Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 05-28-2013, 17:17   #1 (permalink)
.::Gsm-Play::.'s Avatar
Member: 1615596
Sonork: 100.1607XXX
Thanks Meter: 665
Thumbs up Samsung Champ C 3303K Flashing Done with HWK.
Samsung Champ C 3303K Blinking Successfully Flashing Done with HWK.
Partition Table: C3300KJP.ptt
TFS File: C3303KJPJI2.tfs CRC32: B10F7D85
CFG File: C3303KJPJI2.cfg 246690 byte(s)
CSC File: CRC32: 40647E82
CCF File: C3303KOJPJI1.ccf 36539 byte(s)
Connect Cable to Switched Off Mobile (with battery)
Preloader Ok 08, 460800 Baud
FLASH Id: SEC, K5N5629ATA [NOR 256Mb]+[NAND 1G]
NAND Format Complete, Time: 00:08
Partition LCDACT: C3300KJP.bootlcdact
File CRC: 0x7F812DC3
MCU Write Done, 3940 byte(s), Time: 00:00
Partition MAIN: C3300KJP.cla\ER_FLASH_REGION2_CB
File CRC: 0x2E86F4A8
MCU Write Done, 29490004 byte(s), Time: 16:04
Partition DSP: C3300KJP.cla\ER_FLASH_DSP_PATCH
File CRC: 0xBCBFD18F
MCU Write Done, 489508 byte(s), Time: 00:16
Partition ROOT: C3300KJP.cla\ER_FLASH_REGION1_CB
File CRC: 0x913954EF
MCU Write Done, 50548 byte(s), Time: 00:02
BOOT: C3300KJP.bootloader
BOOT: Patched Ok
File CRC: 0x5E92D55E
BOOT Write Done, 42240 byte(s), Time: 00:02
File CRC: 0xB10F7D85
TFS Initialised: 1
TFS Version: TFS4.0_CORONA_01
Directories: 240
Max_Files  : 2812
Files_Count: 2812/2812
TFS Unmounted
TFS Write Done, 50339725 byte(s), Time: 23:07
CSC Format Done, Time: 00:00
File CRC: 0x40647E82
Directories: 63
Max_Files  : 417
Files_Count: 417/417
CSC Unmounted
CSC Write Done, 9703321 byte(s), Time: 04:18
Old 06-02-2013, 18:32   #2 (permalink)
Member: 1197620
Sonork: 100.1602278
Thanks Meter: 552
nice post for many user
Old 06-03-2013, 15:37   #3 (permalink)
KYEJUSA's Avatar
Member: 394869
Thanks Meter: 400
Originally Posted by .::software zone::. View Post
samsung champ c 3303k blinking successfully flashing done with hwk.
partition table: C3300kjp.ptt
tfs file: C3303kjpji2.tfs crc32: B10f7d85
cfg file: C3303kjpji2.cfg 246690 byte(s)
csc file: crc32: 40647e82
ccf file: C3303kojpji1.ccf 36539 byte(s)
connect cable to switched off mobile (with battery)
preloader ok 08, 460800 baud
flash id: Sec, k5n5629ata [nor 256mb]+[nand 1g]
nand format complete, time: 00:08
partition lcdact: C3300kjp.bootlcdact
file crc: 0x7f812dc3
mcu write done, 3940 byte(s), time: 00:00
partition main: C3300kjp.cla\er_flash_region2_cb
file crc: 0x2e86f4a8
mcu write done, 29490004 byte(s), time: 16:04
partition dsp: C3300kjp.cla\er_flash_dsp_patch
file crc: 0xbcbfd18f
mcu write done, 489508 byte(s), time: 00:16
partition root: C3300kjp.cla\er_flash_region1_cb
file crc: 0x913954ef
mcu write done, 50548 byte(s), time: 00:02
boot: C3300kjp.bootloader
boot: Patched ok
file crc: 0x5e92d55e
boot write done, 42240 byte(s), time: 00:02
file crc: 0xb10f7d85
tfs initialised: 1
tfs version: Tfs4.0_corona_01
directories: 240
max_files  : 2812
files_count: 2812/2812
tfs unmounted
tfs write done, 50339725 byte(s), time: 23:07
csc format done, time: 00:00
file crc: 0x40647e82
directories: 63
max_files  : 417
files_count: 417/417
csc unmounted
csc write done, 9703321 byte(s), time: 04:18
which cable do you use for connection and show procedure please.thanks
Old 06-07-2013, 14:40   #4 (permalink)
Member: 1615596
Sonork: 100.1607XXX
Thanks Meter: 665
Use only Micro RJ45 UART cable.
The Following User Says Thank You to .::Gsm-Play::. For This Useful Post:
Page generated in 0.20325 seconds with 7 queries
