Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 02-05-2011, 17:07   #16 (permalink)
Member: 405911
Thanks Meter: 31
sure its a cable problem
i was unable to falsh and unlock c3303 but i ve bought a new cable from gpg and now its work perfectly
Old 02-23-2011, 17:27   #17 (permalink)
gautamlondon's Avatar
Member: 186840
Thanks Meter: 103
Originally Posted by Odia The Ultimate View Post
C3303 not need switch is Swift not Trident platform.
Odia.
dear sir
my model is samsung c3303
i bought another new cable but still not work. i checked the cable has 130k resistor instead of 530k so i looked for 530k resistor from every where in mobile pcbs but couldn't find it any where. so atlast i tried connecting with 100ko+100ko+100ko+100ko+100ko+30ko=530ko but phone still not show any thing. i even tried with switch moving other way but not work. i tried another working phone also but not work. now what should i do?
is there any buttons to press for boot mode? or it will go to boot mode it self just with connecting the cable?
here are the hwk logs
Connect Cable to Switched Off Mobile (with battery)
TAT Canceled: 1
Old 02-23-2011, 21:38   #18 (permalink)
piracik's Avatar
Member: 133762
Thanks Meter: 242
Try with - Nokia 6300 -> R2008 220k x2 + R2035 100k = 540k (by djm)
The Following User Says Thank You to piracik For This Useful Post:
Old 02-23-2011, 23:03   #19 (permalink)
aswancamel's Avatar
Member: 303402
Thanks Meter: 346
thanks, nice info
another way
u you can unlock with usb CA-101, but not WITH using HWK,
easy and fast....
btw,
UFS HWK, I LIKE
GOOD LUCK
ASWANCAMEL
Old 02-24-2011, 09:49   #20 (permalink)
Member: 186840
Thanks Meter: 103
Originally Posted by aswancamel View Post
thanks, nice info
another way
easy and fast....
btw,
UFS HWK, I LIKE
GOOD LUCK
ASWANCAMEL
i have ufs3 box and i kept hwk chip into it
Old 02-24-2011, 09:49   #21 (permalink)
Member: 186840
Thanks Meter: 103
i will check and post result
Old 02-24-2011, 10:03   #22 (permalink)
Member: 186840
Thanks Meter: 103
thanks, nice info
another way
easy and fast....
btw,
UFS HWK, I LIKE
GOOD LUCK
ASWANCAMEL
with usb ca-101 what else i will need?
Old 03-02-2011, 17:26   #23 (permalink)
Member: 186840
Thanks Meter: 103
sorry i bought z3x atlast
Old 03-02-2011, 22:39   #24 (permalink)
Member: 645502
Sonork: 645502
Thanks Meter: 13
Originally Posted by gautamlondon View Post
hello sir
i have samsung champ c3303
i bought samsung gpg cable rj45 miniusb name (ufs sam cable gpg)
i am trying to connect phone with hwk in off condition and on codition with batt and without batt but same error always
Partition Table: C3303DDJG3.ptt
TFS File: C3303DDJG3.tfs CRC32: F517CE1F
CFG File: C3303DDJG3.cfg 227012 byte(s)
1st Boot Failed:
FATAL_ERROR, Recovering
i have 3 phones working condition but they all not connect with hwk
i checked cable its ok
before you connect the phone to a HWK press vol. and camera, power so that the phone will boot in boot-loader then read mobile info first. and followed the procedure on the screen
try it may be it help
Old 03-03-2011, 11:10   #25 (permalink)
Member: 186840
Thanks Meter: 103
i got it connected the problem was that i was trying the cable that was made by gpg dragon ufs uart samsung cable . and in last i tried the normal rj45 cable with micro usb pin now it worked perfect . thanks anyway
no one could give me perfect solution for it so i finally contact with samrat singh and he gave me the solution for it
thanx to him
Old 03-03-2011, 19:08   #26 (permalink)
Member: 904530
Thanks Meter: 517
Check
Samsung Universal uUSB Cable Rev2.1.xps
on support site
Old 03-22-2011, 14:29   #27 (permalink)
Member: 186840
Thanks Meter: 103
this thread closed for me
Old 06-14-2011, 10:02   #28 (permalink)
trust4eve83's Avatar
Member: 1269056
Thanks Meter: 1,114
thanx to him
i have sam prob can u halpe me how to connect c3303 withe hwk thanxxxxxxxx
The Following 2 Users Say Thank You to trust4eve83 For This Useful Post:
Old 06-26-2011, 20:34   #29 (permalink)
lion4000's Avatar
Member: 352062
Thanks Meter: 35
i test my cable with resistor 150k not work . then i change it with 560k ohm
i get it in crad network , now my cable work fine this log :
LOG Started: 26062011_193303
Please Wait ...
UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10
UFS_USB V2.8 (c) SarasSoft 2007., S/n: -----
HID: ----------------------
HWK: ---------------
Licence: True
LogFile: .\_!_LOG\------_26062011_193303_LOG.txt
Loaded Settings from: Sams.ini
Error in Versions Info
Software: C3303KJPJG3
Hardware: MP 0.802
Regions : Arabic
Language: ar,en,fr(fa,ur)
Release : 2010 July Rev: 3
MSL Active
S/N : RPWZ985306
IMEI: 353958-04-6------6
BTID: 101D:C0:AA65F8
MSL Active
SIMLOCK STATUS: 0000
MCC-MNC:
MASTER KEY: 38011160
NET 73273960, <BADSET>
SUB 00000000, 00000000
SP 00000000, 00000000
CP 00000000, 00000000
SIM <UN_SET>, 00000000
ACT 00000000, 00000000
PLK <BADSET>, 00000000
MSL Active
MSL Active
MCC-MNC:
SLOCK Reset, Ok
Unlock Done
Preloader Ok 08, 921600 Baud
FLASH Id: SEC, K5N5629ATA [NOR 256Mb]+[NAND 1G]
MCU Read Done, 2097152 byte(s), Time: 00:25, 0
E2P Info:
HMEI: 353958-04-6------6
E2P Saved as E:\Program Files\SarasSoft\UFS\UFS_SAMs\C3303\C3303_353958-04-676190-6_E2P.bin
Old 06-28-2011, 21:09   #30 (permalink)
Member: 639574
Thanks Meter: 15
original use as cable or spell
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.23818 seconds with 10 queries
