Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 03-29-2010, 17:37   #1 (permalink)
..::alexis::..'s Avatar
Member: 289200
Thanks Meter: 219
Problem with unlocking Samsung E1080
With original Eeprom phone show:
Image File: 25E1080_358698-03-xxxxxx-1_E2P.bin
File Size: 524288 byte(s) [0x00080000]
E2P Info:
IMEI: 358698-03-xxxxxx-1
REG.FIRMWARE: E1080APIL1_T1
SIMLOCK STATUS: 0000
MCC-MNC: 2F0-700
Extended:
SIMLOCK STATUS: 0003
MCC-MNC: 262-07
#SIMLOCK*NET*81729510#
I have read and enter Network lock code
But phone is still locked. It ask Provider code(by *#7465625# Subset lock is active)
Now by Reading and checking Eeprom software show only:
Image File: E1070_358698-03-xxxxxx-1_E2P.bin
E2P Info:
MCC-MNC: 000-000
After writing unlocked Eeprom phone is unlocked, but this is not comprehensible to me, because after this I can't repair it to original IMEI.
Is it possible to unlock this phone?
Old 03-31-2010, 00:58   #2 (permalink)
Member: 289200
Thanks Meter: 219
Someone help?
Like no one didn't see this thread...
Old 03-31-2010, 12:35   #3 (permalink)
cover_one's Avatar
Member: 97299
Thanks Meter: 37
Originally Posted by ..::alexis::.. View Post
Someone help?
write back your original eeprom reset with *2767*3855# use U*S*T set as c270 uncheck test mode use combo e210 with usb and rj45 pluget in read codes
Old 03-31-2010, 12:57   #4 (permalink)
Member: 289200
Thanks Meter: 219
Usb cable with this phone?
I haven't UST!
I ask in UFS section, so I try to fix this problem by UFS.
Old 03-31-2010, 13:28   #5 (permalink)
f164's Avatar
Member: 184351
Thanks Meter: 215
only code reading and flashing eprom function like imei repair not supported so it is limited support
Old 03-31-2010, 13:34   #6 (permalink)
DIGITAL BABU's Avatar
Member: 420857
Sonork: 100.1576793
Thanks Meter: 1,734
*7465625*782*81729510# = enables subset lock
#7465625*782*81729510# = disables subset lock
dB
Old 03-31-2010, 15:35   #7 (permalink)
Member: 289200
Thanks Meter: 219
dB
Code 81729510 work only or #7465625*638*81729510#
For *782* phone write "Wrong password"
Old 03-31-2010, 22:42   #8 (permalink)
cover_one's Avatar
Member: 97299
Thanks Meter: 37
there are 3 codes , ex:
81729510
xxxxxxxxx
xxxxxxxxx
need to be used the first and the last one .
p.s. yes e210 combo cable you need to use rj45 but usb need to be connected to pc in order to read the codes .
just give a tray
Old 03-31-2010, 22:58   #9 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 454
this phone cant unlock whith HWK .
i tested in new update and not unlocked .
but i unlock it whith USTPRO II very easy.
lahdache
Old 04-01-2010, 00:02   #10 (permalink)
utsav_jayesh's Avatar
Member: 314847
Thanks Meter: 102
use cable not work for e1080 it's guru seriz mobile just try with rj45 cable.
Old 04-01-2010, 01:32   #11 (permalink)
Member: 289200
Thanks Meter: 219
lahdache
I haven't UST PROII!
Yes of cource, I use ordinary E210 RJ cable
Old 04-01-2010, 01:54   #12 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 474
phone with sim card inserted and read code with finish enter insported sim card and enter code manuly
it the ferst ur unlock is 81729510 try and give report
Old 04-11-2010, 01:01   #13 (permalink)
Member: 289200
Thanks Meter: 219
Can you say me- you read all my posts? For what you write useless posts?
Old 04-11-2010, 06:56   #14 (permalink)
GsmMunna's Avatar
Member: 66937
Thanks Meter: 5,043
Arrow
Extended:
MCC-MNC: 262-07
MASTER: 33543180
#SIMLOCK*SUB*34662550#
#SIMLOCK*SP*00000000#
#SIMLOCK*CP*00000000#
Munna.
Old 04-11-2010, 19:56   #15 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,024
Exclamation
Originally Posted by GsmMunna View Post
Extended:
MCC-MNC: 262-07
MASTER: 33543180
Munna.
He know, I PM him already
Odia.
problem with unlock SAMSUNG E1120 keygamer Z3X-Team Products 1 03-25-2010 18:12
problem with unlock NCK samsung allunlock89| Universalbox 1 01-29-2010 18:22
Samsung T239 problem with unlock rafauz UST Pro II 10 09-18-2009 11:46
Problem with unlocking samsung softbank 920sc sshabbir UST Pro II 0 08-02-2009 16:42
problem with unlock samsung p910 with read codes elvan121 KULANKENDI Server 5 12-31-2007 14:02
Page generated in 0.44799 seconds with 9 queries
