok 1 Group Id: [13] Rec: 168 Len: 70 ..... Ok 1 Group Id: [13] Rec: 169 Len: 70 ..... Ok 1 Group Id: [13] Rec: 170 Len: 70 ..... Ok 1 Group Id: [13] Rec: 171 Len: 70 ..... Ok 1 Group Id: [13] Rec: 172 Len: 70 ..... Ok 1 Group Id: [13] Rec: 173 Len: 70 ..... Ok 1 Group Id: [13] Rec: 174 Len: 70 ..... Ok 1 Group Id: [13] Rec: 175 Len: 70 ..... Ok 1 Group Id: [13] Rec: 176 Len: 70 ..... Ok 1 Group Id: [13] Rec: 177 Len: 70 ..... Ok 1 Group Id: [13] Rec: 178 Len: 70 ..... Ok 1 Group Id: [13] Rec: 179 Len: 70 ..... Ok 1 Group Id: [13] Rec: 180 Len: 70 ..... Ok 1 Group Id: [13] Rec: 181 Len: 70 ..... Ok 1 Group Id: [13] Rec: 182 Len: 70 ..... Ok 1 Group Id: [13] Rec: 183 Len: 70 ..... Ok 1 Group Id: [13] Rec: 184 Len: 70 ..... Ok 1 Group Id: [13] Rec: 185 Len: 70 ..... Ok 1 Group Id: [13] Rec: 186 Len: 70 ..... Ok 1 Group Id: [13] Rec: 187 Len: 70 ..... Ok 1 Group Id: [13] Rec: 188 Len: 70 ..... Ok 1 Group Id: [13] Rec: 189 Len: 70 ..... Ok 1 Group Id: [13] Rec: 190 Len: 70 ..... Ok 1 Group Id: [13] Rec: 191 Len: 70 ..... Ok 1 Group Id: [13] Rec: 192 Len: 70 ..... Ok 1 Group Id: [13] Rec: 193 Len: 70 ..... Ok 1 Group Id: [13] Rec: 194 Len: 70 ..... Ok 1 Group Id: [13] Rec: 195 Len: 70 ..... Ok 1 Group Id: [13] Rec: 196 Len: 70 ..... Ok 1 Group Id: [13] Rec: 197 Len: 70 ..... Ok 1 Group Id: [13] Rec: 198 Len: 70 ..... Ok 1 Group Id: [13] Rec: 199 Len: 70 ..... Ok 1 Group Id: [13] Rec: 200 Len: 70 ..... Ok 1 Group Id: [13] Rec: 201 Len: 70 ..... Ok 1 Group Id: [13] Rec: 202 Len: 70 ..... Ok 1 Group Id: [13] Rec: 203 Len: 70 ..... Ok 1 Group Id: [13] Rec: 204 Len: 70 ..... Ok 1 Group Id: [13] Rec: 205 Len: 70 ..... Ok 1 Group Id: [13] Rec: 206 Len: 70 ..... Ok 1 Group Id: [13] Rec: 207 Len: 70 ..... Ok 1 Group Id: [13] Rec: 208 Len: 70 ..... Ok 1 Group Id: [13] Rec: 209 Len: 70 ..... Ok 1 Group Id: [13] Rec: 210 Len: 70 ..... Ok 1 Group Id: [13] Rec: 211 Len: 70 ..... Ok 1 Group Id: [13] Rec: 212 Len: 70 ..... Ok 1 Group Id: [13] Rec: 213 Len: 70 ..... Ok 1 Group Id: [13] Rec: 214 Len: 70 ..... Ok 1 Group Id: [13] Rec: 215 Len: 70 ..... Ok 1 Group Id: [13] Rec: 216 Len: 70 ..... Ok 1 Group Id: [13] Rec: 217 Len: 70 ..... Ok 1 Group Id: [13] Rec: 218 Len: 70 ..... Ok 1 Group Id: [13] Rec: 219 Len: 70 ..... Ok 1 Group Id: [13] Rec: 220 Len: 70 ..... Ok 1 Group Id: [13] Rec: 221 Len: 70 ..... Ok 1 Group Id: [13] Rec: 222 Len: 70 ..... Ok 1 Group Id: [13] Rec: 223 Len: 70 ..... Ok 1 Group Id: [13] Rec: 224 Len: 70 ..... Ok 1 Group Id: [13] Rec: 225 Len: 70 ..... Ok 1 Group Id: [13] Rec: 226 Len: 70 ..... Ok 1 Group Id: [13] Rec: 227 Len: 70 ..... Ok 1 Group Id: [13] Rec: 228 Len: 70 ..... Ok 1 Group Id: [13] Rec: 229 Len: 70 ..... Ok 1 Group Id: [13] Rec: 230 Len: 70 ..... Ok 1 Group Id: [13] Rec: 231 Len: 70 ..... Ok 1 Group Id: [13] Rec: 232 Len: 70 ..... Ok 1 Group Id: [13] Rec: 233 Len: 70 ..... Ok 1 Group Id: [13] Rec: 234 Len: 70 ..... Ok 1 Group Id: [13] Rec: 235 Len: 70 ..... Ok 1 Group Id: [13] Rec: 236 Len: 70 ..... Ok 1 Group Id: [13] Rec: 237 Len: 70 ..... Ok 1 Group Id: [13] Rec: 238 Len: 70 ..... Ok 1 Group Id: [13] Rec: 239 Len: 70 ..... Ok 1 Group Id: [13] Rec: 240 Len: 70 ..... Ok 1 Group Id: [13] Rec: 241 Len: 70 ..... Ok 1 Group Id: [13] Rec: 242 Len: 70 ..... Ok 1 Group Id: [13] Rec: 243 Len: 70 ..... Ok 1 Group Id: [13] Rec: 244 Len: 70 ..... Ok 1 Group Id: [13] Rec: 245 Len: 70 ..... Ok 1 Group Id: [13] Rec: 246 Len: 70 ..... Ok 1 Group Id: [13] Rec: 247 Len: 70 ..... Ok 1 Group Id: [13] Rec: 248 Len: 70 ..... Ok 1 Group Id: [13] Rec: 249 Len: 70 ..... Ok 1 Group Id: [14] Rec: 0 Len: 87 ..... Ok 1 Group Id: [14] Rec: 1 Len: 87 ..... Ok 1 Group Id: [14] Rec: 2 Len: 87 ..... Ok 1 Group Id: [14] Rec: 3 Len: 87 ..... Ok 1 Group Id: [14] Rec: 4 Len: 87 ..... Ok 1 Group Id: [14] Rec: 5 Len: 87 ..... Ok 1 Group Id: [14] Rec: 6 Len: 87 ..... Ok 1 Group Id: [14] Rec: 7 Len: 87 ..... Ok 1 Group Id: [14] Rec: 8 Len: 87 ..... Ok 1 Group Id: [14] Rec: 9 Len: 87 ..... Ok 1 Group Id: [14] Rec: 10 Len: 87 ..... Ok 1 Group Id: [14] Rec: 11 Len: 87 ..... Ok 1 Group Id: [14] Rec: 12 Len: 87 ..... Ok 1 Group Id: [14] Rec: 13 Len: 87 ..... Ok 1 Group Id: [14] Rec: 14 Len: 87 ..... Ok 1 Group Id: [14] Rec: 15 Len: 87 ..... Ok 1 Group Id: [14] Rec: 16 Len: 87 ..... Ok 1 Group Id: [14] Rec: 17 Len: 87 ..... Ok 1 Group Id: [14] Rec: 18 Len: 87 ..... Ok 1 Group Id: [14] Rec: 19 Len: 87 ..... Ok 1 Group Id: [15] Rec: 0 Len: 87 ..... Ok 1 Group Id: [15] Rec: 1 Len: 87 ..... Ok 1 Group Id: [15] Rec: 2 Len: 87 ..... Ok 1 Group Id: [15] Rec: 3 Len: 87 ..... Ok 1 Group Id: [15] Rec: 4 Len: 87 ..... Ok 1 Group Id: [15] Rec: 5 Len: 87 ..... Ok 1 Group Id: [15] Rec: 6 Len: 87 ..... Ok 1 Group Id: [15] Rec: 7 Len: 87 ..... Ok 1 Group Id: [15] Rec: 8 Len: 87 ..... Ok 1 Group Id: [15] Rec: 9 Len: 87 ..... Ok 1 Group Id: [15] Rec: 10 Len: 87 ..... Ok 1 Group Id: [15] Rec: 11 Len: 87 ..... Ok 1 Group Id: [15] Rec: 12 Len: 87 ..... Ok 1 Group Id: [15] Rec: 13 Len: 87 ..... Ok 1 Group Id: [15] Rec: 14 Len: 87 ..... Ok 1 Group Id: [15] Rec: 15 Len: 87 ..... Ok 1 Group Id: [15] Rec: 16 Len: 87 ..... Ok 1 Group Id: [15] Rec: 17 Len: 87 ..... Ok 1 Group Id: [15] Rec: 18 Len: 87 ..... Ok 1 Group Id: [15] Rec: 19 Len: 87 ..... Ok 1 Group Id: [16] Rec: 0 Len: 87 ..... Ok 1 Group Id: [16] Rec: 1 Len: 87 ..... Ok 1 Group Id: [16] Rec: 2 Len: 87 ..... Ok 1 Group Id: [16] Rec: 3 Len: 87 ..... Ok 1 Group Id: [16] Rec: 4 Len: 87 ..... Ok 1 Group Id: [16] Rec: 5 Len: 87 ..... Ok 1 Group Id: [16] Rec: 6 Len: 87 ..... Ok 1 Group Id: [16] Rec: 7 Len: 87 ..... Ok 1 Group Id: [16] Rec: 8 Len: 87 ..... Ok 1 Group Id: [16] Rec: 9 Len: 87 ..... Ok 1 Group Id: [16] Rec: 10 Len: 87 ..... Ok 1 Group Id: [16] Rec: 11 Len: 87 ..... Ok 1 Group Id: [16] Rec: 12 Len: 87 ..... Ok 1 Group Id: [16] Rec: 13 Len: 87 ..... Ok 1 Group Id: [16] Rec: 14 Len: 87 ..... Ok 1 Group Id: [16] Rec: 15 Len: 87 ..... Ok 1 Group Id: [16] Rec: 16 Len: 87 ..... Ok 1 Group Id: [16] Rec: 17 Len: 87 ..... Ok 1 Group Id: [16] Rec: 18 Len: 87 ..... Ok 1 Group Id: [16] Rec: 19 Len: 87 ..... Ok 1 Group Id: [17] Rec: 0 Len: 42 ..... Ok 1 Group Id: [17] Rec: 1 Len: 42 ..... Ok 1 Group Id: [17] Rec: 2 Len: 42 ..... Ok 1 Group Id: [18] Rec: 0 Len: 2056 ... Fail Write PM Failed Init Normal Mode Ok, Time: 00:03 PM File: Rm-961_355739060298043.pm Group Id: [4] Rec: 0 Len: 1 ...... Ok 1 Group Id: [4] Rec: 1 Len: 20 ..... Ok 1 Group Id: [4] Rec: 2 Len: 22 ..... Ok 1 Group Id: [4] Rec: 3 Len: 10 ..... Ok 1 Group Id: [4] Rec: 4 Len: 8 ...... Ok 1 Group Id: [4] Rec: 5 Len: 8 ...... Ok 1 Group Id: [4] Rec: 6 Len: 8 ...... Ok 1 Group Id: [4] Rec: 9 Len: 5 ...... Ok 1 Group Id: [5] Rec: 0 Len: 78 ..... Ok 1 Group Id: [11] Rec: 0 Len: 4 ...... Ok 1 Group Id: [11] Rec: 1 Len: 4 ...... Ok 1 Group Id: [11] Rec: 2 Len: 4 ...... Ok 1 Group Id: [11] Rec: 3 Len: 4 ...... Ok 1 Group Id: [11] Rec: 4 Len: 1 ...... Ok 1 Group Id: [11] Rec: 5 Len: 6 ...... Ok 1 Group Id: [11] Rec: 6 Len: 4 ...... Ok 1 Group Id: [11] Rec: 7 Len: 4 ...... Ok 1 Group Id: [11] Rec: 8 Len: 2 ...... Ok 1 Group Id: [11] Rec: 9 Len: 1 ...... Ok 1 Group Id: [11] Rec: 10 Len: 4 ...... Ok 1 Group Id: [11] Rec: 11 Len: 14 ..... Ok 1 Group Id: [11] Rec: 12 Len: 2 ...... Ok 1 Group Id: [11] Rec: 13 Len: 1 ...... Ok 1 Group Id: [11] Rec: 14 Len: 1 ...... Ok 1 Group Id: [11] Rec: 15 Len: 1 ...... Ok 1 Group Id: [11] Rec: 16 Len: 8 ...... Ok 1 Group Id: [11] Rec: 17 Len: 1 ...... Ok 1 Group Id: [11] Rec: 18 Len: 1 ...... Ok 1 Group Id: [11] Rec: 19 Len: 4 ...... Ok 1 Group Id: [11] Rec: 20 Len: 2 ...... Ok 1 Group Id: [11] Rec: 21 Len: 2 ...... Ok 1 Group Id: [11] Rec: 22 Len: 1 ...... Ok 1 Group Id: [11] Rec: 23 Len: 8 ...... Ok 1 Group Id: [11] Rec: 24 Len: 1 ...... Ok 1 Group Id: [11] Rec: 25 Len: 2 ...... Ok 1 Group Id: [11] Rec: 26 Len: 2 ...... Ok 1 Group Id: [11] Rec: 27 Len: 2 ...... Ok 1 Group Id: [11] Rec: 28 Len: 2 ...... Ok 1 Group Id: [11] Rec: 29 Len: 2 ...... Ok 1 Group Id: [11] Rec: 30 Len: 4 ...... Ok 1 Group Id: [11] Rec: 31 Len: 4 ...... Ok 1 Group Id: [11] Rec: 32 Len: 4 ...... Ok 1 Group Id: [11] Rec: 33 Len: 4 ...... Ok 1 Group Id: [11] Rec: 34 Len: 4 ...... Ok 1 Group Id: [11] Rec: 35 Len: 4 ...... Ok 1 Group Id: [11] Rec: 36 Len: 4 ...... Ok 1 Group Id: [11] Rec: 37 Len: 16 ..... Ok 1 Group Id: [11] Rec: 38 Len: 4 ...... Ok 1 Group Id: [11] Rec: 39 Len: 2 ...... Ok 1 Group Id: [11] Rec: 40 Len: 4 ...... Ok 1 Group Id: [11] Rec: 41 Len: 2 ...... Ok 1 Group Id: [11] Rec: 42 Len: 2 ...... Ok 1 Group Id: [11] Rec: 43 Len: 1 ...... Ok 1 Group Id: [11] Rec: 44 Len: 1 ...... Ok 1 Group Id: [11] Rec: 45 Len: 4 ...... Ok 1 Group Id: [11] Rec: 46 Len: 4 ...... Ok 1 Group Id: [11] Rec: 47 Len: 4 ...... Ok 1 Group Id: [11] Rec: 48 Len: 4 ...... Ok 1 Group Id: [11] Rec: 49 Len: 4 ...... Ok 1 Group Id: [11] Rec: 50 Len: 4 ...... Ok 1 Group Id: [11] Rec: 51 Len: 4 ...... Ok 1 Group Id: [11] Rec: 52 Len: 4 ...... Ok 1 Group Id: [11] Rec: 53 Len: 4 ...... Ok 1 Group Id: [11] Rec: 54 Len: 4 ...... Ok 1 Group Id: [11] Rec: 55 Len: 4 ...... Ok 1 Group Id: [11] Rec: 56 Len: 4 ...... Ok 1 Group Id: [11] Rec: 57 Len: 4 ...... Ok 1 Group Id: [11] Rec: 58 Len: 4 ...... Ok 1 Group Id: [11] Rec: 59 Len: 4 ...... Ok 1 Group Id: [11] Rec: 60 Len: 4 ...... Ok 1 Group Id: [11] Rec: 61 Len: 4 ...... Ok 1 Group Id: [11] Rec: 62 Len: 4 ...... Ok 1 Group Id: [11] Rec: 63 Len: 4 ...... Ok 1 Group Id: [11] Rec: 64 Len: 2 ...... Ok 1 Group Id: [11] Rec: 65 Len: 4 ...... Ok 1 Group Id: [11] Rec: 66 Len: 2 ...... Ok 1 Group Id: [11] Rec: 67 Len: 1 ...... Ok 1 Group Id: [11] Rec: 68 Len: 16 ..... Ok 1 Group Id: [11] Rec: 69 Len: 4 ...... Ok 1 Group Id: [11] Rec: 70 Len: 2 ...... Ok 1 Group Id: [11] Rec: 71 Len: 2 ...... Ok 1 Group Id: [11] Rec: 72 Len: 2 ...... Ok 1 Group Id: [11] Rec: 73 Len: 2 ...... Ok 1 Group Id: [11] Rec: 74 Len: 2 ...... Ok 1 Group Id: [11] Rec: 75 Len: 2 ...... Ok 1 Group Id: [11] Rec: 76 Len: 2 ...... Ok 1 Group Id: [11] Rec: 77 Len: 2 ...... Ok 1 Group Id: [11] Rec: 78 Len: 2 ...... Ok 1 Group Id: [11] Rec: 79 Len: 2 ...... Ok 1 Group Id: [11] Rec: 80 Len: 2 ...... Ok 1 Group Id: [11] Rec: 81 Len: 2 ...... Ok 1 Group Id: [11] Rec: 82 Len: 2 ...... Ok 1 Group Id: [11] Rec: 83 Len: 2 ...... Ok 1 Group Id: [11] Rec: 84 Len: 2 ...... Ok 1 Group Id: [11] Rec: 85 Len: 2 ...... Ok 1 Group Id: [11] Rec: 86 Len: 2 ...... Ok 1 Group Id: [11] Rec: 87 Len: 2 ...... Ok 1 Group Id: [11] Rec: 88 Len: 2 ...... Ok 1 Group Id: [11] Rec: 89 Len: 2 ...... Ok 1 Group Id: [11] Rec: 90 Len: 2 ...... Ok 1 Group Id: [11] Rec: 91 Len: 2 ...... Ok 1 Group Id: [11] Rec: 92 Len: 2 ...... Ok 1 Group Id: [11] Rec: 93 Len: 2 ...... Ok 1 Group Id: [11] Rec: 94 Len: 2 ...... Ok 1 Group Id: [11] Rec: 95 Len: 2 ...... Ok 1 Group Id: [13] Rec: 0 Len: 70 ..... Ok 1 Group Id: [13] Rec: 1 Len: 70 ..... Ok 1 Group Id: [13] Rec: 2 Len: 70 ..... Ok 1 Group Id: [13] Rec: 3 Len: 70 ..... Ok 1 Group Id: [13] Rec: 4 Len: 70 ..... Ok 1 Group Id: [13] Rec: 5 Len: 70 ..... Ok 1 Group Id: [13] Rec: 6 Len: 70 ..... Ok 1 Group Id: [13] Rec: 7 Len: 70 ..... Ok 1 Group Id: [13] Rec: 8 Len: 70 ..... Ok 1 Group Id: [13] Rec: 9 Len: 70 ..... Ok 1 Group Id: [13] Rec: 10 Len: 70 ..... Ok 1 Group Id: [13] Rec: 11 Len: 70 ..... Ok 1 Group Id: [13] Rec: 12 Len: 70 ..... Ok 1 Group Id: [13] Rec: 13 Len: 70 ..... Ok 1 Group Id: [13] Rec: 14 Len: 70 ..... Ok 1 Group Id: [13] Rec: 15 Len: 70 ..... Ok 1 Group Id: [13] Rec: 16 Len: 70 ..... Ok 1 Group Id: [13] Rec: 17 Len: 70 ..... Ok 1 Group Id: [13] Rec: 18 Len: 70 ..... Ok 1 Group Id: [13] Rec: 19 Len: 70 ..... Ok 1 Group Id: [13] Rec: 20 Len: 70 ..... Ok 1 Group Id: [13] Rec: 21 Len: 70 ..... Ok 1 Group Id: [13] Rec: 22 Len: 70 ..... Ok 1 Group Id: [13] Rec: 23 Len: 70 ..... Ok 1 Group Id: [13] Rec: 24 Len: 70 ..... Ok 1 Group Id: [13] Rec: 25 Len: 70 ..... Ok 1 Group Id: [13] Rec: 26 Len: 70 ..... Ok 1 Group Id: [13] Rec: 27 Len: 70 ..... Ok 1 Group Id: [13] Rec: 28 Len: 70 ..... Ok 1 Group Id: [13] Rec: 29 Len: 70 ..... Ok 1 Group Id: [13] Rec: 30 Len: 70 ..... Ok 1 Group Id: [13] Rec: 31 Len: 70 ..... Ok 1 Group Id: [13] Rec: 32 Len: 70 ..... Ok 1 Group Id: [13] Rec: 33 Len: 70 ..... Ok 1 Group Id: [13] Rec: 34 Len: 70 ..... Ok 1 Group Id: [13] Rec: 35 Len: 70 ..... Ok 1 Group Id: [13] Rec: 36 Len: 70 ..... Ok 1 Group Id: [13] Rec: 37 Len: 70 ..... Ok 1 Group Id: [13] Rec: 38 Len: 70 ..... Ok 1 Group Id: [13] Rec: 39 Len: 70 ..... Ok 1 Group Id: [13] Rec: 40 Len: 70 ..... Ok 1 Group Id: [13] Rec: 41 Len: 70 ..... Ok 1 Group Id: [13] Rec: 42 Len: 70 ..... Ok 1 Group Id: [13] Rec: 43 Len: 70 ..... Ok 1 Group Id: [13] Rec: 44 Len: 70 ..... Ok 1 Group Id: [13] Rec: 45 Len: 70 ..... Ok 1 Group Id: [13] Rec: 46 Len: 70 ..... Ok 1 Group Id: [13] Rec: 47 Len: 70 ..... Ok 1 Group Id: [13] Rec: 48 Len: 70 ..... Ok 1 Group Id: [13] Rec: 49 Len: 70 ..... Ok 1 Group Id: [13] Rec: 50 Len: 70 ..... Ok 1 Group Id: [13] Rec: 51 Len: 70 ..... Ok 1 Group Id: [13] Rec: 52 Len: 70 ..... Ok 1 Group Id: [13] Rec: 53 Len: 70 ..... Ok 1 Group Id: [13] Rec: 54 Len: 70 ..... Ok 1 Group Id: [13] Rec: 55 Len: 70 ..... Ok 1 Group Id: [13] Rec: 56 Len: 70 ..... Ok 1 Group Id: [13] Rec: 57 Len: 70 ..... Ok 1 Group Id: [13] Rec: 58 Len: 70 ..... Ok 1 Group Id: [13] Rec: 59 Len: 70 ..... Ok 1 Group Id: [13] Rec: 60 Len: 70 ..... Ok 1 Group Id: [13] Rec: 61 Len: 70 ..... Ok 1 Group Id: [13] Rec: 62 Len: 70 ..... Ok 1 Group Id: [13] Rec: 63 Len: 70 ..... Ok 1 Group Id: [13] Rec: 64 Len: 70 ..... Ok 1 Group Id: [13] Rec: 65 Len: 70 ..... Ok 1 Group Id: [13] Rec: 66 Len: 70 ..... Ok 1 Group Id: [13] Rec: 67 Len: 70 ..... Ok 1 Group Id: [13] Rec: 68 Len: 70 ..... Ok 1 Group Id: [13] Rec: 69 Len: 70 ..... Ok 1 Group Id: [13] Rec: 70 Len: 70 ..... Ok 1 Group Id: [13] Rec: 71 Len: 70 ..... Ok 1 Group Id: [13] Rec: 72 Len: 70 ..... Ok 1 Group Id: [13] Rec: 73 Len: 70 ..... Ok 1 Group Id: [13] Rec: 74 Len: 70 ..... Ok 1 Group Id: [13] Rec: 75 Len: 70 ..... Ok 1 Group Id: [13] Rec: 76 Len: 70 ..... Ok 1 Group Id: [13] Rec: 77 Len: 70 ..... Ok 1 Group Id: [13] Rec: 78 Len: 70 ..... Ok 1 Group Id: [13] Rec: 79 Len: 70 ..... Ok 1 Group Id: [13] Rec: 80 Len: 70 ..... Ok 1 Group Id: [13] Rec: 81 Len: 70 ..... Ok 1 Group Id: [13] Rec: 82 Len: 70 ..... Ok 1 Group Id: [13] Rec: 83 Len: 70 ..... Ok 1 Group Id: [13] Rec: 84 Len: 70 ..... Ok 1 Group Id: [13] Rec: 85 Len: 70 ..... Ok 1 Group Id: [13] Rec: 86 Len: 70 ..... Ok 1 Group Id: [13] Rec: 87 Len: 70 ..... Ok 1 Group Id: [13] Rec: 88 Len: 70 ..... Ok 1 Group Id: [13] Rec: 89 Len: 70 ..... Ok 1 Group Id: [13] Rec: 90 Len: 70 ..... Ok 1 Group Id: [13] Rec: 91 Len: 70 ..... Ok 1 Group Id: [13] Rec: 92 Len: 70 ..... Ok 1 Group Id: [13] Rec: 93 Len: 70 ..... Ok 1 Group Id: [13] Rec: 94 Len: 70 ..... Ok 1 Group Id: [13] Rec: 95 Len: 70 ..... Ok 1 Group Id: [13] Rec: 96 Len: 70 ..... Ok 1 Group Id: [13] Rec: 97 Len: 70 ..... Ok 1 Group Id: [13] Rec: 98 Len: 70 ..... Ok 1 Group Id: [13] Rec: 99 Len: 70 ..... Ok 1 Group Id: [13] Rec: 100 Len: 70 ..... Ok 1 Group Id: [13] Rec: 101 Len: 70 ..... Ok 1 Group Id: [13] Rec: 102 Len: 70 ..... Ok 1 Group Id: [13] Rec: 103 Len: 70 ..... Ok 1 Group Id: [13] Rec: 104 Len: 70 ..... Ok 1 Group Id: [13] Rec: 105 Len: 70 ..... Ok 1 Group Id: [13] Rec: 106 Len: 70 ..... Ok 1 Group Id: [13] Rec: 107 Len: 70 ..... Ok 1 Group Id: [13] Rec: 108 Len: 70 ..... Ok 1 Group Id: [13] Rec: 109 Len: 70 ..... Ok 1 Group Id: [13] Rec: 110 Len: 70 ..... Ok 1 Group Id: [13] Rec: 111 Len: 70 ..... Ok 1 Group Id: [13] Rec: 112 Len: 70 ..... Ok 1 Group Id: [13] Rec: 113 Len: 70 ..... Ok 1 Group Id: [13] Rec: 114 Len: 70 ..... Ok 1 Group Id: [13] Rec: 115 Len: 70 ..... Ok 1 Group Id: [13] Rec: 116 Len: 70 ..... Ok 1 Group Id: [13] Rec: 117 Len: 70 ..... Ok 1 Group Id: [13] Rec: 118 Len: 70 ..... Ok 1 Group Id: [13] Rec: 119 Len: 70 ..... Ok 1 Group Id: [13] Rec: 120 Len: 70 ..... Ok 1 Group Id: [13] Rec: 121 Len: 70 ..... Ok 1 Group Id: [13] Rec: 122 Len: 70 ..... Ok 1 Group Id: [13] Rec: 123 Len: 70 ..... Ok 1 Group Id: [13] Rec: 124 Len: 70 ..... Ok 1 Group Id: [13] Rec: 125 Len: 70 ..... Ok 1 Group Id: [13] Rec: 126 Len: 70 ..... Ok 1 Group Id: [13] Rec: 127 Len: 70 ..... Ok 1 Group Id: [13] Rec: 128 Len: 70 ..... Ok 1 Group Id: [13] Rec: 129 Len: 70 ..... Ok 1 Group Id: [13] Rec: 130 Len: 70 ..... Ok 1 Group Id: [13] Rec: 131 Len: 70 ..... Ok 1 Group Id: [13] Rec: 132 Len: 70 ..... Ok 1 Group Id: [13] Rec: 133 Len: 70 ..... Ok 1 Group Id: [13] Rec: 134 Len: 70 ..... Ok 1 Group Id: [13] Rec: 135 Len: 70 ..... Ok 1 Group Id: [13] Rec: 136 Len: 70 ..... Ok 1 Group Id: [13] Rec: 137 Len: 70 ..... Ok 1 Group Id: [13] Rec: 138 Len: 70 ..... Ok 1 Group Id: [13] Rec: 139 Len: 70 ..... Ok 1 Group Id: [13] Rec: 140 Len: 70 ..... Ok 1 Group Id: [13] Rec: 141 Len: 70 ..... Ok 1 Group Id: [13] Rec: 142 Len: 70 ..... Ok 1 Group Id: [13] Rec: 143 Len: 70 ..... Ok 1 Group Id: [13] Rec: 144 Len: 70 ..... Ok 1 Group Id: [13] Rec: 145 Len: 70 ..... Ok 1 Group Id: [13] Rec: 146 Len: 70 ..... Ok 1 Group Id: [13] Rec: 147 Len: 70 ..... Ok 1 Group Id: [13] Rec: 148 Len: 70 ..... Ok 1 Group Id: [13] Rec: 149 Len: 70 ..... Ok 1 Group Id: [13] Rec: 150 Len: 70 ..... Ok 1 Group Id: [13] Rec: 151 Len: 70 ..... Ok 1 Group Id: [13] Rec: 152 Len: 70 ..... Ok 1 Group Id: [13] Rec: 153 Len: 70 ..... Ok 1 Group Id: [13] Rec: 154 Len: 70 ..... Ok 1 Group Id: [13] Rec: 155 Len: 70 ..... Ok 1 Group Id: [13] Rec: 156 Len: 70 ..... Ok 1 Group Id: [13] Rec: 157 Len: 70 ..... Ok 1 Group Id: [13] Rec: 158 Len: 70 ..... Ok 1 Group Id: [13] Rec: 159 Len: 70 ..... Ok 1 Group Id: [13] Rec: 160 Len: 70 ..... Ok 1 Group Id: [13] Rec: 161 Len: 70 ..... Ok 1 Group Id: [13] Rec: 162 Len: 70 ..... Ok 1 Group Id: [13] Rec: 163 Len: 70 ..... Ok 1 Group Id: [13] Rec: 164 Len: 70 ..... Ok 1 Group Id: [13] Rec: 165 Len: 70 ..... Ok 1 Group Id: [13] Rec: 166 Len: 70 ..... Ok 1 Group Id: [13] Rec: 167 Len: 70 ..... Ok 1 Group Id: [13] Rec: 168 Len: 70 ..... Ok 1 Group Id: [13] Rec: 169 Len: 70 ..... Ok 1 Group Id: [13] Rec: 170 Len: 70 ..... Ok 1 Group Id: [13] Rec: 171 Len: 70 ..... Ok 1 Group Id: [13] Rec: 172 Len: 70 ..... Ok 1 Group Id: [13] Rec: 173 Len: 70 ..... Ok 1 Group Id: [13] Rec: 174 Len: 70 ..... Ok 1 Group Id: [13] Rec: 175 Len: 70 ..... Ok 1 Group Id: [13] Rec: 176 Len: 70 ..... Ok 1 Group Id: [13] Rec: 177 Len: 70 ..... Ok 1 Group Id: [13] Rec: 178 Len: 70 ..... Ok 1 Group Id: [13] Rec: 179 Len: 70 ..... Ok 1 Group Id: [13] Rec: 180 Len: 70 ..... Ok 1 Group Id: [13] Rec: 181 Len: 70 ..... Ok 1 Group Id: [13] Rec: 182 Len: 70 ..... Ok 1 Group Id: [13] Rec: 183 Len: 70 ..... Ok 1 Group Id: [13] Rec: 184 Len: 70 ..... Ok 1 Group Id: [13] Rec: 185 Len: 70 ..... Ok 1 Group Id: [13] Rec: 186 Len: 70 ..... Ok 1 Group Id: [13] Rec: 187 Len: 70 ..... Ok 1 Group Id: [13] Rec: 188 Len: 70 ..... Ok 1 Group Id: [13] Rec: 189 Len: 70 ..... Ok 1 Group Id: [13] Rec: 190 Len: 70 ..... Ok 1 Group Id: [13] Rec: 191 Len: 70 ..... Ok 1 Group Id: [13] Rec: 192 Len: 70 ..... Ok 1 Group