08-25-2008, 20:00 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 39
Member: 61620 Status: Offline Thanks Meter: 5 | Nokia 1650 Dead I have a 1650, i tried to upgrade to phone from 4.11 to 5.06, I only did flashing of MCU+PPM. Now I cannot read the phone anymore with NBOX+HWK. Any suggestion? Thanks, Gideon |
The Following User Says Thank You to The Beast For This Useful Post: |
08-26-2008, 19:03 | #8 (permalink) |
Member: 61620 Status: Offline Thanks Meter: 5 | Hi everyone, Thanks, for all your advice. First: The phone doesn't boot, I tried the info button, nothing, tried the read PM button, nothing. That is the problem, so I don't have any log for you. The phone just doesn't boot anymore. I did not try full erase yet, because i cannot read the PM from the phone. Any other suggestion? |
08-26-2008, 19:52 | #10 (permalink) |
Member: 61620 Status: Offline Thanks Meter: 5 | I have erased flashed. I read a PM from another good 1650. Erasing went ok. Flashing also went ok: 1st Boot Err: Bad Resp DCT3, C3 D3 5 Cannot Detect Mobile Brand Bad Image File: rm305_5.06.smi 1st Boot: Ok, DCT4, UPP: 2292 [Rm-305] [2.0.7.2] 2nd Boot: u3_2nd.fia, Ver: 4.70.1 Fl0: 0x01000000-0x01FFFFFF,0001327E,Amd 29NS128P Algorithm: u3_amd.fia, Ver: 4.70.1 Algorithm Ok, MSID: 84F37E81ED2BB77F77DC2A11DE Decoded MSID: 3E4EBAE9-00941508-A8000000 Encoded FAID: FD7835AF-B5338C36-A11E7BCF IMAGE: rm305_05.06af Area1: 0x01240000-0x0125FFFF Erased, Time: 00:00 Area2: 0x01260000-0x0175FFFF Erased, Time: 00:26 PPM Flashing Completed, Time: 00:50 Flashing Completed, Rebooting Mobile But the phone will not boot, LOCAL MODE will not show on the screen. After this I tried to write PM, again INIT LOCAL MODE FAILED. The phone still won't turn on. |
08-26-2008, 20:39 | #11 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: algeria BBA BELIMOUR Age: 46
Member: 184351 Status: Offline Thanks Meter: 263 | Quote:
first you have not flashed the mcu part (bad image file ) how do you expect to read the pm when the phone is dead ? first choose the mcu file wich end by 0 (biggest file size) rm305_05.060 second choose ppm normally yours is correct rm305_05.06ic as example third choose cnt file rm3050_nai5.06ic (same as ppm) finally press flash after that write pm Last edited by f164; 08-26-2008 at 20:48. | |
08-27-2008, 18:52 | #15 (permalink) | |
Member: 61620 Status: Offline Thanks Meter: 5 | Quote:
Thanks again. Gideon | |
nokia 1650 dead while i change the charging connector | parag4923 | Nokia Hardware & Hardware Repair | 9 | 11-30-2010 18:29 |
nokia 1650 dead ?? | dapinderjit | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 04-20-2010 13:42 |
Nokia 1650 dead no full factory | purshottam_bapu | Nokia Hardware & Hardware Repair | 8 | 03-01-2009 12:05 |
nokia 1650 dead help urgent | niks4u09 | Nokia Hardware & Hardware Repair | 2 | 01-24-2009 12:45 |
