10-27-2009, 13:52 | #1 (permalink) | |
No Life Poster Join Date: Mar 2007
Member: 470292 Status: Offline Thanks Meter: 147 | Samsung C3050 Unlock Problem Quote:
10-28-2009, 10:57 | #4 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: philippines now here in U.A.E Age: 38
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | Quote:
restart your pc then start it again info first your phone then unlock 100% tested on me regards: lilong lee | |
10-28-2009, 11:07 | #5 (permalink) |
Member: 1070665 Status: Offline Sonork: 100.1636802 Thanks Meter: 572 | Software: C3050DX Hardware: MP 0.401 Regions : Indonesia,Malaysia,Singapore,Thailand,Vietnam Language: en,id,ms,th,vi,zh(ta) Release : 2008 August Rev: 5 MSL Active S/N : R1XQB44760 IMEI: xxxxxxxxxxxx BTID: 00236:31ABF5 SIMLOCK STATUS: 0000 MASTER KEY: xxxxxxxx #SIMLOCK*NET*00000000# #SIMLOCK*SUB*00000000# #SIMLOCK*SP*00000000# #SIMLOCK*CP*00000000# #SIMLOCK*SIM*1325797 #SIMLOCK*AUSIM# #SIMLOCK*ACT# MSL Active MSL Active SIMLOCK STATUS: 0000 MASTER KEY: 14765879 SLOCK Reset, Ok Unlock Done see this unlock succesfully |
10-28-2009, 20:34 | #6 (permalink) | ||
No Life Poster Join Date: Feb 2005 Location: BAHOUAN
Member: 118601 Status: Offline Thanks Meter: 200 | Quote:
if i look well your log i see that your phone is not lock on any network but lock code when power on phone even without SIM CARD. i may wrong? so just do RESET MMI with phone power and your problem is going to be soft don't need flash. i resolve one similar case today but it was C3053 and i just select C3050. just see my log file. Quote:
10-29-2009, 07:13 | #7 (permalink) | |
Member: 470292 Status: Offline Thanks Meter: 147 | Not working Man I debranded and still having problem... Without sim it turns on and with simcard It shows Invalid simcard..Phone is locked..I also did reset mmi. Quote:
10-29-2009, 08:09 | #8 (permalink) |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | As lock level is 9. you need to enter 2x codes (NCK and SPCK)...! Munna. |
The Following User Says Thank You to GsmMunna For This Useful Post: |
10-30-2009, 20:57 | #10 (permalink) |
Member: 118601 Status: Offline Thanks Meter: 200 | very strange your situation but i unlock 02 C3050 today without any particular problem. just wait about 10mn to each one to calculate code then i enter it manually. when i look your log file i see that there is no worknet lock code there only look like phoe ask for phone with or without sim card! very curious your situation. |
11-01-2009, 05:56 | #13 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Hate stupidity
Member: 904530 Status: Offline Thanks Meter: 517 | where and what you enter exactly ? #0141*00000000# #0111*00000000# #0121*00000000# #0133*00000000# without sim card it cannot be quet, must reply somrthing about personalize Last edited by Major-T; 11-01-2009 at 06:02. |
11-02-2009, 05:03 | #14 (permalink) |
Member: 470292 Status: Offline Thanks Meter: 147 | When without sim I power on set it normally turns on. then I enter #0141*00000000# so it says Emergency calls only. And with sim card It shows Invalid sim card and when I enter code as above so nothing happen... |
11-02-2009, 06:19 | #15 (permalink) |
Member: 904530 Status: Offline Thanks Meter: 517 | very strange situation try to unfreeze #0199*00000000# if nothing happens reflash phone and you see correct imei then *#06# ? if not must rebuild msl |
Samsung c3050 unlock problem need help | jonel1983 | NSPRO | 10 | 09-24-2012 14:53 |
samsung c3050 unlock | sameer918 | UST Pro II | 2 | 11-12-2009 19:34 |
samsung c3050 unlock successfully | asif_ae | Easy-Unlocker | 1 | 10-25-2009 21:42 |
samsung c3050 unlock problem!!!! | tommyvo | UST Pro II | 1 | 07-14-2009 10:46 |
