12-15-2006, 09:15 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | Problem Install V3.0.3 i have a new original hwk but when i install in win98 only samsung, motorola, can open, the others open and dissappear one second after. this with ufs setup versions V3.0.1; V3.0.2; V3.0.3, i have the same result. only V3.0.0 open and work normaly. on Win XP, none on those versions can't even open. with V2.0.2 i have some strenght message like "unknow razka 20$........" sometimes i even have " devices not compatible with this software. so what i can do? |
12-21-2006, 07:27 | #7 (permalink) |
No Life Poster Join Date: Dec 2003 Age: 36
Member: 47281 Status: Offline Thanks Meter: 17 | Mr odia is right. You need to revert back to old firmware. You can achieve this by asking your reseller fbi file for first firmware. This will help, if not see below Is your hwk 1.04A? If yes,you need to upgrade box firmware to latest. Cheers, YAsir |
12-21-2006, 10:28 | #8 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | yes my hwk is 1.04A. i think it was a windows install problem. because i format my pc and reinstall xp pro not xp sp2 again it connect and work with last version 3.0.3. now only win98 not work with those version 3.0.1; 3.0.2; 3.0.3 only samsung and motorola soft can open there. nokia, Lg etc.. open and close after 1 second but v3.0.0 work perfetly on that win98. |
12-21-2006, 11:02 | #9 (permalink) |
No Life Poster Join Date: Jun 2006 Age: 54
Member: 296018 Status: Offline Thanks Meter: 74 | Pour ceux qui veulent tenter la nouvelle V03.03.000 IMPORTANT sauvegardez ces trois fichiers cachés C:\ NTDETECT.COM , ntldr et boot.ini avant d'installer la suite et ensuite recopiez les sur C:\ AVANT de redémarrer rebooter ensuite vous pouvez les utiliser et les cracker |
12-21-2006, 11:49 | #10 (permalink) |
Registered User Join Date: Dec 2005 Location: Syria
Member: 212458 Status: Offline Thanks Meter: 3 | I have hwk crack ... When was the issuance of the new 3.3. The works were dependent system Windows? Format and work to the computer. Note that the second problem is about the destruction of the telephone after work Flash! I do not have the solution ? |
12-29-2006, 18:18 | #12 (permalink) |
No Life Poster Join Date: Jan 2006 Location: india Age: 45
Member: 216088 Status: Offline Thanks Meter: 43 | i had same problem 2day i had bought hwd original have problem install my ufs setup v3.0.1 ; v3.0.2; v3.0.3 ; i have a new original hwk but when i install in win98 only samsung, motorola, can open, the others open and dissappear one second after. this with ufs setup versions V3.0.1; V3.0.2; V3.0.3, i have the same result. only V3.0.0 open and work normaly. can any body guide me what to do . . . |
12-30-2006, 08:32 | #13 (permalink) | |
Member: 47281 Status: Offline Thanks Meter: 17 | Quote:
registration for merriam webster v3.0.3 | ervie9 | Nokia Multimedia | 6 | 03-07-2015 05:46 |
HWK Replacer V3.0.3.001 | gsmfun | Twisterflasher | 16 | 11-11-2010 10:33 |
>>> GRIFFIN MASTER INSTALLER v3.0 <<< | adam5589 | Griffin | 76 | 09-25-2008 04:53 |
I Need Hwk V3.0.3 | haroun02 | HWK | 1 | 03-28-2008 13:57 |
Problems with v3.0 and 3.0.1 | yeldar | NSPRO | 11 | 07-09-2005 17:44 |