Id: [13] Rec: 193 Len: 70 ..... Ok 1 Group Id: [13] Rec: 194 Len: 70 ..... Ok 1 Group Id: [13] Rec: 195 Len: 70 ..... Ok 1 Group Id: [13] Rec: 196 Len: 70 ..... Ok 1 Group Id: [13] Rec: 197 Len: 70 ..... Ok 1 Group Id: [13] Rec: 198 Len: 70 ..... Ok 1 Group Id: [13] Rec: 199 Len: 70 ..... Ok 1 Group Id: [13] Rec: 200 Len: 70 ..... Ok 1 Group Id: [13] Rec: 201 Len: 70 ..... Ok 1 Group Id: [13] Rec: 202 Len: 70 ..... Ok 1 Group Id: [13] Rec: 203 Len: 70 ..... Ok 1 Group Id: [13] Rec: 204 Len: 70 ..... Ok 1 Group Id: [13] Rec: 205 Len: 70 ..... Ok 1 Group Id: [13] Rec: 206 Len: 70 ..... Ok 1 Group Id: [13] Rec: 207 Len: 70 ..... Ok 1 Group Id: [13] Rec: 208 Len: 70 ..... Ok 1 Group Id: [13] Rec: 209 Len: 70 ..... Ok 1 Group Id: [13] Rec: 210 Len: 70 ..... Ok 1 Group Id: [13] Rec: 211 Len: 70 ..... Ok 1 Group Id: [13] Rec: 212 Len: 70 ..... Ok 1 Group Id: [13] Rec: 213 Len: 70 ..... Ok 1 Group Id: [13] Rec: 214 Len: 70 ..... Ok 1 Group Id: [13] Rec: 215 Len: 70 ..... Ok 1 Group Id: [13] Rec: 216 Len: 70 ..... Ok 1 Group Id: [13] Rec: 217 Len: 70 ..... Ok 1 Group Id: [13] Rec: 218 Len: 70 ..... Ok 1 Group Id: [13] Rec: 219 Len: 70 ..... Ok 1 Group Id: [13] Rec: 220 Len: 70 ..... Ok 1 Group Id: [13] Rec: 221 Len: 70 ..... Ok 1 Group Id: [13] Rec: 222 Len: 70 ..... Ok 1 Group Id: [13] Rec: 223 Len: 70 ..... Ok 1 Group Id: [13] Rec: 224 Len: 70 ..... Ok 1 Group Id: [13] Rec: 225 Len: 70 ..... Ok 1 Group Id: [13] Rec: 226 Len: 70 ..... Ok 1 Group Id: [13] Rec: 227 Len: 70 ..... Ok 1 Group Id: [13] Rec: 228 Len: 70 ..... Ok 1 Group Id: [13] Rec: 229 Len: 70 ..... Ok 1 Group Id: [13] Rec: 230 Len: 70 ..... Ok 1 Group Id: [13] Rec: 231 Len: 70 ..... Ok 1 Group Id: [13] Rec: 232 Len: 70 ..... Ok 1 Group Id: [13] Rec: 233 Len: 70 ..... Ok 1 Group Id: [13] Rec: 234 Len: 70 ..... Ok 1 Group Id: [13] Rec: 235 Len: 70 ..... Ok 1 Group Id: [13] Rec: 236 Len: 70 ..... Ok 1 Group Id: [13] Rec: 237 Len: 70 ..... Ok 1 Group Id: [13] Rec: 238 Len: 70 ..... Ok 1 Group Id: [13] Rec: 239 Len: 70 ..... Ok 1 Group Id: [13] Rec: 240 Len: 70 ..... Ok 1 Group Id: [13] Rec: 241 Len: 70 ..... Ok 1 Group Id: [13] Rec: 242 Len: 70 ..... Ok 1 Group Id: [13] Rec: 243 Len: 70 ..... Ok 1 Group Id: [13] Rec: 244 Len: 70 ..... Ok 1 Group Id: [13] Rec: 245 Len: 70 ..... Ok 1 Group Id: [13] Rec: 246 Len: 70 ..... Ok 1 Group Id: [13] Rec: 247 Len: 70 ..... Ok 1 Group Id: [13] Rec: 248 Len: 70 ..... Ok 1 Group Id: [13] Rec: 249 Len: 70 ..... Ok 1 Group Id: [14] Rec: 0 Len: 87 ..... Ok 1 Group Id: [14] Rec: 1 Len: 87 ..... Ok 1 Group Id: [14] Rec: 2 Len: 87 ..... Ok 1 Group Id: [14] Rec: 3 Len: 87 ..... Ok 1 Group Id: [14] Rec: 4 Len: 87 ..... Ok 1 Group Id: [14] Rec: 5 Len: 87 ..... Ok 1 Group Id: [14] Rec: 6 Len: 87 ..... Ok 1 Group Id: [14] Rec: 7 Len: 87 ..... Ok 1 Group Id: [14] Rec: 8 Len: 87 ..... Ok 1 Group Id: [14] Rec: 9 Len: 87 ..... Ok 1 Group Id: [14] Rec: 10 Len: 87 ..... Ok 1 Group Id: [14] Rec: 11 Len: 87 ..... Ok 1 Group Id: [14] Rec: 12 Len: 87 ..... Ok 1 Group Id: [14] Rec: 13 Len: 87 ..... Ok 1 Group Id: [14] Rec: 14 Len: 87 ..... Ok 1 Group Id: [14] Rec: 15 Len: 87 ..... Ok 1 Group Id: [14] Rec: 16 Len: 87 ..... Ok 1 Group Id: [14] Rec: 17 Len: 87 ..... Ok 1 Group Id: [14] Rec: 18 Len: 87 ..... Ok 1 Group Id: [14] Rec: 19 Len: 87 ..... Ok 1 Group Id: [15] Rec: 0 Len: 87 ..... Ok 1 Group Id: [15] Rec: 1 Len: 87 ..... Ok 1 Group Id: [15] Rec: 2 Len: 87 ..... Ok 1 Group Id: [15] Rec: 3 Len: 87 ..... Ok 1 Group Id: [15] Rec: 4 Len: 87 ..... Ok 1 Group Id: [15] Rec: 5 Len: 87 ..... Ok 1 Group Id: [15] Rec: 6 Len: 87 ..... Ok 1 Group Id: [15] Rec: 7 Len: 87 ..... Ok 1 Group Id: [15] Rec: 8 Len: 87 ..... Ok 1 Group Id: [15] Rec: 9 Len: 87 ..... Ok 1 Group Id: [15] Rec: 10 Len: 87 ..... Ok 1 Group Id: [15] Rec: 11 Len: 87 ..... Ok 1 Group Id: [15] Rec: 12 Len: 87 ..... Ok 1 Group Id: [15] Rec: 13 Len: 87 ..... Ok 1 Group Id: [15] Rec: 14 Len: 87 ..... Ok 1 Group Id: [15] Rec: 15 Len: 87 ..... Ok 1 Group Id: [15] Rec: 16 Len: 87 ..... Ok 1 Group Id: [15] Rec: 17 Len: 87 ..... Ok 1 Group Id: [15] Rec: 18 Len: 87 ..... Ok 1 Group Id: [15] Rec: 19 Len: 87 ..... Ok 1 Group Id: [16] Rec: 0 Len: 87 ..... Ok 1 Group Id: [16] Rec: 1 Len: 87 ..... Ok 1 Group Id: [16] Rec: 2 Len: 87 ..... Ok 1 Group Id: [16] Rec: 3 Len: 87 ..... Ok 1 Group Id: [16] Rec: 4 Len: 87 ..... Ok 1 Group Id: [16] Rec: 5 Len: 87 ..... Ok 1 Group Id: [16] Rec: 6 Len: 87 ..... Ok 1 Group Id: [16] Rec: 7 Len: 87 ..... Ok 1 Group Id: [16] Rec: 8 Len: 87 ..... Ok 1 Group Id: [16] Rec: 9 Len: 87 ..... Ok 1 Group Id: [16] Rec: 10 Len: 87 ..... Ok 1 Group Id: [16] Rec: 11 Len: 87 ..... Ok 1 Group Id: [16] Rec: 12 Len: 87 ..... Ok 1 Group Id: [16] Rec: 13 Len: 87 ..... Ok 1 Group Id: [16] Rec: 14 Len: 87 ..... Ok 1 Group Id: [16] Rec: 15 Len: 87 ..... Ok 1 Group Id: [16] Rec: 16 Len: 87 ..... Ok 1 Group Id: [16] Rec: 17 Len: 87 ..... Ok 1 Group Id: [16] Rec: 18 Len: 87 ..... Ok 1 Group Id: [16] Rec: 19 Len: 87 ..... Ok 1 Group Id: [17] Rec: 0 Len: 42 ..... Ok 1 Group Id: [17] Rec: 1 Len: 42 ..... Ok 1 Group Id: [17] Rec: 2 Len: 42 ..... Ok 1 Group Id: [18] Rec: 0 Len: 2056 ... Fail Group Id: [22] Rec: 0 Len: 196 .... Ok 2 Group Id: [26] Rec: 0 Len: 304 .... Ok 3 Group Id: [26] Rec: 1 Len: 304 .... Ok 3 Group Id: [26] Rec: 2 Len: 304 .... Ok 3 Group Id: [26] Rec: 3 Len: 304 .... Ok 3 Group Id: [26] Rec: 4 Len: 304 .... Ok 3 Group Id: [26] Rec: 5 Len: 304 .... Ok 3 Group Id: [26] Rec: 6 Len: 304 .... Ok 3 Group Id: [26] Rec: 7 Len: 304 .... Ok 3 Group Id: [26] Rec: 8 Len: 304 .... Ok 3 Group Id: [26] Rec: 9 Len: 304 .... Ok 3 Group Id: [26] Rec: 10 Len: 304 .... Ok 3 Group Id: [26] Rec: 11 Len: 304 .... Ok 3 Group Id: [26] Rec: 12 Len: 304 .... Ok 3 Group Id: [26] Rec: 13 Len: 304 .... Ok 3 Group Id: [26] Rec: 14 Len: 304 .... Ok 3 Group Id: [26] Rec: 15 Len: 304 .... Ok 3 Group Id: [26] Rec: 16 Len: 304 .... Ok 3 Group Id: [26] Rec: 17 Len: 304 .... Ok 3 Group Id: [26] Rec: 18 Len: 304 .... Ok 3 Group Id: [26] Rec: 19 Len: 304 .... Ok 3 Group Id: [26] Rec: 20 Len: 304 .... Ok 3 Group Id: [26] Rec: 21 Len: 304 .... Ok 3 Group Id: [26] Rec: 22 Len: 304 .... Ok 3 Group Id: [26] Rec: 23 Len: 304 .... Ok 3 Group Id: [26] Rec: 24 Len: 304 .... Ok 3 Group Id: [26] Rec: 25 Len: 304 .... Ok 3 Group Id: [26] Rec: 26 Len: 304 .... Ok 3 Group Id: [26] Rec: 