12-07-2010, 10:05 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Age: 40
Member: 691960 Status: Offline Sonork: 100.1592294 Thanks Meter: 145 | 2610 phone dead after flash? MCU SW : V 07.11 05-11-08 RH-86 (c) Nokia. PPM SW : V 07.11 05-11-08 RH-86_87 (c) Nokia. IA Product : Nokia 2610 Prd.Code: 0533407 Bpr.Code: 0530409 Prod.Sn : DMJ191887 HW Vers : 1000 UEM : 1328 UPP : 12352 [3040] RFIC Ver: 0500 DSP Vers: P05w45.v49 LCD Type: ELBE IMEI : 011287-xx-xxxxxx-x SL Conf : 001-01-00000000000 SL Prof : 800000000001000-B SL Var : 00550112870020608800 SL Aux : 000B5555 HW Sig : 2CEAB38FAD8D3E0F Box Id : 894F8BD2FFFFFFFF BLK1= L1: UNKN L2: UNKN L3: UNKN L4: AUTO L5: UNKN BLK2= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN BLK3= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN BLK4= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN BLK5= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN BLK6= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN BLK7= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: AUTO Provider: GSM Test Equipment also n selftest everything is ok except lcd test it show not supported... phone is not powering on whats the big idea now i m confused..... (phone was having minor hang fault b4 flashing) need urgent solution.......................:confused : |
12-07-2010, 13:18 | #2 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Algeria-Cne Age: 47
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | your phone is not dead but you have problem with LCD. with dead phone you can't make info from it. so better to give more details about the initial state of your phone before flashing imei 011287-xx-xxxxxx-x is not a problem it is from america and canada. goo luck |
12-07-2010, 14:25 | #4 (permalink) |
No Life Poster Join Date: Oct 2009 Location: JAM Exploring Simlock 3!!! Age: 36
Member: 1149815 Status: Offline Sonork: N/A for now Thanks Meter: 218 | BLK1= L1: UNKN L2: UNKN L3: UNKN L4: AUTO L5: UNKN BLK2= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN BLK3= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN BLK4= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN BLK5= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN BLK6= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: UNKN BLK7= L1: UNKN L2: UNKN L3: UNKN L4: UNKN L5: AUTO Provider: GSM Test Equipment Simlock Blocks Unknown the phone is dead |
The Following User Says Thank You to GSM_STREET For This Useful Post: |
12-07-2010, 15:39 | #5 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Maybe Quote:
Try Make Ask to Rpl, wirte rpl again. Then Full factory Or Water DAamage ;( Br Polish | |
12-07-2010, 15:47 | #6 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Remove facia and you see Contact Service there while turning on. And about SIMLOCK Info, HWK Showns UNKNOWN for both 2626 and 2610. Check back label to determine its type eg. RH-86 or RH-87. Flash with appropirate files, you may also try to erase phone and then full flash. You may also compare IMEI in Info with Back label. Br, Shadab Ahmad |
12-08-2010, 08:57 | #7 (permalink) | |
Member: 691960 Status: Offline Sonork: 100.1592294 Thanks Meter: 145 | Quote:
i already done every bit of things that u ppl told me ................ something is fishy | |
12-08-2010, 09:18 | #8 (permalink) |
Member: 691960 Status: Offline Sonork: 100.1592294 Thanks Meter: 145 | yes there was an other back label sticker when i removed it. it is 2610b so it means that this phone is converted to 2610 so can i go for it with 2610 firmware or is it nessry to flash it with 2610b if yes so which version would work for me............?????????? |
12-08-2010, 10:14 | #10 (permalink) | |
ok thanks bro phone is on but has no network also phone restarts once when u power on and after some times when phone is on it powers off also it is a bit bump or can say slow..................... so now need more help........... | |
12-08-2010, 14:21 | #14 (permalink) |
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | he can't retreive network signal without hardware modification. @decentevil try to amke searche with convert 2610b to 2610 ther is two filter to change good luck |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
