11-03-2007, 07:09 | #1 (permalink) |
Insane Poster Join Date: Aug 2006
Member: 329883 Status: Offline Thanks Meter: 2 | Error installing HWK_Suite_Setup_v02.06.000 28-10-2007 get this error Call to RegDBQuerykey failed and some time OS is not supported by this installer have tried all type of Compatibilty NS 4.0 SP5 win98 and with out checking Compatibilty need quick help before this installer all was working fine |
The Following User Says Thank You to fanig For This Useful Post: |
11-03-2007, 08:51 | #2 (permalink) |
Product Supporter Join Date: May 2001
Member: 4566 Status: Offline Sonork: 100.112355 Thanks Meter: 503 | 1 Install HWK_Support_Suite_Setup_v02.06.000.exe, then update HWK if needed. Do not close this window yet. 2.Install HWK_Support_Suite_Setup_v02.06.000.exe |
11-03-2007, 09:10 | #4 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Proud To Be A Muslim Age: 38
Member: 434968 Status: Offline Sonork: 100.1590883 Thanks Meter: 580 | no Error installing properteis change no Error installing properteis change color and win 95 to change 2000....ok solution..... |
11-03-2007, 12:50 | #6 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: Now inside NHL-2NA Age: 50
Member: 115864 Status: Offline Thanks Meter: 8 | Quote:
11-03-2007, 14:25 | #8 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: KERALA,INDIA Age: 38
Member: 597241 Status: Offline Sonork: 100.1575009 Thanks Meter: 85 | Quote:
i have also same complaint any know a good solution for this complaint? \pls help me.............................any one | |
11-03-2007, 16:17 | #9 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Nigeria, Oyo state Age: 48
Member: 180091 Status: Offline Thanks Meter: 62 | i have the same problem here too. "can not continue installation,report to support forum" @Odia pls help with this problem or realese a tested and error free suite for all platform of operating system(OS) most esspecially XP service pack2, unlimited and vista. |
11-03-2007, 16:24 | #10 (permalink) |
Member: 4566 Status: Offline Sonork: 100.112355 Thanks Meter: 503 | Have you tried doing this already? 1. Install HWK_Support_Suite_Setup_v02.06.000.exe, Run Update client then update HWK if needed. Do not close this window yet. 2. Install HWK_Suite_Setup_v02.06.000.exe |
11-03-2007, 18:03 | #12 (permalink) | ||||
Freak Poster Join Date: Jul 2005 Location: In Front All of You Guys
Member: 166078 Status: Offline Thanks Meter: 21 | Quote:
B.R "DOGLAG" | ||||
11-03-2007, 20:54 | #13 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: Romania Brasov Age: 45
Member: 25136 Status: Offline Sonork: 1591036 Thanks Meter: 54 | Quote:
And were is the solucion? I have 2 P.C. In one work and in the other not work. I uninstall the old soft , install first hwk update and second hwk 2.6 and work in first pc. Wen i try install hwk update in other pc give this error with usb driver new. I try install and uninstall drivers separatly but not work. I transferr the copy with SarasSoft in other pc and work good. Sorry for my english! | |
11-04-2007, 05:55 | #14 (permalink) | |
THIS FOR SOLVED THE PROBLEM FOR ALL OF YOU: 1. Uninstall Old HWK Suite. 2. Install HWK_Support_Suite_Setup_v02.06.000. 3. Run HWK_Support_Suite_Setup_v02.06.000. 4. Click on Next on main window of HWK_Support_Suite_Setup_v02.06.000 (Anactive Internet Connection is Required). 5. When HWK_Support_Suite_Setup_v02.06.000 finishes its process then leave it alone, dont click on "Start HWK update" at this time. 6. Go to C:\Windows\Prefetch and delete all files inside the Prefetch folder (for step 6 you can do it or not no problem). 7. Now Install HWK_Suite_Setup_v02.06.000. 8. This time hopefully HWK_Suite_Setup_v02.06.000 will go smoothly without any error. 9. When HWK_Suite_Setup_v02.06.000 finishes its instllation then go back to HWK_Support_Suite_Setup_v02.06.000 already opened window and click on Quit. 10. Now new setup should be insalled successfully. At this time you may use any of HWK modules without any error. 11. Uninstall old usb driver restart your windows xp sp2 after that put or find new usb driver for your box (C:\Program Files\SarasSoft\UFS\UFS_USB_Driver) and run update client to update your box until update succesfully completted. NB: AFTER COMPLETE INSTALL HWK_Support_Suite_Setup_v02.06.000 AND HWK_Suite_Setup_v02.06.000 finishes without any error of HWK modules BEFORE YOU CONNECT TO "Official HWK Support Area" YOU TRY TO RUN "SeDBx" FIRST AND CONNECT YOUR BOX WITHOUT ANY ERROR AGAIN AND DON`T CLOSE IT. NOW RUN "Official HWK Support Area" THAT WILL DETECTED YOUR HWK ORI ID AND YOU CAN ENTER SUPPORT AREA WITHOUT PROBLEM OR DATA ERROR. GO SUPPORT OR FOR LOGIN "Official HWK Support Area" OR http://sarunasoftware.com/supportlogin.html (INTERNET EXPLORER ONLY). TESTED 100% BY ME. THAX`S TO HWK TEAM. BRAVOO!!!! B.R "DOGLAG" | |
11-04-2007, 08:00 | #15 (permalink) | |
I cant install HWK_Support_Suite_Setup_v02.06.000 becose give this error. I have 2 sistems in this PC one new with out another install but not work. I try install v2.5 and the same problem with usb new error. | |
installation HWK_Suite_Setup_v02.06.000 erorr | Miftahudin | HWK | 4 | 01-11-2008 11:26 |
Tested and 100% solution to install new HWK_Suite_Setup_v02.06.000.exe | Unlocker AL | HWK | 23 | 12-21-2007 01:54 |
HWK_Suite_Setup_v02.06.000 Installation Error | Aazib jhon | HWK | 4 | 11-30-2007 02:40 |
UNKNOWN ERROR WITH HWK_Suite_Setup_v02.06.000 | outlandier | HWK | 3 | 11-30-2007 00:43 |
100% HOW TO INSTALL HWK_Suite_Setup_v02.06.000 | HZZORY4GSM | HWK | 2 | 11-21-2007 08:24 |
