04-14-2009, 09:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: EDSELLULAR
Member: 236564 Status: Offline Sonork: 100.1667122 Thanks Meter: 816 | CU515 AT&T unlock done by HWK UFS_USB V2.8 (c) SarasSoft 2007., S/n: rea1One HID: D8E3FCCrea1One HWK: A1.04-PRO1 Licence: True, 00:12 PING: OK, COM316 - QCDI Software: CU515-MSM21302430-V10g-NOV-27-2007-ATT-US MiscInfo: Nov 27 200717:51:50Sep 05 200704:00:00CU515 IMEI: 011666-00-051208-2 BTID: 001F:E374D22 FLID: toshiba_ty9000a800jogg PING: OK, COM316 - QCDI Software: CU515-MSM21302430-V10g-NOV-27-2007-ATT-US IMEI: 011666-00-051208-2 PING: OK, COM316 - QCDI NVM Read Done, START: 0000, 826 Active Block(s), Time: 06:27 Saved as CU515-MSM21302430-V10g-NOV-27-2007-ATT-US_011666000512082.nvm PING: OK, COM316 - QCDI NVM Read Done, START: 0226, 1 Active Block(s), Time: 00:00 NVM Read Done, START: 01BF, 1 Active Block(s), Time: 00:00 PING: OK, COM315 - MODEM Software: CU515FL-V10g-01-310-410-00-01-01-NOV-27-2007+0 IMEI: 011666-00-051208-2 BTID: 001F:E374D22 IDDE: OK PING: OK, COM316 - QCDI NVM Write Done: 2 Block(s), Time: 00:00 PING: OK, COM315 - MODEM Software: CU515FL-V10g-01-310-410-00-01-01-NOV-27-2007+0 IMEI: 011666-00-051208-2 BTID: 001F:E374D22 |
The Following 3 Users Say Thank You to rea1One For This Useful Post: |
04-18-2009, 05:47 | #4 (permalink) |
Member: 236564 Status: Offline Sonork: 100.1667122 Thanks Meter: 816 | use orig usb cable and install drivers. to unlock= check option edit BT & imei then press hidden unlock |
The Following 2 Users Say Thank You to rea1One For This Useful Post: |
04-30-2012, 03:42 | #8 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 460316 Status: Offline Thanks Meter: 22 | UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: 95737 HID: 68656F570027005B HWK: A1.04-PRO1 Licence: True, 00:09 PING: OK, COM79 - QCDI SWV : CU515-MSM21302430-V10c-SEP-21-2007-ATT-US MINF: Sep 22 200706:56:25Aug 20 200706:00:00CU515 IMEI: 011269-00-006048-1 BTID: 001C:62:EDE7E3 FLID: toshiba_ty9000a800jogg PING: OK, COM79 - QCDI NVM Read Done, START: 0226, 1 Active Block(s), Time: 00:00 NVM Read Done, START: 01BF, 1 Active Block(s), Time: 00:00 PING: OK, COM23 - MODEM SWV : CU515FL-V10c-01-310-410-00-01-01-SEP-21-2007+0 IMEI: 011269-00-006048-1 BTID: 001C:62:EDE7E3 IDDE: OK PING: OK, COM79 - QCDI NVM Write Done: 2 Block(s), Time: 00:00 PING: OK, COM23 - MODEM SWV : CU515FL-V10c-01-310-410-00-01-01-SEP-21-2007+0 IMEI: 011269-00-006048-1 BTID: 001C:62:EDE7E3 |
The Following User Says Thank You to aboymaligalig For This Useful Post: |
D407 unlock done by HWK | coldGin | Trident/AGERE Platform | 9 | 05-23-2012 19:17 |
2680s unlock done by hwk 4.56 also 4.91 tested | GUDO-GSM | HWK | 3 | 04-22-2009 09:11 |
Blackberry 9000 at&t unlock done | right_click | BlackBerry (RIM) | 3 | 02-05-2009 01:49 |
LG CU515 at&t unlock done. | raselopu | FuriousGold | 1 | 12-06-2008 13:22 |
