12-21-2009, 07:31 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | samsung e1100t flafh ok not power on help MCU File: e1100tdbic3.cla CRC32: BC2F4D91 TFS File: e1100tdbic3.tfs CRC32: EF0B8B3F CFG File: e1100tdbic3.cfg 4154 byte(s) Connect Cable to Switched Off Mobile (with battery) Preloader Ok 54, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N6433ATM Erase Done, 56 sector(s), Time: 00:21 File CRC: 0xBC2F4D91 MCU Write Done, 5039892 byte(s), Time: 01:31 File CRC: 0xEF0B8B3F TFS Version : TFS4.0_CORONA_01 Directories : 16 Max_Files : 52 Directory : /customer Directory : /customer/nvmgr Directory : /images Directory : /images/idle Directory : /images/LargeClock Directory : /images/menu Directory : /images/org Directory : /images/power Directory : /images/UCS Directory : /images/UCS/Default Directory : /images/UCS/Default/cfg Directory : /memo Directory : /sms Directory : /sounds Directory : /sounds/default Directory : /test Files_Count: 52/52 File: /customer/nvmgr/NvData.dat, Size: 8875 File: /customer/nvmgr/NvInit.dat, Size: 8875 File: /customer/nvmgr/nvSize.dbg, Size: 293 File: /customer/nvmgr/VariantVersion.dat, Size: 2 File: /images/idle/idle_011.ifg, Size: 11086 File: /images/idle/idle_021.ifg, Size: 13138 File: /images/idle/idle_031.ifg, Size: 11772 File: /images/idle/idle_041.ifg, Size: 11966 File: /images/idle/idle_051.ifg, Size: 14950 File: /images/LargeClock/icon.ifg, Size: 324 File: /images/LargeClock/idle_large_clock_lock.ifg, Size: 142 File: /images/LargeClock/num.ifg, Size: 3056 File: /images/menu/00_mainmenu_block_bg.ifg, Size: 2014 File: /images/menu/00_mainmenu_block_menu01_ani04.ifg, Size: 230 File: /images/menu/00_mainmenu_block_menu02_ani04.ifg, Size: 236 File: /images/menu/00_mainmenu_block_menu03_ani04.ifg, Size: 330 File: /images/menu/00_mainmenu_block_menu04_ani04.ifg, Size: 334 File: /images/menu/00_mainmenu_block_menu05_ani04.ifg, Size: 330 File: /images/menu/00_mainmenu_block_menu06_ani04.ifg, Size: 276 File: /images/menu/00_mainmenu_block_menu07_ani04.ifg, Size: 308 File: /images/menu/00_mainmenu_block_menu08_ani04.ifg, Size: 236 File: /images/menu/00_mainmenu_block_menu09_ani04.ifg, Size: 510 File: /images/org/01_thai_sympopup_bg1.ifg, Size: 780 File: /images/org/01_thai_sympopup_focus_011.ifg, Size: 696 File: /images/org/01_thai_sympopup_focus_021.ifg, Size: 698 File: /images/power/pwron01.ifg, Size: 2850 File: /images/UCS/Default/cfg/Default-1.thm, Size: 324 File: /images/UCS/Default/cfg/Default-2.thm, Size: 324 File: /images/UCS/Default/cfg/Default-3.thm, Size: 324 File: /images/UCS/Default/cfg/Default-4.thm, Size: 324 File: /images/UCS/Default/cfg/Default-5.thm, Size: 324 File: /images/greeting_01.ifg, Size: 3616 File: /memo/memo_list_file.dat, Size: 804 File: /sounds/default/Baroque.mid, Size: 2227 File: /sounds/default/Basic_tone.mid, Size: 1367 File: /sounds/default/Before sunset.mid, Size: 10870 File: /sounds/default/Butterfly kiss.mid, Size: 4021 File: /sounds/default/Chiming tone.mid, Size: 1583 File: /sounds/default/Classic bell.mp3, Size: 69632 File: /sounds/default/Dewy Leaves.mid, Size: 13024 File: /sounds/default/Focus on it.mid, Size: 4749 File: /sounds/default/Forgotten Promise.mid, Size: 8434 File: /sounds/default/Funky Marionette.mid, Size: 5563 File: /sounds/default/Good morning.mid, Size: 4084 File: /sounds/default/Nightless city.mid, Size: 5250 File: /sounds/default/Rainbow bridge.mid, Size: 7769 File: /sounds/default/Samsung tune.mp3, Size: 321536 File: /sounds/default/Tripping.mid, Size: 799 File: /sounds/default/Voyage.mid, Size: 7115 File: /sounds/default/Watercolor painting.mid, Size: 13998 File: /sounds/default/Wind tone.mp3, Size: 14336 File: /test/cfg.txt, Size: 4101 Files Closed TFS Unmounted TFS Write Done, 600805 byte(s), Time: 00:37 |
