Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 11-12-2008, 09:43   #1 (permalink)
Member: 898192
Thanks Meter: 2
Unhappy pls help me my tornado is not working
sir i try to upgrade new vr of ufs but coming this message(i attach picture pls chk) but sir i remove already old ver .y lik this messeg pls help me
Old 11-12-2008, 09:46   #2 (permalink)
Imran Bhatti's Avatar
Member: 266874
Sonork: 100.1581444
Thanks Meter: 97
where is picture or what is error u face plz explain?
Old 11-12-2008, 10:13   #3 (permalink)
Member: 898192
Thanks Meter: 2
Unhappy sir i explain her
sir i try to install new ver of ufs "HWK_Support_Suite_Setup_v02.08.000" i think this exe is 4.24mb lik that .but coming one message in my computer that is this sir " please remove HWK setup suite prior to installing/removing HWK support suit" pls help me wat prob . i alraedy remove my old vertion setup ver "HWK_Suite_Setup_v02.07.00" sir pls help me
Old 11-15-2008, 12:21   #4 (permalink)
Member: 266874
Sonork: 100.1581444
Thanks Meter: 97
Ok do as i write here.
first of all uninstall any privious version from control panel Add Remove program ufsHwk both exes support and main.
Then go to c:\program files and see if sara soft folder exist remove it manually.
after that in start click run command and type regedit a window registry editor will open from there select Hkey Local_Machine in it u select Software from there u see sara soft if it exist right click on it and delete manually. after this u may install new exe of 2.08.
hope this will help.
The Following User Says Thank You to Imran Bhatti For This Useful Post:
pls help me my mtbox is not activet !!!! sidah-gsm MT-BOX 0 01-23-2010 21:27
Pls. help me my Nokia 6700c - not work. Agarkov_Igor Nokia Base Band 5 ( BB-5 ) 0 11-08-2009 16:24
Pls Help Me My Box Is Dead - solved sarfraz Multi-Box 7 05-25-2006 17:49
Help me!!! My MC60 FUBU not works in my phone!!!! asdv E-Gold Based Phones 10 07-12-2005 13:15
Page generated in 0.19386 seconds with 9 queries