27 Len: 304 .... Ok 3 Group Id: [26] Rec: 28 Len: 304 .... Ok 3 Group Id: [26] Rec: 29 Len: 304 .... Ok 3 Group Id: [27] Rec: 0 Len: 142 .... Ok 2 Group Id: [27] Rec: 1 Len: 142 .... Ok 2 Group Id: [27] Rec: 2 Len: 142 .... Ok 2 Group Id: [27] Rec: 3 Len: 142 .... Ok 2 Group Id: [27] Rec: 4 Len: 142 .... Ok 2 Group Id: [27] Rec: 5 Len: 142 .... Ok 2 Group Id: [27] Rec: 6 Len: 142 .... Ok 2 Group Id: [27] Rec: 7 Len: 142 .... Ok 2 Group Id: [28] Rec: 0 Len: 16 ..... Ok 1 Group Id: [28] Rec: 1 Len: 16 ..... Ok 1 Group Id: [28] Rec: 2 Len: 16 ..... Ok 1 Group Id: [28] Rec: 3 Len: 16 ..... Ok 1 Group Id: [28] Rec: 4 Len: 16 ..... Ok 1 Group Id: [28] Rec: 5 Len: 16 ..... Ok 1 Group Id: [28] Rec: 6 Len: 16 ..... Ok 1 Group Id: [28] Rec: 7 Len: 16 ..... Ok 1 Group Id: [29] Rec: 0 Len: 304 .... Ok 3 Group Id: [29] Rec: 1 Len: 304 .... Ok 3 Group Id: [29] Rec: 2 Len: 304 .... Ok 3 Group Id: [29] Rec: 3 Len: 304 .... Ok 3 Group Id: [29] Rec: 4 Len: 304 .... Ok 3 Group Id: [30] Rec: 0 Len: 138 .... Ok 2 Group Id: [32] Rec: 0 Len: 7 ...... Ok 1 Group Id: [32] Rec: 1 Len: 1 ...... Ok 1 Group Id: [32] Rec: 2 Len: 2 ...... Ok 1 Group Id: [33] Rec: 0 Len: 4 ...... Ok 1 Group Id: [33] Rec: 1 Len: 4 ...... Ok 1 Group Id: [33] Rec: 2 Len: 4 ...... Ok 1 Group Id: [33] Rec: 3 Len: 4 ...... Ok 1 Group Id: [33] Rec: 4 Len: 4 ...... Ok 1 Group Id: [33] Rec: 5 Len: 4 ...... Ok 1 Group Id: [33] Rec: 6 Len: 4 ...... Ok 1 Group Id: [33] Rec: 7 Len: 4 ...... Ok 1 Group Id: [33] Rec: 8 Len: 4 ...... Ok 1 Group Id: [33] Rec: 9 Len: 4 ...... Ok 1 Group Id: [33] Rec: 10 Len: 4 ...... Ok 1 Group Id: [33] Rec: 11 Len: 4 ...... Ok 1 Group Id: [33] Rec: 12 Len: 4 ...... Ok 1 Group Id: [33] Rec: 13 Len: 4 ...... Ok 1 Group Id: [33] Rec: 14 Len: 4 ...... Ok 1 Group Id: [33] Rec: 15 Len: 4 ...... Ok 1 Group Id: [33] Rec: 16 Len: 4 ...... Ok 1 Group Id: [33] Rec: 17 Len: 4 ...... Ok 1 Group Id: [33] Rec: 18 Len: 4 ...... Ok 1 Group Id: [33] Rec: 19 Len: 4 ...... Ok 1 Group Id: [34] Rec: 0 Len: 8 ...... Ok 1 Group Id: [34] Rec: 1 Len: 8 ...... Ok 1 Group Id: [34] Rec: 2 Len: 8 ...... Ok 1 Group Id: [34] Rec: 3 Len: 8 ...... Ok 1 Group Id: [34] Rec: 4 Len: 8 ...... Ok 1 Group Id: [34] Rec: 5 Len: 8 ...... Ok 1 Group Id: [34] Rec: 6 Len: 8 ...... Ok 1 Group Id: [34] Rec: 7 Len: 1 ...... Ok 1 Group Id: [35] Rec: 0 Len: 1 ...... Ok 1 Group Id: [36] Rec: 0 Len: 32 ..... Ok 1 Group Id: [36] Rec: 1 Len: 32 ..... Ok 1 Group Id: [36] Rec: 2 Len: 1 ...... Ok 1 Group Id: [36] Rec: 4 Len: 1 ...... Ok 1 Group Id: [36] Rec: 5 Len: 4 ...... Ok 1 Group Id: [36] Rec: 6 Len: 2 ...... Ok 1 Group Id: [36] Rec: 7 Len: 240 .... Ok 3 Group Id: [36] Rec: 8 Len: 2 ...... Ok 1 Group Id: [36] Rec: 9 Len: 4 ...... Ok 1 Group Id: [36] Rec: 10 Len: 6 ...... Ok 1 Group Id: [36] Rec: 11 Len: 6 ...... Ok 1 Group Id: [36] Rec: 12 Len: 17 ..... Ok 1 Group Id: [36] Rec: 13 Len: 60 ..... Ok 1 Group Id: [36] Rec: 14 Len: 38 ..... Ok 1 Group Id: [36] Rec: 15 Len: 38 ..... Ok 1 Group Id: [36] Rec: 16 Len: 16 ..... Ok 1 Group Id: [36] Rec: 17 Len: 6 ...... Ok 1 Group Id: [36] Rec: 19 Len: 501 .... Ok 5 Group Id: [36] Rec: 23 Len: 32 ..... Ok 1 Group Id: [36] Rec: 24 Len: 32 ..... Ok 1 Group Id: [36] Rec: 25 Len: 1 ...... Ok 1 Group Id: [36] Rec: 26 Len: 4 ...... Ok 1 Group Id: [36] Rec: 27 Len: 10 ..... Ok 1 Group Id: [36] Rec: 28 Len: 11 ..... Ok 1 Group Id: [37] Rec: 0 Len: 1 ...... Ok 1 Group Id: [38] Rec: 0 Len: 88 ..... Ok 1 Group Id: [38] Rec: 1 Len: 88 ..... Ok 1 Group Id: [38] Rec: 2 Len: 88 ..... Ok 1 Group Id: [38] Rec: 3 Len: 88 ..... Ok 1 Group Id: [38] Rec: 4 Len: 88 ..... Ok 1 Group Id: [38] Rec: 5 Len: 88 ..... Ok 1 Group Id: [38] Rec: 6 Len: 88 ..... Ok 1 Group Id: [38] Rec: 7 Len: 40 ..... Ok 1 Group Id: [38] Rec: 8 Len: 40 ..... Ok 1 Group Id: [38] Rec: 9 Len: 40 ..... Ok 1 Group Id: [38] Rec: 10 Len: 40 ..... Ok 1 Group Id: [38] Rec: 11 Len: 40 ..... Ok 1 Group Id: [38] Rec: 12 Len: 40 ..... Ok 1 Group Id: [39] Rec: 0 Len: 17 ..... Ok 1 Group Id: [40] Rec: 0 Len: 6 ...... Ok 1 Group Id: [40] Rec: 1 Len: 6 ...... Ok 1 Group Id: [40] Rec: 2 Len: 6 ...... Ok 1 Group Id: [40] Rec: 3 Len: 6 ...... Ok 1 Group Id: [40] Rec: 4 Len: 6 ...... Ok 1 Group Id: [40] Rec: 5 Len: 6 ...... Ok 1 Group Id: [40] Rec: 6 Len: 6 ...... Ok 1 Group Id: [40] Rec: 7 Len: 6 ...... Ok 1 Group Id: [41] Rec: 0 Len: 10 ..... Ok 1 Group Id: [41] Rec: 1 Len: 14 ..... Ok 1 Group Id: [41] Rec: 11 Len: 36 ..... Ok 1 Group Id: [50] Rec: 2 Len: 1 ...... Ok 1 Group Id: [50] Rec: 3 Len: 1 ...... Ok 1 Group Id: [51] Rec: 2 Len: 242 .... Ok 3 Group Id: [51] Rec: 3 Len: 630 .... Ok 6 Group Id: [51] Rec: 4 Len: 392 .... Ok 4 Group Id: [51] Rec: 6 Len: 242 .... Ok 3 Group Id: [51] Rec: 7 Len: 288 .... Ok 3 Group Id: [51] Rec: 8 Len: 472 .... Ok 5 Group Id: [51] Rec: 11 Len: 212 .... Ok 2 Group Id: [51] Rec: 12 Len: 396 .... Ok 4 Group Id: [51] Rec: 14 Len: 238 .... Ok 3 Group Id: [51] Rec: 16 Len: 396 .... Ok 4 Group Id: [51] Rec: 17 Len: 370 .... Ok 4 Group Id: [51] Rec: 24 Len: 368 .... Ok 4 Group Id: [51] Rec: 25 Len: 206 .... Ok 2 Group Id: [51] Rec: 26 Len: 224 .... Ok 2 Group Id: [51] Rec: 31 Len: 410 .... Ok 4 Group Id: [51] Rec: 33 Len: 300 .... Ok 3 Group Id: [51] Rec: 36 Len: 378 .... Ok 4 Group Id: [51] Rec: 38 Len: 264 .... Ok 3 Group Id: [51] Rec: 43 Len: 396 .... Ok 4 Group Id: [51] Rec: 44 Len: 390 .... Ok 4 Group Id: [57] Rec: 0 Len: 52 ..... Ok 1 Group Id: [61] Rec: 0 Len: 8 ...... Ok 1 Group Id: [62] Rec: 0 Len: 320 .... Ok 3 Group Id: [64] Rec: 0 Len: 2 ...... Ok 1 Group Id: [64] Rec: 1 Len: 4 ...... Ok 1 Group Id: [64] Rec: 2 Len: 32 ..... Ok 1 Group Id: [64] Rec: 3 Len: 32 ..... Ok 1 Group Id: [64] Rec: 4 Len: 32 ..... Ok 1 Group Id: [64] Rec: 5 Len: 32 ..... Ok 1 Group Id: [64] Rec: 6 Len: 32 ..... Ok 1 Group Id: [64] Rec: 7 Len: 32 ..... Ok 1 Group Id: [64] Rec: 8 Len: 32 ..... Ok 1 Group Id: [64] Rec: 9 Len: 32 ..... Ok 1 Group Id: [66] Rec: 0 Len: 4 ...... Ok 1 Group Id: [68] Rec: 0 Len: 16 ..... Ok 1 Group Id: [68] Rec: 1 Len: 16 ..... Ok 1 Group Id: [68] Rec: 2 Len: 16 ..... Ok 1 Group Id: [68] Rec: 3 Len: 16 ..... Ok 1 Group Id: [68] Rec: 4 Len: 16 ..... Ok 1 Group Id: [69] Rec: 2 Len: 142 .... Ok 2 Group Id: [69] Rec: 3 Len: 168 .... Ok 2 Group Id: [69] Rec: 4 Len: 142 .... Ok 2 Group Id: [69] Rec: 6 Len: 142 .... Ok 2 Group Id: [69] Rec: 7 