12-21-2009, 09:10 | #4 (permalink) |
Member: 823633 Status: Offline Thanks Meter: 1,705 | bro i am flash file download hwk server & flash my phone is ok flash log here MCU File: e1100txeic1.cla CRC32: FA4C2113 TFS File: e1100txeic1.tfs CRC32: EB5ED87E CFG File: e1100txeic1.cfg 3291 byte(s) Connect Cable to Switched Off Mobile (with battery) Preloader Ok 54, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N6433ATM Erase Done, 56 sector(s), Time: 00:21 File CRC: 0xFA4C2113 MCU Write Done, 3388560 byte(s), Time: 01:02 File CRC: 0xEB5ED87E TFS Version : TFS4.0_CORONA_01 Directories : 15 Max_Files : 39 Directory : /customer Directory : /customer/nvmgr Directory : /images Directory : /images/idle Directory : /images/LargeClockMCU File: e1100txeic1.cla CRC32: FA4C2113 TFS File: e1100txeic1.tfs CRC32: EB5ED87E CFG File: e1100txeic1.cfg 3291 byte(s) Connect Cable to Switched Off Mobile (with battery) Preloader Ok 54, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N6433ATM Erase Done, 56 sector(s), Time: 00:21 File CRC: 0xFA4C2113 MCU Write Done, 3388560 byte(s), Time: 01:02 File CRC: 0xEB5ED87E TFS Version : TFS4.0_CORONA_01 Directories : 15 Max_Files : 39 Directory : /customer Directory : /customer/nvmgr Directory : /images Directory : /images/idle Directory : /images/LargeClock Directory : /images/menu Directory : /images/power Directory : /images/UCS Directory : /images/UCS/Default Directory : /images/UCS/Default/cfg Directory : /memo Directory : /sms Directory : /sounds Directory : /sounds/default Directory : /test Files_Count: 39/39 File: /customer/nvmgr/NvData.dat, Size: 8708 File: /customer/nvmgr/NvInit.dat, Size: 8708 File: /customer/nvmgr/nvSize.dbg, Size: 289 File: /customer/nvmgr/VariantVersion.dat, Size: 2 File: /images/idle/idle_011.ifg, Size: 14868 File: /images/idle/idle_021.ifg, Size: 14718 File: /images/idle/idle_031.ifg, Size: 14696 File: /images/LargeClock/icon.ifg, Size: 324 File: /images/LargeClock/idle_large_clock_lock.ifg, Size: 142 File: /images/LargeClock/num.ifg, Size: 3158 File: /images/menu/00_mainmenu_block_bg.ifg, Size: 1946 File: /images/menu/00_mainmenu_block_menu01_ani04.ifg, Size: 220 File: /images/menu/00_mainmenu_block_menu02_ani04.ifg, Size: 226 File: /images/menu/00_mainmenu_block_menu03_ani04.ifg, Size: 290 File: /images/menu/00_mainmenu_block_menu04_ani04.ifg, Size: 282 File: /images/menu/00_mainmenu_block_menu05_ani04.ifg, Size: 310 File: /images/menu/00_mainmenu_block_menu06_ani04.ifg, Size: 240 File: /images/menu/00_mainmenu_block_menu07_ani04.ifg, Size: 274 File: /images/menu/00_mainmenu_block_menu08_ani04.ifg, Size: 238 File: /images/menu/00_mainmenu_block_menu09_ani04.ifg, Size: 470 File: /images/power/pwron01.ifg, Size: 6332 File: /images/UCS/Default/cfg/Default-1.thm, Size: 304 File: /images/UCS/Default/cfg/Default-2.thm, Size: 304 File: /images/UCS/Default/cfg/Default-3.thm, Size: 304 File: /images/UCS/Default/cfg/Default-4.thm, Size: 304 File: /images/UCS/Default/cfg/Default-5.thm, Size: 304 File: /images/greeting_01.ifg, Size: 4924 File: /memo/memo_list_file.dat, Size: 804 File: /sounds/default/Basic tone.mid, Size: 309 File: /sounds/default/Chiming tone.mid, Size: 397 File: /sounds/default/Flying High.mid, Size: 1691 File: /sounds/default/Get Happy.mid, Size: 2248 