11-14-2013, 05:37 | #2 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Use USB cable select Model/flash file Click check , insert usb cable wait till set entered in local mode, now read code/factory setting if phone unable to entered in local mode you must have to flash phone. Post result...... |
11-16-2013, 00:05 | #3 (permalink) | |
Freak Poster Join Date: Dec 2011 Location: Russia, North Ural Age: 68
Member: 1702061 Status: Offline Sonork: 100.1651562 Thanks Meter: 306 | UFS HWK support this model only via USB. You have 2 ways to solve problem: 1. Phone in normal mode, connect usb cable and press button "Info". Place screenshot here. 2. Phone in normal mode, connect usb cable. Select Scenario - UI options, tic box "Reset User Lock" and press "Start" button. Quote:
Logic is the iron made. Usefull post? Than press | |
11-17-2013, 13:54 | #4 (permalink) |
Freak Poster Join Date: Mar 2003 Age: 48
Member: 24115 Status: Offline Thanks Meter: 46 | Only with flash - Code: Insert USB Cable to Switched OFF Phone and Power ON USB BOOT : 56,06 [Rm-614] [2.3.0.2] CMT ASICID: 000000000000000022000509200C0000 EM 1 ID : 00005361 CMT PUBID : 0000000000498440637F25FBF86826641273F8D7 CMT MODE : 00 CMT HASH : 1B0D74C532CA1C6133940C740E8C786E CMT ROMID : DE56D582BDDE7A3A CMT 2ND Bt: BCM21351_usb2nd.fg, Ver: 11.34.0 CMT RMID0 : 00000000-00000000 CMT MCID0 : FFFF0000-00000000 CMT FLID0 : 00EC0030-00000431, Sam OneNAND-1G CMT RQALG : XSR 1.6 CMT 2ND Boot OK CMT ALGO : BCM21351_XSR16_usbalg.fg, Ver: 11.34.0 CMT KSIG0 : 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8 CMT ALG Boot OK IMAGE : rm614__08.63.mcusw CMT NAND Erase Area: 0x00000000-0001FFFF CMT NAND Erase Area: 0x00020000-000203FF CMT NAND Erase Area: 0x00060000-012FFFFF CMT NAND Erase Area: 0x01300000-01DFFFFF CMT NAND Erase Area: 0x02600000-029FFFFF CMT NAND Partition Format CMT NAND Partition Format CMT FLASH ERASE OK, Time: 00:00 Written: 11 Certificate(s) CMT FLASH WRITE OK, Time: 00:05 IMAGE : rm614__08.63.image_c1_0597597 CMT NAND Erase Area: 0x02A00000-0753FFFF CMT NAND Partition Format CNT FLASH ERASE OK, Time: 00:01 CNT FLASH WRITE OK, Time: 00:02 IMAGE : rm614__08.63.ppm_c1 CMT NAND Erase Area: 0x01E00000-025FFFFF PPM FLASH ERASE OK, Time: 00:00 PPM FLASH WRITE OK, Time: 00:01 Flashing Completed, Rebooting Mobile UI Defaults Failed UI Defaults Ok, Time: 00:20 Set UI Factory Defaults Ok, Time: 00:00 Set Full Factory Defaults Ok, Time: 00:02 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 All Done, Time: 00:35 |
