03-21-2008, 12:43 | #1 (permalink) |
No Life Poster Join Date: Oct 2001 Location: RO Age: 48
Member: 6738 Status: Offline Sonork: 100.81405 Thanks Meter: 10 | Problem installing last update 02.07 hwk if try to use support - link seems not to work. i have downloaded latest hwk from rapidshare but when i try to install it says: Install noth authorised, please download and install Hwk Support suite and update with latest client and retry main install. ClientCompare. |
03-21-2008, 12:52 | #3 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 444805 Status: Offline Thanks Meter: 45 | uninstall previous hwk version 2.0.6 etc.... procedures how to remove properly 1. uninstall hwk suite setup 2. uninstall hwk support suite setup then install new software hwk 2.0.7 then follow the procedures br |
03-21-2008, 12:58 | #4 (permalink) |
Member: 6738 Status: Offline Sonork: 100.81405 Thanks Meter: 10 | i have uninstalled 2.06 properly i think - or what do you mena properly execpt by going to control panel add remove software and removing both options, after restart.. you know some trick in registry? if i follow exactly the procedures that is what is happening. |
03-21-2008, 13:55 | #5 (permalink) | |
Member: 444805 Status: Offline Thanks Meter: 45 | Quote:
03-21-2008, 14:08 | #6 (permalink) |
Freak Poster Join Date: Apr 2004
Member: 63310 Status: Offline Thanks Meter: 5 | I had the same Problem with 2.06 and nobody in this Forum could help, The PS were not even bothered, now I installed 2.07 and the same problem. It runs on one Laptop, but not on the Office Machine were it is supposed to be...... This Machine is running a dual Boot with a clean Windows Install on the Partion I want HWK Suite, did erything according to Instructions and I get the same Message as hridaya above....... So much for the long awaited Update, is there any PS here that can offer some help ??? |
03-21-2008, 14:08 | #7 (permalink) |
Member: 6738 Status: Offline Sonork: 100.81405 Thanks Meter: 10 | i have looked but still same problem i made all steps.... of course hwk it says it is already upgraded there is no need to upgrade once again. and when i give setup i receive that message. Install noth authorised, please download and install Hwk Support suite and update with latest client and retry main install. ClientCompare. |
03-21-2008, 15:21 | #10 (permalink) | |
Registered User Join Date: Jan 2007 Location: South Africa/Pakistan
Member: 437195 Status: Offline Thanks Meter: 1,734 | Quote:
first run update client Start HWK update when HWK update successfull. then install new setup. it's 10000000000000% solution. tested from me............ | |
03-22-2008, 11:46 | #11 (permalink) |
Member: 63310 Status: Offline Thanks Meter: 5 | @ Shakeel, you don't have this problem, I am telling you tested by myself and obviously Hrydaya, its not working !!! My HWK is updated and runs fine on one Machine, while on the other Machine I cannot install the HWK Suite Software. Support Suite is installed and HWK Update Client tells me HWK is up to date !! So please don't tell us about your 10000000000% Solution for a problem you never had ........... I had the same Problem on the same Machine (with 2.06 (could not run the Modules, now I cant install), and hoped the update would sort the problem out........... Where are the Answers from the PS odia or Munna or Fractilizer ???? |
03-22-2008, 12:15 | #12 (permalink) | |
No Life Poster Join Date: Jan 2005
Member: 104066 Status: Offline Thanks Meter: 62 | Quote:
may be somes bugs in soft i have same problem in my Laptop Toshiba, but in my Desktop Compaq all is ok | |
updat 02.07.000 my hwk dead | w850 | Nokia Base Band 5 ( BB-5 ) | 0 | 03-26-2008 03:19 |
Rapidshare link(fast) for last update 02.06.000 | jawad8305 | HWK | 0 | 11-01-2007 14:07 |
cant install last update to my mt-lite box | kifah | MT-BOX | 3 | 10-18-2007 11:38 |
PC shuts down when try to install last update | gsmtronica | HWK | 20 | 05-23-2007 21:32 |
