09-13-2013, 07:55 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: saharsa bihar
Member: 1033632 Status: Offline Sonork: [email protected] Thanks Meter: 62 | nokia 2690 flashing problam here is log CPU: GenuineIntel, Sp: 5 Platform: Windows NT 5.1 (Build 2600 Service Pack 3) Versions: Ufs2xx.dll 3.2.4, Ufs2xx.sys 2.8.14 Executive Path: C:\Program Files\Nokia\Phoenix UFxBoot V2.2 (c) SarasSoft 2003. Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007. Sn: 78611 HID: FDC637D84160004E, HWK: A1.04-PRO1 Features: 00000001 Licence: True LogFile: .\_!_LOG\78611_91320131_20630_LOG.txt 1ST BOOT : C0,07 [Rm-635] [2.3.0.1] CMT ASICID: 000000010000022600010006030C192101033000 EM 1 ID : 00000296 EM 2 ID : 00000B22 CMT PUBID : 03E00117D1DB0056875549E8672892BE1CF0BBE8 CMT MODE : 00 CMT HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROMID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 00898982-00008A31, Int NU48F512 CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : rm635__10.65.mcusw CMT NOR Erase Area: 0x00000000-000006BF CMT NOR Erase Area: 0x000006C0-0001FFFF CMT NOR Erase Area: 0x00040000-000BFFFF CMT NOR Erase Area: 0x000C0000-0013FFFF CMT NOR Erase Area: 0x00140000-0137FFFF CMT NOR Erase Area: 0x01380000-0151FFFF CMT FLASH ERASE OK, Time: 00:14 DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_MISMATCH: RX2 Pin not Connected, or Used 5 Pin Cable ! DATA_BLK_ERROR at: 0x00F78400, 03 ERR: CMT FLASH WRITE D_BLK , LN: 0x004000, Time: 01:47 Process Failed, Repowering Mobile ** User Break ** |
09-13-2013, 09:34 | #4 (permalink) |
Member: 1033632 Status: Offline Sonork: [email protected] Thanks Meter: 62 | any other trick because I done many sets via this 5 pin cable |
09-13-2013, 09:59 | #7 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: Tamilnadu,India
Member: 906348 Status: Offline Sonork: 100.1624118 Thanks Meter: 30 | Quote:
Adjust in Speed option OR Try With Usb Cable | |
09-13-2013, 13:55 | #8 (permalink) |
No Life Poster Join Date: Dec 2007 Location: coimbatore
Member: 653676 Status: Offline Thanks Meter: 301 | its happen flashing with hwk me too lose a phone ...try Jaf Crack with Usb Dead Mode or othe Nokia Box with dead usb..Is this Your phone USB Detect ? |
09-14-2013, 15:01 | #10 (permalink) |
Member: 1033632 Status: Offline Sonork: [email protected] Thanks Meter: 62 | USb cable not boot properly... I have cheked 2 set (2690) .. but problam same... |
01-21-2014, 07:23 | #13 (permalink) | |
Freak Poster Join Date: Sep 2013 Location: INDIA
Member: 2015791 Status: Offline Sonork: 100.1649676 Thanks Meter: 21 | Quote:
