Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 07-03-2008, 08:21   #1 (permalink)
Member: 32847
problem with "Init SimLocks"
after "Init SimLocks" the software automaticly set "Full Factory Defaults"...
Old 07-03-2008, 08:35   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Re-install the whole set up, may be it helps you.
Old 07-03-2008, 09:03   #3 (permalink)
Member: 32847
in this situation re-install can't help,
after operation "UI Settings" software get settings from ini file, and repeat "UI Settings" operation with settings from ini file, in older versions this problem not present
Old 07-03-2008, 09:24   #4 (permalink)
GsmMunna's Avatar
Member: 66937
Sonork: 100.93433
Arrow
You Are Right..!! Also Un-Check Ini Then make Setting's..!
Munna.
The Following User Says Thank You to GsmMunna For This Useful Post:
Old 07-03-2008, 09:39   #5 (permalink)
Member: 597688
write new version after flashing tick only "Init SimLocks" and press UI setting button
Old 07-03-2008, 09:42   #6 (permalink)
Member: 541591
Sonork: 100.1611509
Or only Double-Click on Init Simlock
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 07-03-2008, 09:52   #7 (permalink)
Member: 32847
Munna.
Yes!!!
Thank you!!!
Problem with unlocking Samsung E1080 ..::alexis::.. HWK 18 09-25-2011 14:23
big problem with my mx key sshreesai MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-31-2010 10:07
problem with Z3x lg activation Sioma allGSMunlock MultiOnline Remote Server 4 03-29-2010 17:55
problem with nokia 6234 pachicoo Universalbox 2 03-29-2010 15:19
.: Strange Problem with T610 power on with p-supply but never with battrey :. Jani-Jan Sony Ericsson Hardware Repair Area 5 05-25-2004 16:31
Page generated in 0.27544 seconds with 11 queries
