Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 03-09-2012, 12:50   #1 (permalink)
robin25's Avatar
Member: 771565
Nokia 6600 NHL-10 dead after flashing
1st Boot: Ok, WD2, UPP: 1081 [Nhl-10] [2.2.0.3]
2nd Boot: w3_2nd.fia, Ver: 4.76.0
Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640
Fl1: 0x02000000-0x027FFFFF,002088C0,St M28W640
Fl2: 0x04000000-0x047FFFFF,002088C0,St M28W640
Fl3: 0x06000000-0x067FFFFF,002088C0,St M28W640
Algorithm: w3_st_i.fia, w3_cbusb.fia, Ver: 4.76.0
Algorithm Ok, MSID: 841511657533C93DA72144CF6C
Decoded MSID: 3E4EBAF7-004101EA-A9000000
Encoded FAID: E84D215D-095ED058-F95C7865
Cbus Boot Error: 9
Error Data1:
00000000: 00 96 84 15 11 65 75 33 C9 3D A7 21 44 CF 6C FB .....eu3.=.!D.l.
00000010: 00 C0 88 00 00 21 01 10 00 04 20 00 C0 88 00 00 .....!.... .....
00000020: 21 01 10 00 06 20 00 C0 88 00 00 21 01 10 00 C6 !.... .....!....
00000030: 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA AA ...u...x...{....
Error Data2:
00000000: B3 72 72 11 00 00 00 00 00 00 00 00 00 00 00 00 .rr.............
00000010: 00 00 21 01 10 00 04 20 00 C0 88 00 00 21 01 10 ..!.... .....!..
00000020: 00 06 20 00 C0 88 00 00 21 01 10 00 C6 00 00 EA .. .....!.......
00000030: 75 01 00 EA 78 01 00 EA 7B 01 00 EA AA D3 72 00 u...x...{.....r.
Before taking screenshot, expand this window !
Process Failed, Repowering Mobile
Please help me
Phone was in hang problem . some time working well
But after this error phone is in dead condition
Old 03-09-2012, 12:55   #2 (permalink)
jawad_anis's Avatar
Member: 726546
Sonork: 100.1578784
1st changed fbuss cable and try to flash it again if still same then make little heat upp ic and then reflash it again
Old 03-09-2012, 13:01   #3 (permalink)
robin25's Avatar
Member: 771565
Thank but i already changed cable but problem still same
Okey i'll try to rehot upp ic
Old 03-09-2012, 14:01   #4 (permalink)
lucky2010's Avatar
Member: 1322713
Dear try to flash with another box.........
Old 03-09-2012, 14:26   #5 (permalink)
ajaycrunch007's Avatar
Member: 506395
Remove tick (enable bt flashing) then flash hope ur set is 1000% ok
Old 03-09-2012, 16:57   #6 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
according to your logs & phone condition its 100% flash ic problem. u just rehot flash ic & try again.
Old 03-13-2012, 08:34   #7 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Your phone have hardware fault of flash ic.Hwk not dead that phone.
Br.
Vijendra Saini.
Old 03-14-2012, 05:06   #8 (permalink)
.::Gsm_Srilanka::.'s Avatar
Member: 1133072
Sonork: 100.1611321
ur correct bro....this problem come with Bluetooth ic damaged.
u flash with bt come this error. without no problem.
pls flash ur set without Bluetooth flashing.
P/S- TO OTHER RIPLEY ER,, U DONT KHOW WHAT IS PROBLEM DON'T POST WRONG UR WRONG ANSWER CAN DEAD MOBILE FOREVER.
B,R-chamisrilanka
Old 03-28-2012, 11:27   #9 (permalink)
dreameye's Avatar
Member: 728801
its 10000% flash chips fault
1 st try to reheat flash chips one by one
after power on it... if still same
then flash again 1000% sure
Old 03-28-2012, 13:09   #10 (permalink)
Member: 1062917
Old 06-04-2012, 15:15   #11 (permalink)
Member: 1545731
Sonork: n/a
nokia 6600 nhl10 flash file
Old 06-10-2012, 09:50   #12 (permalink)
Member: 1666829
Sonork: 100.1605750
hi frndz can u tel me how to heat nokia 6600 cpu and where is this???
i badly needed to heat her cpu..
Old 06-10-2012, 12:25   #13 (permalink)
Member: 924171
Sonork: 1615127:bamu
If you are not keen dont rush to heat flash ice you may endup demaging the phone badly just first research widely try to get ajaf crack and try before you make it worse instead take your time
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.34947 seconds with 11 queries
