Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 05-28-2011, 14:58   #1 (permalink)
saqi160's Avatar
Member: 780173
Sonork: 100.1594488
Arrow nokia 2690 flash ok but not uisetting and not power on problem
hi to all brothers
i have nokia 2690 its flashing ok but not power ok and not ui setting
any solution of its problem
its flash into log
1ST BOOT : C0,07 [Rm-635] [2.2.0.0]
CMT ASICID: 000000010000022600010006030C192101033000
EM 1 ID : 00000296
EM 2 ID : 00000B22
CMT PUBID : 04A0010DFC780056B22244B544E063DB8FB0C80C
CMT MODE : 00
CMT HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROMID : 273F6D55DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00898982-00008A31, Int NU48F512
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1
CMT KSIG0 : C6B9354E81AC464DED33FC7B90295086150F4539
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
PASUBTOC : PA_SL3
Rebooting Mobile
EM 1 ID : 00000296
EM 2 ID : 00000B22
CMT MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
CMT NPC Certificate: 20480 byte(s)
PROD: 0592078
HID0: 27080298253F0D4CEE941800646F724200000000
PBID: 04A0010DFC780056B22244B544E063DB8FB0C80C
KSIG: C6B9354E81AC464DED33FC7B90295086150F4539
HID1: 8ED402FDD79A9992ADED5DF6487E3F80B40B039E
IMEI: 353387-04-6*******
BTID: 5DB0861B50
Saved as: Rm-635_3533870463*****_528201141532_NPCCmt.bin
Saved as: Rm-635_35338704635*****_528201141532.ask
CMT VARIANT Certificate: 0 byte(s)
CMT R&D Certificate: 24576 byte(s)
CMT R&D Certificate: Erased
Saved as: Rm-635_35338704635*****_528201141532_RDCmt.bin
CMT CCC Certificate: 30600 byte(s)
Saved as: Rm-635_3533870463*****_528201141532_CCCCmt.bin
CMT HWC Certificate: 20480 byte(s)
HID0: 27080298253F0D4CED941800646F724200000000
PROD: 0592078
Saved as: Rm-635_3533870463*****_528201141532_HWCCmt.bin
EM 1 ID : 00000296
EM 2 ID : 00000B22
CMT MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm635__10.10.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00040000-000BFFFF
CMT NOR Erase Area: 0x000C0000-0013FFFF
CMT NOR Erase Area: 0x00140000-0137FFFF
CMT NOR Erase Area: 0x01380000-0151FFFF
CMT FLASH ERASE OK, Time: 01:24
Written: 8 Certificate(s)
CMT FLASH WRITE OK, Time: 01:58
Chip SECTOR_SIZE: 128k
Warning, Must be Used 128Kb Sector_Size CNT File
CONVERSION: Already 128K Paged Source
IMAGE : rm635__10.10.image_ab_blue
CMT NOR Erase Area: 0x01DC0000-0215FFFF
CMT NOR Erase Area: 0x02160000-03FBFFFF
CNT FLASH ERASE OK, Time: 00:56
CNT FLASH WRITE OK, Time: 00:47
IMAGE : rm635__10.10.ppm_ab
CMT NOR Erase Area: 0x01520000-01DBFFFF
PPM FLASH ERASE OK, Time: 00:14
PPM FLASH WRITE OK, Time: 00:19
Flashing Completed, Rebooting Mobile
Old 05-28-2011, 15:06   #2 (permalink)
Member: 696136
In what condition phone comes to you?
Did you upgrade or downgrade the phone?
Old 05-28-2011, 15:33   #3 (permalink)
mohammed imran's Avatar
Member: 533912
falsh latest version rm635_10.65.exe
Old 09-29-2011, 16:19   #4 (permalink)
Member: 741858
Sonork: 100.1607504 jaysu09@gmail
Hii dears...i have same problem in 2690....flashing ok..i can change local mode to testmode...and everything...but can't power on....i flash it with10.65v.........please help me.....
Old 09-30-2011, 08:12   #5 (permalink)
Member: 1657686
Brother,
Please post the Mobile info log.
If you can get mobile info, please check that carefully,you can see some thing may be abnormal like LCD UNKNOWN ... and do self test also. if everything normal then check RInger ways and BT IC.
Old 10-01-2011, 10:57   #6 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
bro.when he is saying that phone is not going in test or local mode then how can u get the self test.
Old 03-25-2012, 12:40   #7 (permalink)
Member: 942210
Sonork: 1511
nokia 2690
nokia 2690 flashing ok but not uisetting and power on
     ATF Software Version v8.55
ATF Box FBUS Flash Started...
Number of Image Files: 4
Forcing Test Mode via BUSCHECK...
Booting Phone via FBUS...
