07-16-2009, 21:38 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: New Area
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | samsung e2210b Any idea about this model on other box section it s written that is the same as e1360b, but with hwk selecting this model, it give error tried with other models selection, TAT Mode enter but unlock and read info give error WBR, |
07-16-2009, 21:47 | #2 (permalink) |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | E2210b is not Compatible with any other Model Already implemented in v2.0.8.5 if you Still want to have Codes, Please readout Full Firmware as E2210 am make Download Link..@ Munna. |
07-16-2009, 21:58 | #3 (permalink) | |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | Quote:
start 0000 0000 size 0200 0000 and getting error : Connect Cable to Switched Off Mobile (with battery) 1st Boot Failed: Get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| |
07-16-2009, 22:13 | #5 (permalink) |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | here r steps I'm doing : run sams module click Connect Click OM/Swift Select e2210 model check MCU nor Check Tfs nor Click Read Flash soft ask to connect mobile Connected rj45 e210 cable to switchef off mobile with battery inside getting error ??? I m doing wrong ??? |
07-16-2009, 22:19 | #6 (permalink) |
Member: 66937 Status: Offline Thanks Meter: 5,053 | Seems Your cable not have auto-ignition function, so if nothing happens after Cable Connection Press and hold Power on button Untill boot Finishes and Starts read...@ Munna. |
07-16-2009, 23:25 | #8 (permalink) | |
Member: 148814 Status: Offline Sonork: 100.1576882 Thanks Meter: 5,012 | hi again, it took me some time coz i put speed to 115000 E2210b mcu flash readed by HWK box: LINK Quote:
07-16-2009, 23:46 | #9 (permalink) | |
Member: 66937 Status: Offline Thanks Meter: 5,053 | Quote:
MCU File: e2210__mcu_full.bin CRC32: AFA2AC62 Connect Cable to Switched Off Mobile (with battery) Preloader Ok 08, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N5629ATA File CRC: 0xAFA2AC62 MCU Write Done, 33554432 byte(s), Time: 11:50 Here is Unlock Code:- Software: E2210BBGIF1 Hardware: MP 0.600 Regions : Telefonica (Movistar) - Spain Language: de,el,en,es,fr,it,pt,tr Release : 2009 June Rev: 1 MSL Active MSL Deactivated S/N : RPXS359926 IMEI: 352502-03-xxxxxx-x BTID: 0025:67:801DF4 Flags: 00000001 [Locked] Key M: 97756150 [MASTER] Prov : 214-07 Movistar, Spain Key 1: 56433790, 00000000 [NET] Key 2: 00000000, 00000000 Key 3: 00000000, 00000000 Key 4: 00000000, 00000000 Key 5: 00000000, 00000000 Key 6: 00000000, 00000000 Key 7: 00000000, 00000000 Munna. | |
The Following User Says Thank You to GsmMunna For This Useful Post: |
Samsung E2210B Full unlock. | hmyeamin | Chinese Models & Cloned Phones | 0 | 01-19-2010 10:53 |
help !!! Samsung E2210B | PIRATOSS | NSPRO | 0 | 10-05-2009 20:12 |
unlock samsung E2210B | emilian_judea | Samsung Flashers, Software, Firmware. | 0 | 09-18-2009 14:09 |
Samsung e2210b | Abesha | Ultimate-Sam | 1 | 08-19-2009 21:41 |
Samsung E2210B Unlock Solution | Black_Daimond | HWK | 2 | 08-05-2009 15:17 |
