Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 02-02-2006, 23:19   #1 (permalink)
Member: 78236
Thanks Meter: 3
Product Selection Mismatch
I'm flashing 6630. Anyone got a useful idea on this error. Deeply appreciated!!!
The Following User Says Thank You to jjfox04 For This Useful Post:
Old 02-03-2006, 16:01   #2 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 24,024
Maybe you can try manual flash "Flash" instead of "Start", can you read the info from this phone and post here?
Odia.
Old 02-03-2006, 18:23   #3 (permalink)
Member: 78236
Thanks Meter: 3
Yes, I can read info as attached. I did the manual flash button, and still product selection mismatch. It can even suceed on "UI Factory Defaults" but failed on "Full Factory Defaults" and "Full UI Defaults". Maybe a hardware fault but I have no concrete idea so I need help from experts. Pls help.
Old 02-04-2006, 05:56   #4 (permalink)
Member: 4042
Can you put the phone into test mode and read the info again and post it here.
Odia.
Old 02-06-2006, 09:05   #5 (permalink)
Member: 203352
Sonork: 100.1609650
Thanks Meter: 244
this is hardware prob re flow the cmt
Old 02-06-2006, 11:42   #6 (permalink)
sky178's Avatar
Member: 15217
Thanks Meter: 20
when i press chech this message is appear,
1st BOOT : C0,07
RAP3 ID : 000000010000022600010006000C192101002100
EM 1 ID : 00000232
EM 2 ID : 00000341
RAP3 PBID : 0750011106AE4F5739731E0882F99D50120823DB
RAP3 MODE : 00
RAP3 HASH : E9EFF4BFAA5393217CA6B17755FC3E1401000000
RAP3 ROID : F28A211FAC901AEE
CMT 1st Boot Ok
Rebooting Mobile
but when info all thing is right:
MCU Sw: V 04wk47v36 14-04-05 RM-1 (c) Nokia.
APE Co:
APE Va:
Prd.Cd: 0518142
Bpr.Cd: 0600395
Pro.Sn: UD0561960
HW : 6100
APE Hw:
APE Ad:
PCI :
RETU : 32
TAHVO : 41
RFIC : 150a160e
DSP : 04w47v20
LCD :
IMEI : 356657-00-888939-3
Old 02-06-2006, 13:16   #7 (permalink)
Member: 90865
1st BOOT : C0,07
EM 1 ID : 00000232
EM 2 ID : 00000341
RAP3 MODE : 00
CMT 1st Boot Ok
Rebooting Mobile
APE Co:
APE Va:
Prd.Cd: 0518142
Bpr.Cd: 0600395
Pro.Sn: UD0561960
HW : 6100
APE Hw:
APE Ad:
PCI :
RETU : 32
TAHVO : 41
RFIC : 150a160e
DSP : 04w47v20
LCD :
No, there should be more than that. APE Co and APE Va should be filled in at least, probably others too. Try info again and see if it appears on a second click without touching anything.
WolfMan
Old 02-06-2006, 14:17   #8 (permalink)
Member: 78236
Thanks Meter: 3
Odia.
Unfortunately, the client pulled out his 6630 from my shop already. Big thanks, Odia The Ultimate. I do appreciate your intention to help. Thanks a lot and more power!!!
Old 02-07-2006, 03:50   #9 (permalink)
Member: 4042
WolfMan
Some data for BB5 is not available in local mode, thats why I asked him to put the phone in test mode.
@jjfox04
Sorry to hear that (
Odia.
Old 02-07-2006, 12:25   #10 (permalink)
Member: 90865
Odia.
I nearly always see this on first click of Info, one more click and it appears though, so is that what you'd expect? I thought this was to do with the power up sequence, the second time there is power from the word go and the phone behaves as it should.
WolfMan
Old 02-07-2006, 13:44   #11 (permalink)
Member: 4042
WolfMan
Two different issues, what your talking about here is that the phone has not entered local mode fully.
Odia.
Old 02-08-2006, 07:29   #12 (permalink)
sky178's Avatar
Member: 15217
Thanks Meter: 20
after check:
1st BOOT : C0,07
EM 1 ID : 00000232
EM 2 ID : 00000341
RAP3 MODE : 00
RAP3 HASH : E9EFF4BFAA5393217CA6B17755FC3E1407000000
CMT 1st Boot Ok
Rebooting Mobile
local mode:
1st BOOT : C0,07
EM 1 ID : 00000232
EM 2 ID : 00000341
RAP3 MODE : 00
CMT 1st Boot Ok
Rebooting Mobile
Init Local Mode Failed
Old 02-08-2006, 10:36   #13 (permalink)
Crazy Poster
Member: 230396
after check:
1st BOOT : C0,07
EM 1 ID : 00000232
EM 2 ID : 00000341
RAP3 MODE : 00
CMT 1st Boot Ok
Rebooting Mobile
local mode:
1st BOOT : C0,07
EM 1 ID : 00000232
EM 2 ID : 00000341
RAP3 MODE : 00
CMT 1st Boot Ok
Rebooting Mobile
Sir you use jaf jaf is verey good job
Old 02-08-2006, 23:25   #14 (permalink)
Member: 90865
Odia.
Despite it saying Local Mode on the screen? I'll not claim to understand the detail, but I find that usually BB5 phones work better if a disconnect/connect is used. Power and signal sequencing I thought.
WolfMan
Old 02-16-2006, 20:13   #15 (permalink)
Siemens man's Avatar
Member: 3925
Thanks Meter: 21
hi guys
i have same problem with 6680 flashing. 6630 flashing without any problem. help me
thank you
error " product selection mismatch " in N70 nasro_nd Nokia Base Band 5 ( BB-5 ) 57 11-14-2011 15:26
6680 product selection mismatch? stampede UFS2 + UFS3-Tornadoflasher 4 08-01-2009 08:12
n70 product selection mismatch totalmanish Nokia Hardware & Hardware Repair 1 11-08-2006 14:50
n-70-1 flashing error product selection mismatch ashok_kumar459 HWK 0 09-13-2006 19:16
N70 power off i plug it in box twester say product selection mismatch جاسر مقدام Nokia Base Band 5 ( BB-5 ) 3 09-09-2006 07:06
Page generated in 0.48303 seconds with 9 queries
