Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > HWK
Old 12-02-2009, 21:15   #1 (permalink)
milkyctg's Avatar
Member: 56855
Thanks Meter: 77
Samsung M620 Flashing error
Before flashing it was working ok. For change language I attemped to flash it. But flashing job doesn't complete. Hwk gives me the following error....here is the logs...
With MCU- M620XEHF1_FULL.s3t.....
1st Boot Ok, McuId: 00030021, Rom: 00030021, 13-1.2 (Vision X122A)
2nd Boot Ok, McuId: 00030021, Rom: 00030021, 7-2.0
Fll Boot Ok, Vers: 5.22, fl_sceptreeg_vx100_eval_v24_s05_2.sre
Flash1: Fl_Id: 00010000_227E3D00 - Spansion SxxWS512P
Baud Rate Set: 460800 bps
Flashing NOR part...
ErTxdt: 0 - eom.OPEN+!eom.
Write Failed at: 0x209C4000
With MCM620XFIE1_binary.s3 and CTS-M620XFIE1_CTS.cts....
Region: 1, 0x20000000-0x20000063, Length: 100 bytes
Region: 2, 0x2000C000-0x20011113, Length: 20756 bytes
Region: 3, 0x20016000-0x200173BF, Length: 5056 bytes
Region: 4, 0x2001E000-0x2001E09F, Length: 160 bytes
Region: 5, 0x2003803C-0x20040F87, Length: 36684 bytes
Region: 6, 0x20058000-0x20058037, Length: 56 bytes
Region: 7, 0x20058138-0x2005C665, Length: 17710 bytes
Region: 8, 0x20078000-0x20183C9B, Length: 1096860 bytes
Region: 9, 0x20300000-0x21CA7677, Length: 26900088 bytes
Write Failed at: 0x20704000
Would anybody pls help me.
Thanx in advance.
Old 12-02-2009, 22:59   #2 (permalink)
mogrem.soft's Avatar
Member: 914426
Sonork: 01017474627
Thanks Meter: 235
Mate . Try To Low Baud Rate or set it manual change (auto) it .......hope it help u .......
Old 12-03-2009, 00:18   #3 (permalink)
milkyctg's Avatar
Member: 56855
Thanks Meter: 77
Thanx for the response. I already set lower baudrate and auto but the same error. Any other idea pls?
Old 12-04-2009, 17:09   #4 (permalink)
Member: 870664
Sonork: 100.1614707
Thanks Meter: 56
have you tried to erase NOR part before flashing?
Old 12-16-2009, 06:37   #5 (permalink)
Member: 467118
Thanks Meter: 16
ufs also dead m620 with flash (repair with ust pro)
Old 12-16-2009, 06:41   #6 (permalink)
Member: 757799
Thanks Meter: 782
check your battery maybe not enough charge
The Following User Says Thank You to trio1 For This Useful Post:
Old 12-16-2009, 06:45   #7 (permalink)
Member: 904530
Thanks Meter: 517
new M620 can be flashed only using USB !
so use original tool from support
original tool cannot flash it if use not USB connection
Old 12-16-2009, 06:45   #8 (permalink)
Crazy Poster
Member: 700258
Thanks Meter: 9
mee too i agree with this
many times encounter this problem...
Old 12-16-2009, 07:09   #9 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
Used supply to flash this phone not battery set the regular like battery and flash withe the last selected file in support area of hwk your problem solve
z3x samsung M620 flashing problem sahbettin Z3X-Team Products 18 03-24-2014 12:53
M620 Flashing Error... green bird HWK 5 11-01-2009 10:39
m620 flash error turkcellgsm UST Pro II 18 07-14-2009 18:09
m620 flash error turkcellgsm HWK 0 06-19-2009 17:42
logo samsung m620 Flash by nspro done kikikokoki NSPRO 0 05-31-2009 09:01
Page generated in 0.23819 seconds with 9 queries
