05-04-2006, 23:16 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: UK
Member: 90865 Status: Offline Thanks Meter: 1 | Our old friend the N70 - flashing problem Output from DCTxBB5 is: 1st BOOT : C0,0C HELEN ID : 17100701 HELEN MODE: 00 HELEN PBID: 40B9A5D2DCD6A8CB942172E8F35083EF2D4E123D HELEN HASH: 2C05369F57CC3C4CF9E783E83D9B512B HELEN ROID: AB5E4ADB27A06946 RAP3 ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000352 RAP3 PBID : 24D0000851A94951E4933961D157323933EBEAA3 RAP3 MODE : 00 RAP3 HASH : E9EFF4BFAA5393217CA6B17755FC3E1401000000 RAP3 ROID : F28A211FCEA7B19D CMT 1st Boot Ok CMT 2nd Bt: RAP3Gv2_2nd.fg, Ver: 1.9.2 CMT FLID : 00010002-00000111, Amd No Name CMT FLCNT : 000000000000000000000000000000000000 CMT 2nd Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.9.3 CMT Alg Boot OK Erase Area: CMT 0x00000000-0052AB0D Erase Area: CMT 0x006A0000-006BFFFF Erase Area: CMT 0x006DF000-006EFFFF Erase Area: CMT 0x00700000-007EFFFF CMT FLASH ERASE OK, Time: 00:49 CMT FLASH WRITE OK, Time: 00:47 1st BOOT : C0,0C HELEN ID : 17100701 HELEN MODE: 00 HELEN PBID: 40B9A5D2DCD6A8CB942172E8F35083EF2D4E123D HELEN HASH: 2C05369F57CC3C4CF9E783E83D9B512B HELEN ROID: AB5E4ADB27A06946 RAP3 ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000352 RAP3 PBID : 24D0000851A94951E4933961D157323933EBEAA3 RAP3 MODE : 00 RAP3 HASH : E9EFF4BFAA5393217CA6B17755FC3E1402000000 RAP3 ROID : F28A211FCEA7B19D CMT 1st Boot Ok CMT 2nd Bt: RAP3Gv2_2nd.fg, Ver: 1.9.2 CMT FLID : 00010002-00000111, Amd No Name CMT FLCNT : 000000000000000000000000000000000000 CMT 2nd Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.9.3 CMT Alg Boot OK APE 2nd Bt: helen3_2nd.fg, Ver: 1.16.0 ERR: APE 2nd Boot APE ALG: 0700000000B172 Process Failed, Repowering Mobile So far I've tried 5 and 7 pin cables, with and without Vpp adaptor, the only one that gets me anywhere is 5 pin cable without Vpp. The AMD No Name worries me somewhat. At least the N70 still boots, but has the old firmware and the custom operator screen still. So, anyone have any gems of advice for me then? -- WolfMan |
05-04-2006, 23:24 | #3 (permalink) | |
Member: 90865 Status: Offline Thanks Meter: 1 | Quote:
Wonder if Odia can shed any light? -- WolfMan | |
05-05-2006, 19:33 | #4 (permalink) |
Product Supporter Join Date: Dec 2001 Location: in my skin Age: 47
Member: 8086 Status: Offline Thanks Meter: 180 | I had some problem with an N70 today too, I managed to flash it at last. Try the following: uninstall fia 6.xx package and install 5.51 and dctxbb5 1.4d. |
05-05-2006, 22:39 | #5 (permalink) | |
I may try it out on one of my machines to see if the older version works for me. -- WolfMan | |
05-06-2006, 03:46 | #6 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Try the following: uninstall fia 6.xx package and delete your flash folder and then install dctxbb5 1.4e. I have said it before, DCTx is using a custom set of flash loaders, if you install standard flash packages you will have all sorts of errors. Saras needs to analyse the new flash pack before it will work correctly. Odia. | |
05-06-2006, 10:12 | #7 (permalink) | |
-- WolfMan | |
05-07-2006, 11:11 | #8 (permalink) | |
I think a lot of these problems are due to cable connectivity, the Nokia flashing interfaces with spring pins and flat PCB pads look likely to be a bit problematic, and indeed they often are. This was using DCTxBB5 1.4e software. -- WolfMan | |
05-07-2006, 12:19 | #9 (permalink) | |
Member: 8086 Status: Offline Thanks Meter: 180 | Quote:
yes, that's why I first check connection (clean both phone and cable pins). | |
05-07-2006, 12:40 | #10 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Nostalgia... Age: 41
Member: 121728 Status: Offline Thanks Meter: 38 | Quote:
BR., | |
N70 Flashing Problem...APE blocks present in flash file but no APE mcu detected | Celldepot | J.A.F. By Jafsupport.com | 13 | 12-13-2010 05:46 |
n70 flash problem help me Error sync the phone... | mobiletuch | Nokia Hardware & Hardware Repair | 5 | 09-30-2010 07:56 |
N70 flashing problem!!! | simonng83 | Nokia Base Band 5 ( BB-5 ) | 0 | 02-06-2006 09:50 |
