05-26-2010, 08:15 | #16 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | 2nd Boot: u3_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18 Algorithm: u3_intel.fia, Ver: 4.80.0 Algorithm Ok, MSID: 849272425128CDB6F6BE6BAF7A Decoded MSID: 3E4EBAE9-001EB9AC-A9000000 Encoded FAID: B03FD3BD-1FC49FF0-015EB272 IMAGE: rh105_05.060 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013AFFFF Erased, Time: 00:35 Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:03 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:19 IMAGE: rh1050_nai5.06ij Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile I All Tried But Problem Not Solve |
05-26-2010, 09:50 | #17 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Guangzhou-China
Member: 468587 Status: Offline Sonork: 100.1612429 Thanks Meter: 681 | @ mygsm world try with erase 01000000-013FFFFF. full flash. Quote:
*post result. | |
06-08-2010, 03:57 | #22 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Kathmandu, Nepal
Member: 260236 Status: Offline Sonork: 100.1641081 Thanks Meter: 135 | just block vpp pin of the cable and flash the set 100% solution |
The Following 5 Users Say Thank You to ace_venturia For This Useful Post: |
08-01-2010, 05:21 | #26 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 74
Member: 1323797 Status: Offline Thanks Meter: 154 | all is wrong its not a cable or software problem.just rehoot prosessor ic and flash again with any tool 11111111111111111111111111110000000000000000000000 0000000% ok keep it up BR.inocent |
08-01-2010, 12:16 | #27 (permalink) | |
Freak Poster Join Date: May 2004 Age: 44
Member: 66510 Status: Offline Thanks Meter: 27 | Quote:
fash with easy cable high version and low version flash but set is not ok pls any one help this problem | |
09-25-2010, 00:08 | #30 (permalink) | |
Crazy Poster Join Date: Jan 2008 Location: Algeria
Member: 687988 Status: Offline Thanks Meter: 11 | Quote:
or do full erase then flash again and UI users, and no need to write PM. tested many times by me. | |
1200 Contents Package Extracting Failed | sr8787 | Nokia Hardware & Hardware Repair | 8 | 09-28-2010 13:10 |
1200 Contents Package Extracting Failed | sr8787 | Nokia Hardware & Hardware Repair | 10 | 08-25-2009 03:23 |
1200 Contents Package Extracting Failed | sr8787 | Nokia Hardware & Hardware Repair | 1 | 08-20-2009 09:23 |
