Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 09-27-2013, 23:18   #1 (permalink)
Member: 1144000
Thanks Meter: 9
NOKIA x2-01.1 WRONG-FLASHED
Hi forum members, I mistakenly flashed the firmware of nokia x2-01 (rm-709) into nokia x2-01.1 (rm-717), and since then it will only show white light and not boot even after I flashed it with the correct file. I need the way out of this using hwk or infinity best.
Old 09-28-2013, 05:22   #2 (permalink)
pradeep yadav's Avatar
Member: 1289553
Thanks Meter: 52
Post here 'flashing' log........
Old 09-28-2013, 05:39   #3 (permalink)
shuvo007's Avatar
Member: 775086
Sonork: 100.1603609
Thanks Meter: 369
@FLAT SCREEN
Download flash file from navifirm from Match product code & Flash your set again with update firmware.
The Following User Says Thank You to shuvo007 For This Useful Post:
Old 01-15-2015, 12:33   #4 (permalink)
Member: 2066787
Thanks Meter: 3
Is there a flash file with only rm-717 as most of rm-717 firmwares I donwloaded have mcu and ppm rm-709 and for that if you press *#0000# it shows rm-709. I have failed to restore simlock data i backed up and I wonder if the they RM-709 preventing it. It says Writting Simlock data ... Error!
If anyone has RM-717 complete with MCU and PPM with RM-717 please share.....
Old 01-15-2015, 12:41   #5 (permalink)
cobra iphoni's Avatar
Member: 1744389
Sonork: 100.1657056
Thanks Meter: 217
since its sl3, its a bit problem for sim lock to be retreved.
but if you find your product code, and proper flash of it.
try to flash just in case if sim data its stored somewhere of any back up of HWK, if im correct since you flashed with it.
post here product code?
all the best
Old 01-16-2015, 18:05   #6 (permalink)
Member: 2066787
Thanks Meter: 3
Model: X2.01
Type: RM-717
Code: 05HM5410
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Page generated in 0.25950 seconds with 7 queries
