06-09-2011, 17:20 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: India [UNKNOWN]
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | samsung c3010s flash writing problem 1st Boot Ok, McuId: 00050026, Rom: 00050026, 13-1.2 (Vision X113E) 2nd Boot Ok, McuId: 00050026, Rom: 00050026, 7-2.0 Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_v24_s05_2.sre Flash1: Fl_Id: 00890000_887E0000 - Intel SIBLEY 512 Baud Rate Set: 460800 bps MCU File: CODE_C3010SDDJC2.s3 Flashing NOR part... ErClos: rplyCLOS-erreom. Bad response: 0x002C, 6572 ErOpen: rplyOPEN-err Bad response: 0x002C, 6572 Write Failed at: 0x21844000 |
The Following User Says Thank You to MOHIT_THAREJA For This Useful Post: |
06-10-2011, 07:32 | #5 (permalink) |
Member: 1143809 Status: Offline Sonork: 100.1602432 Thanks Meter: 574 | i alos try with usb connection but same problem after 90% mcu then same error Region: 1, 0x20000000-0x20000063, Length: 100 bytes Region: 2, 0x2000C000-0x20011403, Length: 21508 bytes Region: 3, 0x20016000-0x2001C59B, Length: 26012 bytes Region: 4, 0x2001E000-0x2001E0B3, Length: 180 bytes Region: 5, 0x2003803C-0x20040ED7, Length: 36508 bytes Region: 6, 0x20058000-0x20058037, Length: 56 bytes Region: 7, 0x20058138-0x2005CC7D, Length: 19270 bytes Region: 8, 0x20078000-0x2018C173, Length: 1130868 bytes Region: 9, 0x20300000-0x21AB9287, Length: 24875656 bytes USB Boot Ok, McuId: 00050026, Ubl: E5922058, 7-1.1 (Vision X113E) Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_usb_s09.sre Flash1: Fl_Id: 00890000_887E0000 - Intel SIBLEY 512 MCU File: CODE_C3010SDDJC2.s3 Flashing NOR part... ErClos: rplyCLOS-erreom. Bad response: 0x002C, 6572 ErOpen: !eom. Bad response: 0x001C, 0080 Write Failed at: 0x21850000 |
06-10-2011, 07:41 | #6 (permalink) | |
Freak Poster Join Date: Oct 2009 Location: {INDIA * UAE}
Member: 1134306 Status: Offline Thanks Meter: 133 | Quote:
USE THIS FLASHER AND FLASH FILE I UR PROBLEM WL BE SOLVE I HV TASTED MANY TIMES C3010S TESTED FLASH FILE AND FLASHER.rar - 4shared.com - online file sharing and storage - download | |
06-10-2011, 16:14 | #9 (permalink) |
Major Poster Join Date: Mar 2007
Member: 473140 Status: Offline Thanks Meter: 2 | s3010s flashing problem Selected model: C3010S Selected com port: COM22 Selected speed port: 460800 Decode *.s3 file - please wait segments 9 segment 1 20078000 1130076 byte segment 2 2000C000 21416 byte segment 3 20058000 56 byte segment 4 20058138 13890 byte segment 5 2003803C 36508 byte segment 6 20000000 100 byte segment 7 20300000 23828856 byte segment 8 2001E000 180 byte segment 9 20016000 26012 byte Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader 1... OK Syncing phone... OK Sending loader 2... OK Syncing phone... OK Syncing phone... OK Flash ID: 890000007E88 Syncing phone... OK Sending *.s3 file... OK Sending *.cts or *.csc file... Detected file - > 132 Format FFS - wait... OK Send content - wait... bad ask - +ok! Send cts - fail Elapsed time: 1108 second, sw ver: 3.5.0011 |
06-20-2011, 07:43 | #10 (permalink) |
No Life Poster Join Date: Jul 2007 Location: kolkata, india
Member: 553420 Status: Offline Sonork: 100.1624012 Thanks Meter: 129 | same problem with me ....is it hwk problem or what????? plz help urgent.............set dead by flashing erroro with hwk.......... |
07-13-2012, 17:04 | #11 (permalink) |
Junior Member Join Date: Apr 2012
Member: 1744662 Status: Offline Sonork: nanocare Thanks Meter: 0 | Selected model: C3010S Selected com port: COM22 Selected speed port: 460800 Decode *.s3 file - please wait segments 9 segment 1 20078000 1130076 byte segment 2 2000C000 21416 byte segment 3 20058000 56 byte segment 4 20058138 13890 byte segment 5 2003803C 36508 byte segment 6 20000000 100 byte segment 7 20300000 23828856 byte segment 8 2001E000 180 byte segment 9 20016000 26012 byte Phone must be OFF with battery Please, connect phone and press shortly power button Syncing phone... OK Sending loader 1... OK Syncing phone... OK Sending loader 2... OK Syncing phone... OK Syncing phone... OK Flash ID: 890000007E88 Syncing phone... OK Sending *.s3 file... OK Sending *.cts or *.csc file... Detected file - > 132 Format FFS - wait... OK Send content - wait... bad ask - +ok! Send cts - fail Elapsed time: 1108 s for this problem use usb with battery plus press* button in z3x |
10-25-2012, 13:04 | #12 (permalink) |
Crazy Poster Join Date: May 2012 Location: hoshiarpur punjab india
Member: 1758220 Status: Offline Thanks Meter: 7 | samsung c3010s flashing error with hwk Region: 1, 0x20000000-0x20000063, Length: 100 bytes Region: 2, 0x2000C000-0x200113AB, Length: 21420 bytes Region: 3, 0x20016000-0x2001C59B, Length: 26012 bytes Region: 4, 0x2001E000-0x2001E0B3, Length: 180 bytes Region: 5, 0x2003803C-0x20040ED7, Length: 36508 bytes Region: 6, 0x20058000-0x20058037, Length: 56 bytes Region: 7, 0x20058138-0x2005B779, Length: 13890 bytes Region: 8, 0x20078000-0x2018BE9B, Length: 1130140 bytes Region: 9, 0x20300000-0x21AB7F6F, Length: 24870768 bytes 1st: 1st: 1st: 1st: 1st Boot Failed: 1st Response |
08-14-2013, 06:53 | #14 (permalink) |
Freak Poster Join Date: Jul 2010 Location: india , Delhi
Member: 1346449 Status: Offline Thanks Meter: 56 | 100% sucess in z3x Selected model: C3010S Selected com port: COM469 Selected speed port: USB Decode *.s3 file - please wait segments 9 segment 1 20000000 100 byte segment 2 20300000 24739908 byte segment 3 2001E000 180 byte segment 4 20016000 26012 byte segment 5 20078000 1130148 byte segment 6 2000C000 21504 byte segment 7 20058000 56 byte segment 8 20058138 17528 byte segment 9 2003803C 36508 byte Start USB Flash Syncing phone... OK Sending USB loader... OK Syncing phone... OK Flash ID: 890000007E88 Syncing phone... OK Sending *.s3 file... OK Sending *.cts or *.csc file... Detected file - > 121 Format FFS - wait... OK Send content - wait... OK Elapsed time: 346 second, sw ver: 3.5.0040 insert batterry then press '*' button and connect micro uart cable then select usb port in port setting ....... |
08-19-2013, 11:09 | #15 (permalink) |
Insane Poster Join Date: Jul 2013
Member: 1975486 Status: Offline Thanks Meter: 0 | HI friends ! I am trying to flash my samsung s3010 with usb but when i try to conect it with my pc it shows unknown device even i press and hold * key while plugin USB . Please help me friends ............ |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
