06-16-2013, 14:03 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | s5270k flashed using s5610k selection-still in reboot-help Partition Table: S5270KODDLB1.ptt Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2012 February Rev: 1 PROD_ID: E955AB0D18761E0A SCROM_V: PNX6729 V.01.10 CHIPSET: 3C11 FL_VERS: 7.5.3 FL_CHIP: Samsung K522H1HACF [NAND 2G] NAND Read Done, 131072 byte(s), Time: 00:04 BOOT Ok, 460800 Baud Partition IMAGE Erase Done, 6 block(s), Time: 00:00 Partition LCDACT Erase Done, 1 block(s), Time: 00:00 Partition MAIN Erase Done, 144 block(s), Time: 00:00 Partition PAGED Erase Done, 64 block(s), Time: 00:00 Partition a Erase Done, 424 block(s), Time: 00:00 Partition b Erase Done, 264 block(s), Time: 00:00 Partition c Erase Done, 900 block(s), Time: 00:00 Partition d Erase Done, 160 block(s), Time: 00:00 Partition sysv File not Exists, Skipped Partition sysv_bk File not Exists, Skipped Partition IMAGE Write Done, 786432 bytes(s), Time: 00:24 Partition LCDACT Write Done, 131072 bytes(s), Time: 00:04 Partition MAIN Write Done, 15116288 bytes(s), Time: 07:47 Partition PAGED Write Done, 4282340 bytes(s), Time: 02:11 Partition a Write Done, 33960960 bytes(s), Time: 17:48 Partition b Write Done, 8312832 bytes(s), Time: 04:24 Partition c Write Done, 5945280 bytes(s), Time: 03:24 Partition d Write Done, 145728 bytes(s), Time: 00:04 Partition sysv File not Exists, Skipped Partition sysv_bk File not Exists, Skipped Partition BOOTNAND Write Done, 37120 bytes(s), Time: 00:01 but still my set in reboot at samsung logo.? why this model number not in hwk list? helppppppppppp-i have two sets similar problem. |
06-17-2013, 20:06 | #4 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Unnao, UttarPradesh
Member: 1289553 Status: Offline Thanks Meter: 57 | Try with this flasher for s5610k........ Or use any other tool.......samsung flashing toos |
06-17-2013, 21:20 | #5 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | Quote:
Another important point worth of mention is that some samsung files in the support section are not good enough and do cause such behaviours in phones as you have mentioned. | |
08-13-2013, 21:55 | #6 (permalink) | |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | Quote:
If Still This Phone In Your Hand Or If Some One Have Same Problem So Post Here. I Solve This Problem Today. | |
