02-23-2011, 17:27 | #17 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: INDIA Age: 38
Member: 186840 Status: Offline Thanks Meter: 103 | Quote:
my model is samsung c3303 i bought another new cable but still not work. i checked the cable has 130k resistor instead of 530k so i looked for 530k resistor from every where in mobile pcbs but couldn't find it any where. so atlast i tried connecting with 100ko+100ko+100ko+100ko+100ko+30ko=530ko but phone still not show any thing. i even tried with switch moving other way but not work. i tried another working phone also but not work. now what should i do? is there any buttons to press for boot mode? or it will go to boot mode it self just with connecting the cable? here are the hwk logs Connect Cable to Switched Off Mobile (with battery) TAT Canceled: 1 | |
03-02-2011, 22:39 | #24 (permalink) | |
Insane Poster Join Date: Dec 2007 Location: NIGERIA
Member: 645502 Status: Offline Sonork: 645502 Thanks Meter: 13 | Quote:
before you connect the phone to a HWK press vol. and camera, power so that the phone will boot in boot-loader then read mobile info first. and followed the procedure on the screen try it may be it help | |
03-03-2011, 11:10 | #25 (permalink) |
Member: 186840 Status: Offline Thanks Meter: 103 | i got it connected the problem was that i was trying the cable that was made by gpg dragon ufs uart samsung cable . and in last i tried the normal rj45 cable with micro usb pin now it worked perfect . thanks anyway no one could give me perfect solution for it so i finally contact with samrat singh and he gave me the solution for it thanx to him |
06-14-2011, 10:02 | #28 (permalink) | |
No Life Poster Join Date: Mar 2010 Location: south africa Age: 41
Member: 1269056 Status: Offline Thanks Meter: 1,114 | Quote:
The Following 2 Users Say Thank You to trust4eve83 For This Useful Post: |
06-26-2011, 20:34 | #29 (permalink) |
Freak Poster Join Date: Sep 2006 Location: gsmhosting Age: 45
Member: 352062 Status: Offline Thanks Meter: 35 | i test my cable with resistor 150k not work . then i change it with 560k ohm i get it in crad network , now my cable work fine this log : LOG Started: 26062011_193303 --------------------------------- Please Wait ... UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: ----- HID: ---------------------- HWK: --------------- Licence: True LogFile: .\_!_LOG\------_26062011_193303_LOG.txt Loaded Settings from: Sams.ini Connect Cable to Switched Off Mobile (with battery) Error in Versions Info Connect Cable to Switched Off Mobile (with battery) Error in Versions Info Connect Cable to Switched Off Mobile (with battery) Software: C3303KJPJG3 Hardware: MP 0.802 Regions : Arabic Language: ar,en,fr(fa,ur) Release : 2010 July Rev: 3 MSL Active S/N : RPWZ985306 IMEI: 353958-04-6------6 BTID: 101D:C0:AA65F8 MSL Active SIMLOCK STATUS: 0000 MCC-MNC: MASTER KEY: 38011160 NET 73273960, <BADSET> SUB 00000000, 00000000 SP 00000000, 00000000 CP 00000000, 00000000 SIM <UN_SET>, 00000000 ACT 00000000, 00000000 PLK <BADSET>, 00000000 MSL Active MSL Active SIMLOCK STATUS: 0000 MCC-MNC: MASTER KEY: 38011160 NET 73273960, <BADSET> SUB 00000000, 00000000 SP 00000000, 00000000 CP 00000000, 00000000 SIM <UN_SET>, 00000000 ACT 00000000, 00000000 PLK <BADSET>, 00000000 SLOCK Reset, Ok Unlock Done Connect Cable to Switched Off Mobile (with battery) Preloader Ok 08, 921600 Baud FLASH Id: SEC, K5N5629ATA [NOR 256Mb]+[NAND 1G] MCU Read Done, 2097152 byte(s), Time: 00:25, 0 E2P Info: HMEI: 353958-04-6------6 IMEI: 353958-04-6------6 E2P Saved as E:\Program Files\SarasSoft\UFS\UFS_SAMs\C3303\C3303_353958-04-676190-6_E2P.bin |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
