09-28-2008, 16:21 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: chattisgarh,India
Member: 578941 Status: Offline Thanks Meter: 108 | problem installing hwk 2.0.8 says when tried to hwk suite setup 2.0.8 and when tried hwk support suite in upgrade clint it says Upgrade log: ---------- HWK Update Client v 2.0.8.0 ---------- ---------- HWK upgrade started:9/28/2008 8:42:01 PM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : ###### -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: N-BOX -- HWK ID : A1.04-PRO1-0C4DD227416000BF -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller. wats the problem |
09-28-2008, 16:26 | #2 (permalink) |
No Life Poster Join Date: Feb 2006 Location: P A K I S T A N Age: 42
Member: 237155 Status: Offline Thanks Meter: 415 | first of all remove old ufs setup and support setup then install hwk support setup 2.0.8 then open hwk update client but do nothing.and close the soft. now double click on attached registry entry named "2.0.8" now open hwk update client again,and login in the soft. now run hwk setup 2.0.8 and complete the installation. now open dctxbb5 program and try to connect, it will say "none authorized copy of software" exit the program,and then run hwk setup again, when prompted to remove repair or modify, choose repair and click on next. congratulations.you have done... |
The Following 34 Users Say Thank You to quasim0438 For This Useful Post: |
10-19-2008, 09:08 | #3 (permalink) |
Crazy Poster Join Date: Apr 2008
Member: 757447 Status: Offline Thanks Meter: 12 | And if "HWK: NOT AUTHORISED, USE UPDATE TOOL" is it can be done with this trick? Maybe not, becasue all tips and steps that i've found in this forum can not solve my problem. Actually this is what i've done : 1. Doing update with support suite 2.0.8 and failed and 2nd update got bad messages " No More Logs" 2. And try back to 2.0.7 version the messages above appear in program. 3. Already wait for 3 (three) days... but still got the same messages. Strange.... what is the bad thing that can happen to sarassoft team if all the way is easier for *******rs? I've 2 (two) box in hand. 1 for service and the other for try and error like today... Thanks |
10-20-2008, 11:11 | #4 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: near Network Age: 48
Member: 185608 Status: Offline Thanks Meter: 592 | All done! Quote:
So slow down!Uninstall all UFS drivers ,Clean your registry.If ok read M Odia post:ALL WILL BE OK! | |
11-05-2008, 10:26 | #8 (permalink) |
Major Poster Join Date: Jan 2007
Member: 439766 Status: Offline Thanks Meter: 3 | bro uninstall all your ufs files including the usb driver then restart your pc and then do install again here's my y.m: MartinLouie_1982 just message me if you still got some errors..thank you |
11-07-2008, 07:47 | #9 (permalink) |
Insane Poster Join Date: Nov 2007 Location: Guadalajara Age: 36
Member: 636659 Status: Offline Thanks Meter: 20 | hello quasim0438 nothing more to tell you that the procedure you wrote is the # 1 to run the HWK to work for me and my thanks to your procedure thank you very much quasim0438 everything works properly |
11-08-2008, 10:01 | #11 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 620684 Status: Offline Thanks Meter: 12 | @like that ok You need file reg.fbi to solve your problem. Try to read in this link. http://forum.gsmhosting.com/vbb/showthread.php?t=370992 |
11-20-2008, 23:28 | #12 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 52
Member: 174847 Status: Offline Thanks Meter: 5 | I have two UFS boxes , one working great the other not The one that is not working i get box auth error 32 problem I have tried the steps on the forum , but still cant seem to solve the problem. I have tried on several machines with XP and vista , but still working Any help i really would appriate it many many thanks |
11-25-2008, 14:44 | #14 (permalink) | |
Crazy Poster Join Date: Jul 2002 Location: Poland
Member: 14155 Status: Offline Thanks Meter: 0 | Quote:
11-27-2008, 10:06 | #15 (permalink) | |
Junior Member Join Date: Nov 2006 Location: Lithuania
Member: 383743 Status: Offline Thanks Meter: 0 | Quote:
That's the man! Your stuff is working, thanks a lot!!! | |