Len: 142 .... Ok 2 Group Id: [69] Rec: 8 Len: 155 .... Ok 2 Group Id: [69] Rec: 11 Len: 129 .... Ok 2 Group Id: [69] Rec: 12 Len: 142 .... Ok 2 Group Id: [69] Rec: 14 Len: 129 .... Ok 2 Group Id: [69] Rec: 16 Len: 142 .... Ok 2 Group Id: [69] Rec: 17 Len: 142 .... Ok 2 Group Id: [69] Rec: 24 Len: 142 .... Ok 2 Group Id: [69] Rec: 25 Len: 129 .... Ok 2 Group Id: [69] Rec: 26 Len: 129 .... Ok 2 Group Id: [69] Rec: 31 Len: 142 .... Ok 2 Group Id: [69] Rec: 33 Len: 142 .... Ok 2 Group Id: [69] Rec: 36 Len: 142 .... Ok 2 Group Id: [69] Rec: 38 Len: 129 .... Ok 2 Group Id: [69] Rec: 43 Len: 142 .... Ok 2 Group Id: [69] Rec: 44 Len: 142 .... Ok 2 Group Id: [73] Rec: 0 Len: 175 .... Ok 2 Group Id: [73] Rec: 1 Len: 14 ..... Ok 1 Group Id: [73] Rec: 2 Len: 446 .... Ok 4 Group Id: [73] Rec: 3 Len: 292 .... Ok 3 Group Id: [73] Rec: 4 Len: 608 .... Ok 6 Group Id: [73] Rec: 5 Len: 688 .... Ok 6 Group Id: [74] Rec: 0 Len: 4 ...... Ok 1 Group Id: [80] Rec: 0 Len: 5110 ... Fail Group Id: [83] Rec: 0 Len: 6 ...... Ok 1 Group Id: [91] Rec: 0 Len: 196 .... Ok 2 Group Id: [91] Rec: 1 Len: 6 ...... Ok 1 Group Id: [93] Rec: 0 Len: 40 ..... Ok 1 Group Id: [93] Rec: 1 Len: 40 ..... Ok 1 Group Id: [93] Rec: 2 Len: 40 ..... Ok 1 Group Id: [93] Rec: 3 Len: 40 ..... Ok 1 Group Id: [93] Rec: 4 Len: 40 ..... Ok 1 Group Id: [94] Rec: 0 Len: 202 .... Ok 2 Group Id:[110] Rec: 0 Len: 30 ..... Ok 1 Group Id:[111] Rec: 0 Len: 8 ...... Ok 1 Group Id:[128] Rec: 0 Len: 32 ..... Ok 1 Group Id:[128] Rec: 1 Len: 32 ..... Ok 1 Group Id:[128] Rec: 2 Len: 32 ..... Ok 1 Group Id:[128] Rec: 3 Len: 32 ..... Ok 1 Group Id:[128] Rec: 4 Len: 32 ..... Ok 1 Group Id:[128] Rec: 5 Len: 32 ..... Ok 1 Group Id:[128] Rec: 6 Len: 32 ..... Ok 1 Group Id:[128] Rec: 7 Len: 32 ..... Ok 1 Group Id:[128] Rec: 8 Len: 32 ..... Ok 1 Group Id:[128] Rec: 9 Len: 32 ..... Ok 1 Group Id:[128] Rec: 10 Len: 32 ..... Ok 1 Group Id:[128] Rec: 11 Len: 32 ..... Ok 1 Group Id:[128] Rec: 12 Len: 32 ..... Ok 1 Group Id:[128] Rec: 13 Len: 32 ..... Ok 1 Group Id:[128] Rec: 14 Len: 32 ..... Ok 1 Group Id:[128] Rec: 15 Len: 32 ..... Ok 1 Group Id:[128] Rec: 16 Len: 32 ..... Ok 1 Group Id:[128] Rec: 17 Len: 32 ..... Ok 1 Group Id:[128] Rec: 18 Len: 32 ..... Ok 1 Group Id:[128] Rec: 19 Len: 32 ..... Ok 1 Group Id:[128] Rec: 20 Len: 32 ..... Ok 1 Group Id:[128] Rec: 21 Len: 32 ..... Ok 1 Group Id:[128] Rec: 22 Len: 32 ..... Ok 1 Group Id:[128] Rec: 23 Len: 32 ..... Ok 1 Group Id:[128] Rec: 24 Len: 32 ..... Ok 1 Group Id:[128] Rec: 25 Len: 32 ..... Ok 1 Group Id:[128] Rec: 26 Len: 32 ..... Ok 1 Group Id:[128] Rec: 27 Len: 32 ..... Ok 1 Group Id:[128] Rec: 28 Len: 32 ..... Ok 1 Group Id:[128] Rec: 29 Len: 32 ..... Ok 1 Group Id:[128] Rec: 30 Len: 32 ..... Ok 1 Group Id:[128] Rec: 31 Len: 32 ..... Ok 1 Group Id:[128] Rec: 32 Len: 32 ..... Ok 1 Group Id:[128] Rec: 33 Len: 32 ..... Ok 1 Group Id:[128] Rec: 34 Len: 32 ..... Ok 1 Group Id:[128] Rec: 35 Len: 32 ..... Ok 1 Group Id:[128] Rec: 36 Len: 32 ..... Ok 1 Group Id:[128] Rec: 37 Len: 32 ..... Ok 1 Group Id:[128] Rec: 38 Len: 32 ..... Ok 1 Group Id:[128] Rec: 39 Len: 32 ..... Ok 1 Group Id:[128] Rec: 40 Len: 32 ..... Ok 1 Group Id:[128] Rec: 41 Len: 32 ..... Ok 1 Group Id:[128] Rec: 42 Len: 32 ..... Ok 1 Group Id:[128] Rec: 43 Len: 10 ..... Ok 1 Group Id:[129] Rec: 0 Len: 32 ..... Ok 1 Group Id:[129] Rec: 1 Len: 32 ..... Ok 1 Group Id:[129] Rec: 2 Len: 32 ..... Ok 1 Group Id:[129] Rec: 3 Len: 32 ..... Ok 1 Group Id:[129] Rec: 4 Len: 32 ..... Ok 1 Group Id:[129] Rec: 5 Len: 32 ..... Ok 1 Group Id:[129] Rec: 6 Len: 32 ..... Ok 1 Group Id:[129] Rec: 7 Len: 32 ..... Ok 1 Group Id:[129] Rec: 8 Len: 32 ..... Ok 1 Group Id:[129] Rec: 9 Len: 32 ..... Ok 1 Group Id:[129] Rec: 10 Len: 32 ..... Ok 1 Group Id:[129] Rec: 11 Len: 32 ..... Ok 1 Group Id:[129] Rec: 12 Len: 32 ..... Ok 1 Group Id:[129] Rec: 13 Len: 32 ..... Ok 1 Group Id:[129] Rec: 14 Len: 32 ..... Ok 1 Group Id:[129] Rec: 15 Len: 32 ..... Ok 1 Group Id:[129] Rec: 16 Len: 32 ..... Ok 1 Group Id:[129] Rec: 17 Len: 32 ..... Ok 1 Group Id:[129] Rec: 18 Len: 32 ..... Ok 1 Group Id:[129] Rec: 19 Len: 32 ..... Ok 1 Group Id:[129] Rec: 20 Len: 32 ..... Ok 1 Group Id:[129] Rec: 21 Len: 32 ..... Ok 1 Group Id:[129] Rec: 22 Len: 32 ..... Ok 1 Group Id:[129] Rec: 23 Len: 32 ..... Ok 1 Group Id:[129] Rec: 24 Len: 32 ..... Ok 1 Group Id:[129] Rec: 25 Len: 32 ..... Ok 1 Group Id:[129] Rec: 26 Len: 32 ..... Ok 1 Group Id:[129] Rec: 27 Len: 32 ..... Ok 1 Group Id:[129] Rec: 28 Len: 32 ..... Ok 1 Group Id:[129] Rec: 29 Len: 32 ..... Ok 1 Group Id:[129] Rec: 30 Len: 32 ..... Ok 1 Group Id:[129] Rec: 31 Len: 32 ..... Ok 1 Group Id:[129] Rec: 32 Len: 32 ..... Ok 1 Group Id:[129] Rec: 33 Len: 32 ..... Ok 1 Group Id:[129] Rec: 34 Len: 32 ..... Ok 1 Group Id:[129] Rec: 35 Len: 32 ..... Ok 1 Group Id:[129] Rec: 36 Len: 32 ..... Ok 1 Group Id:[129] Rec: 37 Len: 32 ..... Ok 1 Group Id:[129] Rec: 38 Len: 32 ..... Ok 1 Group Id:[129] Rec: 39 Len: 32 ..... Ok 1 Group Id:[129] Rec: 40 Len: 32 ..... Ok 1 Group Id:[129] Rec: 41 Len: 32 ..... Ok 1 Group Id:[129] Rec: 42 Len: 32 ..... Ok 1 Group Id:[129] Rec: 43 Len: 32 ..... Ok 1 Group Id:[129] Rec: 44 Len: 32 ..... Ok 1 Group Id:[129] Rec: 45 Len: 32 ..... Ok 1 Group Id:[129] Rec: 46 Len: 32 ..... Ok 1 Group Id:[129] Rec: 47 Len: 32 ..... Ok 1 Group Id:[129] Rec: 48 Len: 32 ..... Ok 1 Group Id:[129] Rec: 49 Len: 32 ..... Ok 1 Group Id:[129] Rec: 50 Len: 32 ..... Ok 1 Group Id:[129] Rec: 51 Len: 32 ..... Ok 1 Group Id:[129] Rec: 52 Len: 32 ..... Ok 1 Group Id:[129] Rec: 53 Len: 20 ..... Ok 1 Group Id:[130] Rec: 0 Len: 32 ..... Ok 1 Group Id:[130] Rec: 1 Len: 32 ..... Ok 1 Group Id:[130] Rec: 2 Len: 32 ..... Ok 1 Group Id:[130] Rec: 3 Len: 32 ..... Ok 1 Group Id:[130] Rec: 4 Len: 32 ..... Ok 1 Group Id:[130] Rec: 5 Len: 32 ..... Ok 1 Group Id:[130] Rec: 6 Len: 32 ..... Ok 1 Group Id:[130] Rec: 7 Len: 32 ..... Ok 1 Group Id:[130] Rec: 8 Len: 32 ..... Ok 1 Group Id:[130] Rec: 9 Len: 32 ..... Ok 1 Group Id:[130] Rec: 10 Len: 32 ..... Ok 1 Group Id:[130] Rec: 11 Len: 32 ..... Ok 1 Group Id:[130] Rec: 12 Len: 32 ..... Ok 1 Group Id:[130] Rec: 13 Len: 32 ..... Ok 1 Group Id:[130] Rec: 14 Len: 32 ..... Ok 1 Group Id:[130] Rec: 15 Len: 32 ..... Ok 1 Group Id:[130] Rec: 16 Len: 32 ..... Ok 1 Group Id:[130] Rec: 17 Len: 32 ..... Ok 1 Group Id:[130] Rec: 