01-18-2010, 19:13 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: algeria
Member: 793926 Status: Offline Thanks Meter: 67 | plz help me nokia,1600 2nd Boot: u_2nd.fia, Ver: 4.79.0 Fl0: 0x01000000-0x01FFFFFF,FE9F247E, UNKNOWN CHIP ! FLASH DEVICE NOT SUPPORTED Check Product, Use newer Flash Loader Pack Algorithm: u_intel.fia, Ver: 4.80.0 2nd Boot Error: Error Data1: 00000000: 9F 03 02 01 FE 9F 24 7E D4 B4 00 00 00 00 02 04 ......$~........ 00000010: 04 04 05 00 00 00 00 00 00 FE 9F 24 7E 5E 24 4C ...........$~^$L 00000020: A6 FE 9F 24 7E 5E 24 4C A6 B9 00 00 00 00 00 00 ...$~^$L........ 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Error Data2: 00000000: 11 11 11 11 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00000010: 00 00 00 00 00 00 FE 9F 24 7E 5E 24 4C A6 FE 9F ........$~^$L... 00000020: 24 7E 5E 24 4C A6 B9 D3 72 00 00 00 00 00 00 00 $~^$L...r....... 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Before taking screenshot, expand this window ! Process Failed, Repowering Mobile |
01-18-2010, 19:28 | #2 (permalink) |
No Life Poster Join Date: Mar 2007 Location: on moon right now !
Member: 469192 Status: Offline Thanks Meter: 48 | brother see this pls UNKNOWN CHIP so what to do try to heat on flash ic and when u check it again mast be numbers not unknown 100% tested in many phones |
The Following User Says Thank You to alialjorany For This Useful Post: |
01-19-2010, 17:36 | #4 (permalink) | |
No Life Poster Join Date: Jul 2008
Member: 811779 Status: Offline Thanks Meter: 242 | Quote:
here is clear your flash chip is dead now thats no more now now it is hardware only replace or reball is solution | |
01-21-2010, 07:39 | #7 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Islamabad / Riyadh Age: 58
Member: 90733 Status: Offline Thanks Meter: 39 | Its hard to change flash ic sometime connections between UPP & flash ic become dry so reheat the UPP carefully otherwise replacement of flash ic is the final solution. |
Help me!!!Nokia 1600 erassing error:4 | ..::MOBILES::.. | HWK | 2 | 01-07-2010 15:15 |
plz help me nokia 1110i | rem_drive | Nokia Hardware & Hardware Repair | 1 | 10-24-2009 09:23 |
plz help me nokia 6030 jumper need | junaid asif | Nokia Hardware & Hardware Repair | 3 | 05-31-2009 07:59 |
Plz Plz help me Nokia 6120c | gr8ice | Nokia Base Band 5 ( BB-5 ) | 2 | 01-20-2009 15:07 |
plz help me nokia 1200 shows car or ear pieac | atilad1 | Nokia Hardware & Hardware Repair | 5 | 06-07-2008 00:39 |
