11-05-2008, 20:31 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: On Earth
Member: 266339 Status: Offline Thanks Meter: 99 | Problem flashing nokia 1650!!! I receive a 1650 that is not powering on (why?? customer does not know). I try to flash it but it fails to extract CONTENT. Here is Log 1st Boot: Ok, DCT4, UPP: 2292 [Rm-305] [2.0.8.0] 2nd Boot: u3_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x01FFFFFF,0001327E,Amd 29NS128P Algorithm: u3_amd.fia, Ver: 4.76.0 Algorithm Ok, MSID: 849A9464AFBF1A462AB0A035AE Decoded MSID: 3E4EBAE9-00D83993-A8000000 Encoded FAID: 71BEA219-36C8B717-EC2276EC IMAGE: rm305_04.110 Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00 Area2: 0x01010000-0x0179FFFF Erased, Time: 00:43 Area3: 0x017A0000-0x017EFFFF Erased, Time: 00:02 Area4: 0x01F00000-0x01FDFFFF Erased, Time: 00:05 MCU Flashing Completed, Time: 00:49 IMAGE: rm3050_nai4.11ad Area1: 0x01760000-0x0179FFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:04 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Any suggestion how to go ahead is welcome. BR |
The Following User Says Thank You to benarmand For This Useful Post: |
11-05-2008, 21:05 | #3 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 463420 Status: Offline Thanks Meter: 150 | Try delete the phone and reflash again. I have this problem with many dct4+ sometime when is dead can't go in test/local mode (if not in local mode box can't detect the phone and white cnt and ppm. Regards Chimeto! |
The Following User Says Thank You to chimeto For This Useful Post: |
11-06-2008, 06:07 | #4 (permalink) |
No Life Poster Join Date: May 2007 Location: .::Rawalpindi::.
Member: 500844 Status: Offline Sonork: 100.1680109 Thanks Meter: 285 | Ersase Hay man just erase the first n den check ur files secelt in ppm file ia n cnt image ia den if set pro there den u give the power where he doesnt work pick the image file via charger try it may be help |
11-06-2008, 08:21 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | While the process of cnt extracting starts press power button few times. You can also try by marking/unmarking "Use Ini file settings", else it's hardware. |
11-06-2008, 08:47 | #7 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bareilly(U.P) Age: 50
Member: 405715 Status: Offline Thanks Meter: 271 | Quote:
reflash with firmware 5.30,5.32 or later 5.51 try and post reply wbr shoeb | |
problem in nokia 1650 | ranagaurav | HWK | 9 | 08-09-2010 15:53 |
problem flash nokia 1650 | bassemzini | Nokia Hardware & Hardware Repair | 10 | 09-07-2009 15:10 |
problem i nokia 1650 | ranagaurav | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 06-12-2009 03:59 |
Problem with Nokia 1650 patched firmware or downgrade?? | mtb116 | Universalbox | 3 | 03-18-2009 00:49 |
Strange Problem In Nokia 1650 Rm-305 | tarikalikhan | Nokia Hardware & Hardware Repair | 0 | 04-28-2008 18:04 |
