Samsung c3222 restart after 100% flash I GOT SAMSUNG C3222 IN RESTATRT MODE AFTER SUCCESS FLASH ALSO IN SAME CONDITION........I HAVE CHAEKED IT BY HARDWARE BOARD IS TOTAL FRESH....AND ITS JAKE ALSO CLEAN....... I HAVE FLASH IT BY 3 OTHER FIRMWARES.... PLZZZ ANY ONE GUIDE ME SOLVE THIS PROBLEM.... HERE IS SCREEN SHOT http://img706.imageshack.us/img706/2921/samc3222.jpg |
if u have any other ok phone then read full flash from ok set and write and then check also try read e2p from ok phone and write in |
I have alredy WRITE e2p file.. thn also same prb...... |
then try full flash from read ok set and post result |
1st sure that phone is c3222 not c3222w if all is ok then flash with this file Quote:
my set is C3222 .....now let flash ur firmaware which u have given thn i will post result..... thanx for reply... |
c3222 cannot flash tfs and csc with hwk, only mcu and e2p for flash use original flasher, avalaible on support |
tested by me...........:) |
Thanx to all for reply......my prb solve............ |
bro how did you solve this can you explain here ? |
Thanx to all for reply |
I have same problem. after flash phone restart. any help ? |
Selected model: C3222 Selected com port: COM11 Selected speed port: 115200 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 32 second, sw ver: 3.5.0040 handset restart after flash |
HELLO, MARK ON THIS OPTION. AND FLASH IT, http://s23.postimg.org/wz8t5q77v/Capture.png THEN POST RESULT HERE. BR REHAN SHAIKH |
