Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 01-20-2008, 09:55   #1 (permalink)
Member: 470292
Nokia 6131 Flash completed but still problem
I have flashed it 3 times but the problem is same. It turns on. On the screen Nokia appears for a few seconds and then display goes dem and then white. I downgrade the phone as well but no positive result. below is log.
Cannot Detect Mobile Brand
1ST BOOT : C0,07 [Rm-115]
RAPx ID : 000000010000022600010006010C192101001101
EM 1 ID : 00000232
EM 2 ID : 00000352
RAPx PBID : 0EE00013FED251569BD91BF1D9464F4D7E3BB625
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 191EC665DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 1.21.0
CMT FLID0 : 0001002F-00006921, Amd 29NS256N
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5
CMT KSIG0 : A8192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A
CMT VPP : Internal
CMT ALG Boot OK
IMAGE : rm115__06.60.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00020000-0007FFFF
CMT NOR Erase Area: 0x00080000-000DFFFF
CMT NOR Erase Area: 0x00100000-001FFFFF
CMT NOR Erase Area: 0x00200000-002DFFFF
CMT NOR Erase Area: 0x002E0000-00EDFFFF
CMT NOR Erase Area: 0x00EE0000-00EF7FFF
CMT NOR Erase Area: 0x00EF8000-00EFFFFF
CMT FLASH ERASE OK, Time: 01:03
CMT FLASH WRITE OK, Time: 01:19
EM 1 ID : 00000232
EM 2 ID : 00000352
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
CMT ALG Boot OK
Chip SECTOR_SIZE: 128k
Warning, Must be Used 128Kb Sector_Size CNT File
128K Image Saved as: rm115__06.60.image_tmo_de_128
IMAGE : rm115__06.60.image_tmo_de
CMT NOR Erase Area: 0x01460000-01FDFFFF
CNT FLASH ERASE OK, Time: 00:36
CNT FLASH WRITE OK, Time: 00:35
EM 1 ID : 00000232
EM 2 ID : 00000352
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
CMT ALG Boot OK
IMAGE : rm115__06.60.ppm_d
CMT NOR Erase Area: 0x00F00000-0145FFFF
PPM FLASH ERASE OK, Time: 00:21
PPM FLASH WRITE OK, Time: 00:26
Flashing Completed, Rebooting Mobile
UI Defaults Ok, Time: 00:32
Set UI Factory Defaults Ok, Time: 00:32
Set Full Factory Defaults Ok, Time: 00:31
Set Software Upgrade Defaults Ok, Time: 00:32
Set Security Ok, Time: 00:00
All Done, Time: 07:26
The Following User Says Thank You to adnanskyland For This Useful Post:
Old 01-20-2008, 10:01   #2 (permalink)
Axe Man's Avatar
Member: 221472
What kind of cable do you use to flash ?
Old 01-20-2008, 10:09   #3 (permalink)
Member: 470292
Nokia 6031 5 pin cable and ufs interface.
Old 01-20-2008, 10:12   #4 (permalink)
Axe Man's Avatar
Member: 221472
6131 is a BB5 phone. Use 7 pin cable with ticked Dual Line option. It should be ok.
The Following User Says Thank You to Axe Man For This Useful Post:
Old 01-21-2008, 05:14   #5 (permalink)
Member: 470292
I have flashed N70, 6280 etc. many sets with 5 pin cable its ok. But now in bb5 setlist which models need 7 pin cables. Because I want to get that all cables from market. Or if it is possible to modify my 5 pin cable so what is process...
Old 01-21-2008, 05:34   #6 (permalink)
GsmMunna's Avatar
Member: 66937
Sonork: 100.93433
Arrow
You May Need To buy One 7 Pin Cable...! More Over You Can Check Boot Ic Some Time It's H/W Prob....!
Munna.
Old 01-21-2008, 10:29   #7 (permalink)
Member: 470292
I am new to hwk use. I do'nt know about 7 pin cable. Where it connects to phone?
1. Is it connect to Handsfree jack? Or
2. Is it connect on batery place like 5 pin cable?
Old 01-21-2008, 10:32   #8 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Same place, same outlook, just has 7 pins.
Odia.
Old 11-09-2012, 04:47   #9 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Odia.
i have same problem ........flash 6131 with 7pin gpg cable flash ok but still ,,,,,,apear nokia then screen dem and white screen
W200i CID52 Flash Complete But Still Dead??? yeerk05 Cruiser Suite 17 05-23-2009 05:50
N95 Rm-159 Flashed Complete But Still Dead chiragp J.A.F. By Jafsupport.com 8 03-27-2008 12:34
k800 flashing complete but still dead c_ahmad79 Cruiser Suite 12 07-15-2007 08:20
7610 flashing complete but still problem HUM Nokia Hardware & Hardware-Repair Area 9 05-11-2007 16:44
Page generated in 0.34087 seconds with 11 queries