VBATT Powering Down <<<<
VBATT Powering Up   >>>>
SET VCCIO Level Done
SET BSI Load Done
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
                  TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 7  (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000001
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010006
     ID DWORD    3 : 030C1921
     ID DWORD    4 : 01033000
  2  EM_ASIC_ID 02
     Block Length  : 5  (05)
     ID DWORD    0 : 00000296
  3  EM_ASIC_ID 02
     ID DWORD    0 : 00000B22
  4  PUBLIC_ID 12
     ID DWORD    0 : 11000214
     ID DWORD    1 : 0E960156
     ID DWORD    2 : 2258C2DC
     ID DWORD    3 : 8A8EFF3B
     ID DWORD    4 : 76E7FCF9
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 273F6D55
     CRC         1 : DFAAF68F
Checksum           C7
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
Boot File - Version  010.042.00
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Secondary Loader Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : 03
 SubBlocks  : 03
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : NOR  00
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 2400 -> Type not in database
   Extended/Fixed ID : 0000
   Revision ID       : 8A31
 2 Sub Block ID      : 11  STORAGE_DEVICE_CONTENTS_BB5
   Block Length      : 13
   Device Index      : 00
   Device Contents   : 00000000000000000000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 Checksum   : D5
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :00EC DevID :2400 ExtID :0000 RevID :8A31
Flash Descriptor
   Device ID         : 2400
   Revision ID       : 0000
   Size              : 04000000 (64 MB)
   VPP Info          : 0009
   Erase10s          : 28
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPPInfo : VPP_INFO_3V_MASK  VPP_INFO_9V_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
Algorithm File - Version  010.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5  : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType  : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
Uploading ALGO File...
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
   PAPUB_KEYS_HASH_RESP_BB5 2A
   BB Asic Index   : 00
CMT PAPUBKEYS HASH:
Scanning Simlock Applet Type...
OK
              PA_SL3 Applet detected
* Firmware Version Downgrade will KILL PHONE !!!
* Manual Full Erase WILL KILL PHONE!!!
* Simlocks are in PM 120 Only...
* PM 308 is Write Protected...
FlashInfo.RestartMode : 2
Waiting for Phone to Go Online...
Elapsed Time: 1s
Elapsed Time: 2s
Elapsed Time: 3s
Elapsed Time: 4s
Elapsed Time: 5s
Elapsed Time: 6s
Elapsed Time: 7s
Elapsed Time: 8s
Elapsed Time: 9s
Elapsed Time: 10s
             Basic Phone Information
WARNING: Simlock Backup Failed
If this is a Dead Phone, just click YES
to Continue with the Flash Procedure...
Changing MODE : FLASH
SET BSI Load Done
BootFlashMode_DCT5
                  TIME STARTS HERE
  1  SYSTEM_ASIC_ID 01
  2  EM_ASIC_ID 02
  3  EM_ASIC_ID 02
  4  PUBLIC_ID 12
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
  7  ROM_ID 15
     CRC         0 : 273F6D55
     CRC         1 : DFAAF68F
Checksum           C7
 MessageID  : 03
 SubBlocks  : 03
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 8A31
   Block Length      : 13
   Device Index      : 00
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
 Checksum   : D5
SendAlgoCode_DCT5..
Flash Descriptor
   Device ID         : 2400
   Revision ID       : 0000
   VPP Info          : 0009
   Erase10s          : 28
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
Pabub KEY Request
   BB Asic Index   : 00
CMT PAPUBKEYS HASH:
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
 VARIANT :  Empty
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
Reading : PARTNERC (CMT)
 PARTNERC :  Empty
Reading : MDM_KEYS (CMT)
 MDM_KEYS :  Empty
FINISHED READING RPL DATA
 RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\353410048743813\353410048743813_50159.rpl
Processing Image File :
 C:\Program Files\Nokia\Phoenix\Products\RM-635\rm635__10.65.mcusw
CMT Type                   :  BB5
CMT Algorithm              :  BB5 ALGORITHM
Secondary Sending Speed    :  3250000 Hz
Algorithm Sending Speed    :  6500000 Hz
Program Sending Speed      :  6500000 Hz
Message Reading Speed      :  98000 Hz
Number of Blocks           :  1165
Entry Point                :  0x5047
Page Format                :  128K
Maximum Page Size          :  0x00004000
SET BSI Load Done
BootFlashMode_DCT5
                  TIME STARTS HERE
  1  SYSTEM_ASIC_ID 01
  2  EM_ASIC_ID 02
  3  EM_ASIC_ID 02
  4  PUBLIC_ID 12
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
  7  ROM_ID 15
     CRC         0 : 273F6D55
     CRC         1 : DFAAF68F
Checksum           C7
 MessageID  : 03
 SubBlocks  : 03
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 8A31
   Block Length      : 13
   Device Index      : 00
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
 Checksum   : D5
SendAlgoCode_DCT5..
Flash Descriptor
   Device ID         : 2400
   Revision ID       : 0000
   VPP Info          : 0009
   Erase10s          : 28
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
Pabub KEY Request
   BB Asic Index   : 00
CMT PAPUBKEYS HASH:
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
Certificate 5
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength  :  0x36  (54)
ERASE Blocks :  0x01  (1)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x33 (51)
            BB ASIC Index    : 0x00 CMT
            Device Type      : 0x00 NOR
            Device Index     : 0x00
               0             : 00000000-000006BF
               1             : 000006C0-0001FFFF
               2             : 00040000-000BFFFF
               3             : 000C0000-0013FFFF
               4             : 00140000-0137FFFF
               5             : 01380000-0151FFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      : 14 STATUS_NOR_OK_BB5
           Block Length      : 01
           BB ASIC Index     : 00
Successfully erased..
Time Taken to Erase : 00:01:12
TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 04 D9
ReturnedType : 04 DDR & 2TX
Flashing Speed: 5.00 Mhz
Processing  : rm635__10.65.mcusw
Total blocks to write : 1165
         FBUS Cable RX2 PIN Diagnostics
           Block Length      : 01
           BB ASIC Index     : 00
INFO: RX2 PIN is OK
>>  CMT Rootkey Hash CERT : NOLO
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS
>>  CMT Rootkey Hash CERT : UPDAPP
>>  CMT Rootkey Hash CERT : DSP0
>>  CMT Rootkey Hash CERT : MCUSW
ContinueFlash_DCT5 Complete
           Block Length      : 01
           BB ASIC Index     : 00
Continue Flash Complete :  : No Error - 0 (0x00)
Time Taken to Flash  : 00:01:07
 C:\Program Files\Nokia\Phoenix\Products\RM-635\rm635__10.65.ppm_mr
CMT Type                   :  BB5
Number of Blocks           :  205
Entry Point                :  0x00B6
Page Format                :  128K
Using Internal VPP
StartErase_DCT5...
BlockLength  :  0x0E  (14)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 01520000-01DBFFFF
           Block Length      : 01
           BB ASIC Index     : 00
Time Taken to Erase : 00:00:14
Processing  : rm635__10.65.ppm_mr
Total blocks to write : 205
           Block Length      : 01
           BB ASIC Index     : 00
Time Taken to Flash  : 00:00:12
 C:\Program Files\Nokia\Phoenix\Products\RM-635\rm635__10.65.image_mr_black
CMT Type                   :  BB5
Number of Blocks           :  488
Entry Point                :  0x00C8
Page Format                :  128K
Using Internal VPP
StartErase_DCT5...
BlockLength  :  0x16  (22)
            Block Length     : 0x13 (19)
            Device Index     : 0x00
               0             : 01DC0000-0215FFFF
               1             : 02160000-03FBFFFF
           Block Length      : 01
           BB ASIC Index     : 00
Time Taken to Erase : 00:00:37
Processing  : rm635__10.65.image_mr_black
Total blocks to write : 488
           Block Length      : 01
           BB ASIC Index     : 00
Time Taken to Flash  : 00:00:27
Total Flash Write Time (Flashing Only) : 00:01:47
Total Flashing Time (Booting + Erase + Flashing) : 00:03:50
Old 05-17-2012, 11:19   #8 (permalink)
Member: 804463
Sonork: buntydk1@gmail.com
10000% cpu prob....... this phone
Old 05-17-2012, 13:34   #9 (permalink)
Member: 1615710
Bro... connect the phone to Power Supply post what it shows when you press on off button.
Old 06-10-2012, 07:26   #10 (permalink)
Member: 682764
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: ********
Using device: HTI, FW ver: 00.50, SN: ********
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Preparing phone for SW downgrade ...
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0980010A84450156A8BFF63A3B5910DE471319CF
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 2400 - 0000 8A31 [Samsung K5N2833ATB,512 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: C6B9354E81AC464DED33FC7B90295086150F4539
TransmissionMode: DDR&TX2
Processing MCU file: rm635__10.65.mcusw
[BB5,BB5 ALGORITHM] size: 17.99 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [00140000-0137FFFF]
CMT FLASH,NOR area [01380000-0151FFFF]
erased in 1 min 8.516 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: C6B9354E [RAP Certificate v1 246] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
NOR: OK
Programming completed in 1 min 10.703 s
Processing PPM file: rm635__10.65.ppm_mr
[BB5,BB5 ALGORITHM] size: 3.19 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01520000-01DBFFFF]
erased in 13.547 s
NOR: OK
NOR: OK
Programming completed in 12.890 s
Processing CNT file: rm635__10.65.image_mr_blue
[BB5,BB5 ALGORITHM] page size: 128 K size: 7.63 MB
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF]
CMT FLASH,NOR area [02160000-03FBFFFF]
erased in 35.078 s
NOR: OK
NOR: OK
Programming completed in 29.813 s
Total time for flashing process(boot+erase+write) was 3 min 58.406 s
but set not on
Old 06-11-2012, 15:07   #11 (permalink)
..::RAJA-SOFT-INDORE::..'s Avatar
Member: 1702670
Sonork: 100.1623908
use 10.65 version.....................
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
Page generated in 0.66406 seconds with 11 queries