18 Len: 32 ..... Ok 1 Group Id:[130] Rec: 19 Len: 32 ..... Ok 1 Group Id:[130] Rec: 20 Len: 32 ..... Ok 1 Group Id:[130] Rec: 21 Len: 32 ..... Ok 1 Group Id:[130] Rec: 22 Len: 32 ..... Ok 1 Group Id:[130] Rec: 23 Len: 32 ..... Ok 1 Group Id:[130] Rec: 24 Len: 32 ..... Ok 1 Group Id:[130] Rec: 25 Len: 32 ..... Ok 1 Group Id:[130] Rec: 26 Len: 32 ..... Ok 1 Group Id:[130] Rec: 27 Len: 32 ..... Ok 1 Group Id:[130] Rec: 28 Len: 32 ..... Ok 1 Group Id:[130] Rec: 29 Len: 32 ..... Ok 1 Group Id:[130] Rec: 30 Len: 32 ..... Ok 1 Group Id:[130] Rec: 31 Len: 32 ..... Ok 1 Group Id:[130] Rec: 32 Len: 32 ..... Ok 1 Group Id:[130] Rec: 33 Len: 32 ..... Ok 1 Group Id:[130] Rec: 34 Len: 32 ..... Ok 1 Group Id:[130] Rec: 35 Len: 32 ..... Ok 1 Group Id:[130] Rec: 36 Len: 32 ..... Ok 1 Group Id:[130] Rec: 37 Len: 32 ..... Ok 1 Group Id:[130] Rec: 38 Len: 32 ..... Ok 1 Group Id:[130] Rec: 39 Len: 32 ..... Ok 1 Group Id:[130] Rec: 40 Len: 32 ..... Ok 1 Group Id:[130] Rec: 41 Len: 32 ..... Ok 1 Group Id:[130] Rec: 42 Len: 32 ..... Ok 1 Group Id:[130] Rec: 43 Len: 32 ..... Ok 1 Group Id:[130] Rec: 44 Len: 32 ..... Ok 1 Group Id:[130] Rec: 45 Len: 32 ..... Ok 1 Group Id:[130] Rec: 46 Len: 32 ..... Ok 1 Group Id:[130] Rec: 47 Len: 32 ..... Ok 1 Group Id:[130] Rec: 48 Len: 32 ..... Ok 1 Group Id:[130] Rec: 49 Len: 32 ..... Ok 1 Group Id:[130] Rec: 50 Len: 32 ..... Ok 1 Group Id:[130] Rec: 51 Len: 32 ..... Ok 1 Group Id:[130] Rec: 52 Len: 32 ..... Ok 1 Group Id:[130] Rec: 53 Len: 32 ..... Ok 1 Group Id:[130] Rec: 54 Len: 32 ..... Ok 1 Group Id:[130] Rec: 55 Len: 32 ..... Ok 1 Group Id:[130] Rec: 56 Len: 32 ..... Ok 1 Group Id:[130] Rec: 57 Len: 32 ..... Ok 1 Group Id:[130] Rec: 58 Len: 32 ..... Ok 1 Group Id:[130] Rec: 59 Len: 32 ..... Ok 1 Group Id:[130] Rec: 60 Len: 32 ..... Ok 1 Group Id:[130] Rec: 61 Len: 32 ..... Ok 1 Group Id:[130] Rec: 62 Len: 32 ..... Ok 1 Group Id:[130] Rec: 63 Len: 32 ..... Ok 1 Group Id:[130] Rec: 64 Len: 32 ..... Ok 1 Group Id:[130] Rec: 65 Len: 32 ..... Ok 1 Group Id:[130] Rec: 66 Len: 32 ..... Ok 1 Group Id:[130] Rec: 67 Len: 32 ..... Ok 1 Group Id:[130] Rec: 68 Len: 32 ..... Ok 1 Group Id:[130] Rec: 69 Len: 32 ..... Ok 1 Group Id:[130] Rec: 70 Len: 32 ..... Ok 1 Group Id:[130] Rec: 71 Len: 32 ..... Ok 1 Group Id:[130] Rec: 72 Len: 32 ..... Ok 1 Group Id:[130] Rec: 73 Len: 32 ..... Ok 1 Group Id:[130] Rec: 74 Len: 32 ..... Ok 1 Group Id:[130] Rec: 75 Len: 32 ..... Ok 1 Group Id:[130] Rec: 76 Len: 32 ..... Ok 1 Group Id:[130] Rec: 77 Len: 32 ..... Ok 1 Group Id:[130] Rec: 78 Len: 32 ..... Ok 1 Group Id:[130] Rec: 79 Len: 32 ..... Ok 1 Group Id:[130] Rec: 80 Len: 32 ..... Ok 1 Group Id:[130] Rec: 81 Len: 32 ..... Ok 1 Group Id:[130] Rec: 82 Len: 32 ..... Ok 1 Group Id:[130] Rec: 83 Len: 32 ..... Ok 1 Group Id:[130] Rec: 84 Len: 32 ..... Ok 1 Group Id:[130] Rec: 85 Len: 32 ..... Ok 1 Group Id:[130] Rec: 86 Len: 32 ..... Ok 1 Group Id:[130] Rec: 87 Len: 32 ..... Ok 1 Group Id:[130] Rec: 88 Len: 32 ..... Ok 1 Group Id:[130] Rec: 89 Len: 32 ..... Ok 1 Group Id:[130] Rec: 90 Len: 32 ..... Ok 1 Group Id:[130] Rec: 91 Len: 32 ..... Ok 1 Group Id:[130] Rec: 92 Len: 32 ..... Ok 1 Group Id:[130] Rec: 93 Len: 32 ..... Ok 1 Group Id:[130] Rec: 94 Len: 32 ..... Ok 1 Group Id:[130] Rec: 95 Len: 32 ..... Ok 1 Group Id:[130] Rec: 96 Len: 32 ..... Ok 1 Group Id:[130] Rec: 97 Len: 32 ..... Ok 1 Group Id:[130] Rec: 98 Len: 32 ..... Ok 1 Group Id:[130] Rec: 99 Len: 32 ..... Ok 1 Group Id:[130] Rec: 100 Len: 32 ..... Ok 1 Group Id:[130] Rec: 101 Len: 32 ..... Ok 1 Group Id:[130] Rec: 102 Len: 32 ..... Ok 1 Group Id:[130] Rec: 103 Len: 32 ..... Ok 1 Group Id:[130] Rec: 104 Len: 32 ..... Ok 1 Group Id:[130] Rec: 105 Len: 32 ..... Ok 1 Group Id:[130] Rec: 106 Len: 32 ..... Ok 1 Group Id:[130] Rec: 107 Len: 32 ..... Ok 1 Group Id:[130] Rec: 108 Len: 32 ..... Ok 1 Group Id:[130] Rec: 109 Len: 32 ..... Ok 1 Group Id:[130] Rec: 110 Len: 32 ..... Ok 1 Group Id:[130] Rec: 111 Len: 32 ..... Ok 1 Group Id:[130] Rec: 112 Len: 32 ..... Ok 1 Group Id:[130] Rec: 113 Len: 32 ..... Ok 1 Group Id:[130] Rec: 114 Len: 32 ..... Ok 1 Group Id:[130] Rec: 115 Len: 32 ..... Ok 1 Group Id:[130] Rec: 116 Len: 32 ..... Ok 1 Group Id:[130] Rec: 117 Len: 32 ..... Ok 1 Group Id:[130] Rec: 118 Len: 32 ..... Ok 1 Group Id:[130] Rec: 119 Len: 32 ..... Ok 1 Group Id:[130] Rec: 120 Len: 32 ..... Ok 1 Group Id:[130] Rec: 121 Len: 32 ..... Ok 1 Group Id:[130] Rec: 122 Len: 32 ..... Ok 1 Group Id:[130] Rec: 123 Len: 32 ..... Ok 1 Group Id:[130] Rec: 124 Len: 32 ..... Ok 1 Group Id:[130] Rec: 125 Len: 32 ..... Ok 1 Group Id:[130] Rec: 126 Len: 32 ..... Ok 1 Group Id:[130] Rec: 127 Len: 32 ..... Ok 1 Group Id:[130] Rec: 128 Len: 32 ..... Ok 1 Group Id:[130] Rec: 129 Len: 32 ..... Ok 1 Group Id:[130] Rec: 130 Len: 32 ..... Ok 1 Group Id:[130] Rec: 131 Len: 32 ..... Ok 1 Group Id:[130] Rec: 132 Len: 32 ..... Ok 1 Group Id:[130] Rec: 133 Len: 32 ..... Ok 1 Group Id:[130] Rec: 134 Len: 32 ..... Ok 1 Group Id:[130] Rec: 135 Len: 32 ..... Ok 1 Group Id:[130] Rec: 136 Len: 32 ..... Ok 1 Group Id:[130] Rec: 137 Len: 32 ..... Ok 1 Group Id:[130] Rec: 138 Len: 32 ..... Ok 1 Group Id:[130] Rec: 139 Len: 32 ..... Ok 1 Group Id:[130] Rec: 140 Len: 32 ..... Ok 1 Group Id:[130] Rec: 141 Len: 32 ..... Ok 1 Group Id:[130] Rec: 142 Len: 32 ..... Ok 1 Group Id:[130] Rec: 143 Len: 32 ..... Ok 1 Group Id:[130] Rec: 144 Len: 32 ..... Ok 1 Group Id:[130] Rec: 145 Len: 16 ..... Ok 1 Group Id:[131] Rec: 0 Len: 106 .... Ok 1 Group Id:[131] Rec: 1 Len: 106 .... Ok 1 Group Id:[131] Rec: 2 Len: 106 .... Ok 1 Group Id:[131] Rec: 3 Len: 106 .... Ok 1 Group Id:[131] Rec: 4 Len: 106 .... Ok 1 Group Id:[131] Rec: 5 Len: 106 .... Ok 1 Group Id:[131] Rec: 6 Len: 106 .... Ok 1 Group Id:[131] Rec: 7 Len: 106 .... Ok 1 Group Id:[131] Rec: 8 Len: 106 .... Ok 1 Group Id:[131] Rec: 9 Len: 106 .... Ok 1 Group Id:[131] Rec: 10 Len: 106 .... Ok 1 Group Id:[131] Rec: 11 Len: 106 .... Ok 1 Group Id:[131] Rec: 12 Len: 106 .... Ok 1 Group Id:[131] Rec: 13 Len: 106 .... Ok 1 Group Id:[131] Rec: 14 Len: 106 .... Ok 1 Group Id:[131] Rec: 15 Len: 106 .... Ok 1 Group Id:[131] Rec: 16 Len: 106 .... Ok 1 Group Id:[131] Rec: 17 Len: 106 .... Ok 1 Group Id:[131] Rec: 18 Len: 106 .... Ok 1 Group Id:[132] Rec: 2 Len: 528 .... Ok 5 Group Id:[152] Rec: 0 Len: 180 .... Ok 2 Group