Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 07-01-2012, 17:23   #1 (permalink)
Member: 1558098
nokia 1110i flash Process Failed?
please help me
1st Boot: Ok, DCT4, UPP: 2201 [Rh-93] [2.2.0.3]
2nd Boot: u_2nd.fia, Ver: 4.79.0
Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18
Algorithm: u_intel.fia, Ver: 4.80.0
Algorithm Ok, MSID: 8450500A21AC06695C73FB4A3B
Decoded MSID: 3E4EBAE9-001536F5-A9000000
Encoded FAID: D089D8B9-DD7F2DCF-AA7687D2
IMAGE: rh93_06.400
Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
Area2: 0x01010000-0x013BFFFF Erased, Time: 00:36
Area3: 0x013C0000-0x013EFFFF Erased, Time: 00:01
Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
MCU Flashing Completed, Time: 00:16
IMAGE: rh930_nai6.40ic
Area1: 0x01380000-0x013BFFFF Erased, Time: 00:02
CNT Flashing Completed, Time: 00:01
Extracting Contents Package ...
Init Local Mode Failed
Contents Package Extracting Failed:
Process Failed, Repowering Mobile
Old 07-01-2012, 17:27   #2 (permalink)
alamgarh's Avatar
Member: 358694
complete erase your phone then try to flash with latest version without erasing. i mean u must skip erase area after erasing. then flash , i think it will be ok. then write pm and then unlock.
Old 07-01-2012, 17:52   #3 (permalink)
Member: 1558098
First thank you brother for response
second how can i skip erasing setup?
please help me because im new in this domaine.
Old 07-01-2012, 18:19   #4 (permalink)
Member: 1558098
AFTER FLASH PPM ONLY PHONE WORKS BUT PROBLEME INSERT SIM
Algorithm Ok, MSID: 848AEB1A91A6CFEF820986D7CB
Decoded MSID: 3E4EBAE9-001536F5-AA000000
Encoded FAID: 817BBFA6-D1FF71AF-D6EF6FFF
IMAGE: rh93_06.40ic
Area1: 0x011E0000-0x011EFFFF Erased, Time: 00:00
Area2: 0x011F0000-0x0137FFFF Erased, Time: 00:15
PPM Flashing Completed, Time: 00:11
Flashing Completed, Rebooting Mobile
Old 07-01-2012, 19:18   #5 (permalink)
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
@kadiadi ,
phone have hardware issue , better check hardware (uem).
Old 07-02-2012, 08:05   #6 (permalink)
.::Gsm_Srilanka::.'s Avatar
Member: 1133072
Sonork: 100.1611321
IMAGE: rh93_06.40ic
insert sim show it not software issue, try change sim esd filter.
if show "SIM NOT VALID" do initial simlock.
B,R-chamisrilanka
Old 07-02-2012, 09:16   #7 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
phone can't insert test or local mood with fbus you need to use easy cable with such mobiles.
Old 07-02-2012, 09:19   #8 (permalink)
Member: 1558098
thank you dears brothers scsarcar, chamisrilanka
problem solved : the battery was not the original phone battery.
other question: when the only ppm flash is request?
thanks in advance for any help.
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.39087 seconds with 11 queries