File: /sounds/default/Look Back.mid, Size: 1919 File: /sounds/default/Mirage tone.mid, Size: 230 File: /sounds/default/Samsung tune.mid, Size: 722 File: /sounds/default/Secret Life.mid, Size: 1457 File: /sounds/default/Shadow of Your Smile.mid, Size: 945 File: /sounds/default/Tripping.mid, Size: 398 File: /test/cfg.txt, Size: 3228 Files Closed TFS Unmounted TFS Write Done, 97233 byte(s), Time: 00:15 Connect Cable to Switched Off Mobile (with battery) MSL Active MSL Deactivated SLOCK Reset, Ok Unlock Done Directory : /images/menu Directory : /images/power Directory : /images/UCS Directory : /images/UCS/Default Directory : /images/UCS/Default/cfg Directory : /memo Directory : /sms Directory : /sounds Directory : /sounds/default Directory : /test Files_Count: 39/39 File: /customer/nvmgr/NvData.dat, Size: 8708 File: /customer/nvmgr/NvInit.dat, Size: 8708 File: /customer/nvmgr/nvSize.dbg, Size: 289 File: /customer/nvmgr/VariantVersion.dat, Size: 2 File: /images/idle/idle_011.ifg, Size: 14868 File: /images/idle/idle_021.ifg, Size: 14718 File: /images/idle/idle_031.ifg, Size: 14696 File: /images/LargeClock/icon.ifg, Size: 324 File: /images/LargeClock/idle_large_clock_lock.ifg, Size: 142 File: /images/LargeClock/num.ifg, Size: 3158 File: /images/menu/00_mainmenu_block_bg.ifg, Size: 1946 File: /images/menu/00_mainmenu_block_menu01_ani04.ifg, Size: 220 File: /images/menu/00_mainmenu_block_menu02_ani04.ifg, Size: 226 File: /images/menu/00_mainmenu_block_menu03_ani04.ifg, Size: 290 File: /images/menu/00_mainmenu_block_menu04_ani04.ifg, Size: 282 File: /images/menu/00_mainmenu_block_menu05_ani04.ifg, Size: 310 File: /images/menu/00_mainmenu_block_menu06_ani04.ifg, Size: 240 File: /images/menu/00_mainmenu_block_menu07_ani04.ifg, Size: 274 File: /images/menu/00_mainmenu_block_menu08_ani04.ifg, Size: 238 File: /images/menu/00_mainmenu_block_menu09_ani04.ifg, Size: 470 File: /images/power/pwron01.ifg, Size: 6332 File: /images/UCS/Default/cfg/Default-1.thm, Size: 304 File: /images/UCS/Default/cfg/Default-2.thm, Size: 304 File: /images/UCS/Default/cfg/Default-3.thm, Size: 304 File: /images/UCS/Default/cfg/Default-4.thm, Size: 304 File: /images/UCS/Default/cfg/Default-5.thm, Size: 304 File: /images/greeting_01.ifg, Size: 4924 File: /memo/memo_list_file.dat, Size: 804 File: /sounds/default/Basic tone.mid, Size: 309 File: /sounds/default/Chiming tone.mid, Size: 397 File: /sounds/default/Flying High.mid, Size: 1691 File: /sounds/default/Get Happy.mid, Size: 2248 File: /sounds/default/Look Back.mid, Size: 1919 File: /sounds/default/Mirage tone.mid, Size: 230 File: /sounds/default/Samsung tune.mid, Size: 722 File: /sounds/default/Secret Life.mid, Size: 1457 File: /sounds/default/Shadow of Your Smile.mid, Size: 945 File: /sounds/default/Tripping.mid, Size: 398 File: /test/cfg.txt, Size: 3228 Files Closed TFS Unmounted TFS Write Done, 97233 byte(s), Time: 00:15 Connect Cable to Switched Off Mobile (with battery) MSL Active MSL Deactivated SLOCK Reset, Ok Unlock Done |
1112 software is ok but set not power on help me plz | shani72 | Nokia Hardware & Hardware Repair | 12 | 06-22-2009 13:04 |
chaging ok not power on t100 samsung | shani72 | Samsung Hardware Repair | 1 | 01-09-2009 09:53 |
SL45i CHARGING OK, NOT POWER ON. HELP!!! | bocahklaten | Siemens Hardware Repair Area | 2 | 11-15-2007 08:42 |
SL45i CHARGING OK, NOT POWER ON. HELP!!! | bocahklaten | x1x to x45/x50 | 0 | 10-29-2007 15:32 |
Platiji Help me :-( GX15 flash ok, not power on ?????? | Dynamitor | Sharp | 0 | 04-16-2006 13:51 |