Id:[238] Rec: 0 Len: 70 ..... Ok 1 Group Id:[238] Rec: 1 Len: 70 ..... Ok 1 Group Id:[238] Rec: 2 Len: 70 ..... Ok 1 Group Id:[238] Rec: 3 Len: 70 ..... Ok 1 Group Id:[238] Rec: 4 Len: 70 ..... Ok 1 Group Id:[238] Rec: 5 Len: 70 ..... Ok 1 Group Id:[238] Rec: 6 Len: 70 ..... Ok 1 Group Id:[238] Rec: 7 Len: 70 ..... Ok 1 Group Id:[238] Rec: 8 Len: 70 ..... Ok 1 Group Id:[238] Rec: 9 Len: 70 ..... Ok 1 Group Id:[238] Rec: 10 Len: 70 ..... Ok 1 Group Id:[238] Rec: 11 Len: 70 ..... Ok 1 Group Id:[238] Rec: 12 Len: 70 ..... Ok 1 Group Id:[238] Rec: 13 Len: 70 ..... Ok 1 Group Id:[238] Rec: 14 Len: 70 ..... Ok 1 Group Id:[238] Rec: 15 Len: 70 ..... Ok 1 Group Id:[238] Rec: 16 Len: 70 ..... Ok 1 Group Id:[238] Rec: 17 Len: 70 ..... Ok 1 Group Id:[238] Rec: 18 Len: 70 ..... Ok 1 Group Id:[238] Rec: 19 Len: 70 ..... Ok 1 Group Id:[238] Rec: 20 Len: 70 ..... Ok 1 Group Id:[238] Rec: 21 Len: 70 ..... Ok 1 Group Id:[238] Rec: 22 Len: 70 ..... Ok 1 Group Id:[238] Rec: 23 Len: 70 ..... Ok 1 Group Id:[238] Rec: 24 Len: 70 ..... Ok 1 Group Id:[238] Rec: 25 Len: 70 ..... Ok 1 Group Id:[238] Rec: 26 Len: 70 ..... Ok 1 Group Id:[238] Rec: 27 Len: 70 ..... Ok 1 Group Id:[238] Rec: 28 Len: 70 ..... Ok 1 Group Id:[238] Rec: 29 Len: 70 ..... Ok 1 Group Id:[238] Rec: 30 Len: 70 ..... Ok 1 Group Id:[238] Rec: 31 Len: 70 ..... Ok 1 Group Id:[238] Rec: 32 Len: 70 ..... Ok 1 Group Id:[238] Rec: 33 Len: 70 ..... Ok 1 Group Id:[238] Rec: 34 Len: 70 ..... Ok 1 Group Id:[238] Rec: 35 Len: 70 ..... Ok 1 Group Id:[238] Rec: 36 Len: 70 ..... Ok 1 Group Id:[238] Rec: 37 Len: 70 ..... Ok 1 Group Id:[238] Rec: 38 Len: 70 ..... Ok 1 Group Id:[238] Rec: 39 Len: 70 ..... Ok 1 Group Id:[238] Rec: 40 Len: 70 ..... Ok 1 Group Id:[238] Rec: 41 Len: 70 ..... Ok 1 Group Id:[238] Rec: 42 Len: 70 ..... Ok 1 Group Id:[238] Rec: 43 Len: 70 ..... Ok 1 Group Id:[238] Rec: 44 Len: 70 ..... Ok 1 Group Id:[238] Rec: 45 Len: 70 ..... Ok 1 Group Id:[238] Rec: 46 Len: 70 ..... Ok 1 Group Id:[238] Rec: 47 Len: 70 ..... Ok 1 Group Id:[238] Rec: 48 Len: 70 ..... Ok 1 Group Id:[238] Rec: 49 Len: 70 ..... Ok 1 Group Id:[238] Rec: 50 Len: 70 ..... Ok 1 Group Id:[238] Rec: 51 Len: 70 ..... Ok 1 Group Id:[238] Rec: 52 Len: 70 ..... Ok 1 Group Id:[238] Rec: 53 Len: 70 ..... Ok 1 Group Id:[238] Rec: 54 Len: 70 ..... Ok 1 Group Id:[238] Rec: 55 Len: 70 ..... Ok 1 Group Id:[238] Rec: 56 Len: 70 ..... Ok 1 Group Id:[238] Rec: 57 Len: 70 ..... Ok 1 Group Id:[238] Rec: 58 Len: 70 ..... Ok 1 Group Id:[238] Rec: 59 Len: 70 ..... Ok 1 Group Id:[238] Rec: 60 Len: 70 ..... Ok 1 Group Id:[238] Rec: 61 Len: 70 ..... Ok 1 Group Id:[238] Rec: 62 Len: 70 ..... Ok 1 Group Id:[238] Rec: 63 Len: 70 ..... Ok 1 Group Id:[238] Rec: 64 Len: 70 ..... Ok 1 Group Id:[238] Rec: 65 Len: 70 ..... Ok 1 Group Id:[238] Rec: 66 Len: 70 ..... Ok 1 Group Id:[238] Rec: 67 Len: 70 ..... Ok 1 Group Id:[238] Rec: 68 Len: 70 ..... Ok 1 Group Id:[238] Rec: 69 Len: 70 ..... Ok 1 Group Id:[238] Rec: 70 Len: 70 ..... Ok 1 Group Id:[238] Rec: 71 Len: 70 ..... Ok 1 Group Id:[238] Rec: 72 Len: 70 ..... Ok 1 Group Id:[238] Rec: 73 Len: 70 ..... Ok 1 Group Id:[238] Rec: 74 Len: 70 ..... Ok 1 Group Id:[238] Rec: 75 Len: 70 ..... Ok 1 Group Id:[238] Rec: 76 Len: 70 ..... Ok 1 Group Id:[238] Rec: 77 Len: 70 ..... Ok 1 Group Id:[238] Rec: 78 Len: 70 ..... Ok 1 Group Id:[238] Rec: 79 Len: 70 ..... Ok 1 Group Id:[238] Rec: 80 Len: 70 ..... Ok 1 Group Id:[238] Rec: 81 Len: 70 ..... Ok 1 Group Id:[238] Rec: 82 Len: 70 ..... Ok 1 Group Id:[238] Rec: 83 Len: 70 ..... Ok 1 Group Id:[238] Rec: 84 Len: 70 ..... Ok 1 Group Id:[238] Rec: 85 Len: 70 ..... Ok 1 Group Id:[238] Rec: 86 Len: 70 ..... Ok 1 Group Id:[238] Rec: 87 Len: 70 ..... Ok 1 Group Id:[238] Rec: 88 Len: 70 ..... Ok 1 Group Id:[238] Rec: 89 Len: 70 ..... Ok 1 Group Id:[238] Rec: 90 Len: 70 ..... Ok 1 Group Id:[238] Rec: 91 Len: 70 ..... Ok 1 Group Id:[238] Rec: 92 Len: 70 ..... Ok 1 Group Id:[238] Rec: 93 Len: 70 ..... Ok 1 Group Id:[238] Rec: 94 Len: 70 ..... Ok 1 Group Id:[238] Rec: 95 Len: 70 ..... Ok 1 Group Id:[238] Rec: 96 Len: 70 ..... Ok 1 Group Id:[238] Rec: 97 Len: 70 ..... Ok 1 Group Id:[238] Rec: 98 Len: 70 ..... Ok 1 Group Id:[238] Rec: 99 Len: 70 ..... Ok 1 Group Id:[238] Rec: 100 Len: 70 ..... Ok 1 Group Id:[238] Rec: 101 Len: 70 ..... Ok 1 Group Id:[238] Rec: 102 Len: 70 ..... Ok 1 Group Id:[238] Rec: 103 Len: 70 ..... Ok 1 Group Id:[238] Rec: 104 Len: 70 ..... Ok 1 Group Id:[238] Rec: 105 Len: 70 ..... Ok 1 Group Id:[238] Rec: 106 Len: 70 ..... Ok 1 Group Id:[238] Rec: 107 Len: 70 ..... Ok 1 Group Id:[238] Rec: 108 Len: 70 ..... Ok 1 Group Id:[238] Rec: 109 Len: 70 ..... Ok 1 Group Id:[238] Rec: 110 Len: 70 ..... Ok 1 Group Id:[238] Rec: 111 Len: 70 ..... Ok 1 Group Id:[238] Rec: 112 Len: 70 ..... Ok 1 Group Id:[238] Rec: 113 Len: 70 ..... Ok 1 Group Id:[238] Rec: 114 Len: 70 ..... Ok 1 Group Id:[238] Rec: 115 Len: 70 ..... Ok 1 Group Id:[238] Rec: 116 Len: 70 ..... Ok 1 Group Id:[238] Rec: 117 Len: 70 ..... Ok 1 Group Id:[238] Rec: 118 Len: 70 ..... Ok 1 Group Id:[238] Rec: 119 Len: 70 ..... Ok 1 Group Id:[238] Rec: 120 Len: 70 ..... Ok 1 Group Id:[238] Rec: 121 Len: 70 ..... Ok 1 Group Id:[238] Rec: 122 Len: 70 ..... Ok 1 Group Id:[238] Rec: 123 Len: 70 ..... Ok 1 Group Id:[238] Rec: 124 Len: 70 ..... Ok 1 Group Id:[238] Rec: 125 Len: 70 ..... Ok 1 Group Id:[238] Rec: 126 Len: 70 ..... Ok 1 Group Id:[238] Rec: 127 Len: 70 ..... Ok 1 Group Id:[238] Rec: 128 Len: 70 ..... Ok 1 Group Id:[238] Rec: 129 Len: 70 ..... Ok 1 Group Id:[238] Rec: 130 Len: 70 ..... Ok 1 Group Id:[238] Rec: 131 Len: 70 ..... Ok 1 Group Id:[238] Rec: 132 Len: 70 ..... Ok 1 Group Id:[238] Rec: 133 Len: 70 ..... Ok 1 |
06-19-2017, 13:17 | #14 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: PAKISTAN Age: 38
Member: 689829 Status: Offline Sonork: 100.1651716 Thanks Meter: 102 | Quote:
it's long time for this post but i think someone will need this. this is the solution tested by me. | |
06-21-2017, 21:18 | #15 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | Sim if test fail , it means when you take selftest result from your set there is no sim card inside in mobile . it's normal . Anyway it's a hardware issue , try to change PA with new one . (as posted above). Post result. |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
