08-21-2007, 13:59 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | !!The Perfect solution for PC Restart after installing new updates!! tested many times BR |
08-21-2007, 14:32 | #5 (permalink) |
Freak Poster Join Date: May 2007 Location: looking for a job Age: 44
Member: 506781 Status: Offline Sonork: looking for a job Thanks Meter: 12 | when i tried to install update HWK_Suite_Setup_v2[1].0.5.exe i had to format because an boot error then i installed clean. HWK_Suite_v02.05.001.exe then updates 1,2,3,4 with compatibility mode, 5,6 without compatibility mode then had no problem |
08-21-2007, 16:01 | #7 (permalink) |
Freak Poster Join Date: Jan 2004 Location: inside nokia tuning plant Age: 48
Member: 48980 Status: Offline Thanks Meter: 7 | youl having a big problem bro maybe your other programs will not run i suggest backup files,reformat pc,install all hwk suite.then install any program you want..thats the perfect solution mate..right odia?? |
08-21-2007, 17:32 | #8 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Will now add validty check of prefetch, will slow down the installer, but needs must... | |
08-21-2007, 18:15 | #9 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | We're not talking about agreeing or not here,The most important here is to resolve the problem. Because I tested it many times,That's why I posted it again Now All what we need is the results,Please those who tested it post results. BR |
08-21-2007, 18:22 | #10 (permalink) | |
Odia. | |
08-21-2007, 20:33 | #12 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 48
Member: 53791 Status: Offline Thanks Meter: 17 | Try to imagine if some of all that energy that is used to prevent people from installing 2.0.5.6 without installing 2.0.5.1 thru 2.0.5.5 .. Oh well maybe the skills only work for this kind of programming and not for programming needed updates.. Twisterfan |
08-21-2007, 23:01 | #14 (permalink) |
Junior Member Join Date: Jul 2003
Member: 33313 Status: Offline Thanks Meter: 0 | hwk minor 005 and 006 ... Odia i use orginal hwk with version 2.05.004 and works perfect.. but after instalation of minor 005.. my system files are gone .. i undelete them but this is insane what you are doing for peaople who use orginal hwk .. no killers no crack and system ****ed up, why are you not implement check hwk id before prepare install ????? it is so damn hard ? regards |
08-22-2007, 02:19 | #15 (permalink) |
No Life Poster Join Date: Nov 2003 Location: srilanka Age: 51
Member: 44229 Status: Offline Sonork: 1592530 Thanks Meter: 366 | still i cant install 2.0.5.5 and 2.0.5.6. i think major release may fix this. or hwk team need something else other than original hwk they may need 1. few time format thier customers pc (still i cant install) 2. removing all other software related to gsm 3. begging them 'pls how to install' if not pls tell us what causing this ntldr missing br. |
Whats the perfect solution for 1110,1600,6030,2310 LIght Problem | sharaz191 | Nokia Hardware & Hardware Repair | 7 | 01-08-2011 08:08 |
please advice/help after install new update my box DEAD | "KINO" | Cyclonebox | 1 | 10-31-2009 08:51 |
PROBLEM after installing new update by manole | alexander.tech | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 08-18-2009 08:04 |
After install new update, can not unlock any sony ericson???? | jham | Universalbox | 1 | 05-07-2009 17:30 |
which way is the perfect solution for w550i | nimanima | Universalbox | 6 | 05-09-2006 09:51 |
