11-30-2010, 06:37 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: india Age: 39
Member: 725038 Status: Offline Sonork: 100.1675584 Thanks Meter: 288 | nokia 1600 flach probalem 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00EC2268,Sam K8S3215ETE Algorithm: u_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 84D35DAAC65A497CC5531F5069 Decoded MSID: 3E4EBAE9-005812E0-A9000000 Encoded FAID: C933F145-6C8BD3AB-015E9C7F IMAGE: rh64_07.020 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x013BFFFF Erased, Time: 00:26 Area3: 0x013C0000-0x013EFFFF Erased, Time: 00:01 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds Write Error: hDat 14, at: 0x01040000:08 Process Failed, Repowering Mobile pls help me |
11-30-2010, 06:47 | #4 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Hate stupidity
Member: 904530 Status: Offline Thanks Meter: 517 | as you see this info, means communications ok, so neot need clean nothing. cannot flash or erase, because vpp voltage forced down to ground by cable vpp pin |
11-30-2010, 17:29 | #7 (permalink) |
Freak Poster Join Date: Sep 2010 Location: world cellphone
Member: 1396436 Status: Offline Thanks Meter: 35 | look that you are check in software, in this log you see a 1600 rh-64, i done downgrade to change language, this phone done v6.40 LP AE and finally v5.54 LP UA, measure cable 1100, good luck, if you dont solved you problem post log to see 1st Boot: Ok, DCT4, UPP: 2201 [Rh-64] [2.1.0.1] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320 Algorithm: u_amd.fia, Ver: 4.79.0 Rebooting Mobile MCU SW : V 6.40 12-01-07 RH-64 (c) NMP PPM SW : V 6.40 12-01-07 RH-64 (c) NMP AE Prd.Code: 0525092 Bpr.Code: 0520754 Prod.Sn : KKP336131 HW Vers : 0526 UEM : 1328 UPP : 8705 [2201] RFIC Ver: 0500 DSP Vers: P05w06.v34 LCD Type: PHI:NAXv8B LDS184 IMEI : 358xxxxxxxxxxxxxxxxxxxxx SL Conf : 001-01-00000000000 SL Prof : 000000000000000-2 SL Var : 000035xxxxxxxxxxxxxxxxx SL Aux : 00020000 HW Sig : EBE54BD711B0A6D0 Box Id : 8C06FFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN MastCode: 26 57 24 60 22 Provider: GSM Test Equipment #pw+ 996 022 714 452 535 +1# #pw+ 918 402 335 676 611 +2# #pw+ 837 841 651 510 452 +3# #pw+ 487 167 000 563 376 +4# #pw+ 497 017 510 512 323 +5# #pw+ 458 137 574 653 341 +6# #pw+ 108 294 223 614 201 +7# 1st Boot: Ok, DCT4, UPP: 2201 [Rh-64] [2.1.0.1] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320 Algorithm: u_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 8484D3F29A8280F6015080FF2B Decoded MSID: 3E4EBAE9-00860277-AA000000 Encoded FAID: D979210A-F1376951-C38E5FA6 IMAGE: rh64_05.540 Erasing: 0x01000000-0x0100FFFF ... Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Erasing: 0x01010000-0x013BFFFF ... Area2: 0x01010000-0x013BFFFF Erased, Time: 00:30 Erasing: 0x013C0000-0x013EFFFF ... Area3: 0x013C0000-0x013EFFFF Erased, Time: 00:01 Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:13 IMAGE: rh640_nai5.54ua Erasing: 0x01380000-0x013BFFFF ... Area1: 0x01380000-0x013BFFFF Erased, Time: 00:02 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Running: Server fake reply for CUI phone. Contents Package Extracting Ok, Time: 00:10 1st Boot: Ok, DCT4, UPP: 2201 [Rh-64] [2.1.0.1] 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320 Algorithm: u_amd.fia, Ver: 4.79.0 Algorithm Ok, MSID: 8484D3F29A8280F6015080FF2B Decoded MSID: 3E4EBAE9-00860277-AA000000 Encoded FAID: D979210A-F1376951-C38E5FA6 IMAGE: rh64_05.54ua Erasing: 0x011D0000-0x011DFFFF ... Area1: 0x011D0000-0x011DFFFF Erased, Time: 00:00 Erasing: 0x011E0000-0x0137FFFF ... Area2: 0x011E0000-0x0137FFFF Erased, Time: 00:13 PPM Flashing Completed, Time: 00:11 Flashing Completed, Rebooting Mobile MCU SW : V 5.54 16-08-06 RH-64 (c) NMP PPM SW : V 5.54 16-08-06 RH-64 (c) NMP UA Prd.Code: 0525092 Bpr.Code: 0520754 Prod.Sn : KKP336131 HW Vers : 0526 UEM : 1328 UPP : 8705 [2201] RFIC Ver: 0500 DSP Vers: P05w06.v34 LCD Type: PHI:LD184v8b IMEI : 358xxxxxxxxxxxxxx SL Conf : 001-01-00000000000 SL Prof : 000000000000000-2 SL Var : 000035xxxxxxxxxxxxxxxxxxxx SL Aux : 00020000 HW Sig : EBE54BD711B0A6D0 Box Id : 8C06FFFFFFFFFFFF BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN MastCode: 26 57 24 60 22 Provider: GSM Test Equipment #pw+ 996 022 714 452 535 +1# #pw+ 918 402 335 676 611 +2# #pw+ 837 841 651 510 452 +3# #pw+ 487 167 000 563 376 +4# #pw+ 497 017 510 512 323 +5# #pw+ 458 137 574 653 341 +6# #pw+ 108 294 223 614 201 +7# |
The Following User Says Thank You to warrior2010 For This Useful Post: |
