samsung s5222 rest code read to ufs Connect Cable to Switched Off Mobile (with battery) TAT Canceled: 1 Unlock failed Software: S5222DDLAA/S5222ODDLAA Warning, Wrong Product Selected [S3310i] Regions : DL Release : 2001 January Rev: IMEI: 359800-04-114432-0 S/N : RF1C23NNW4 BTID: 9C0298-E132E5 ULCK: 2609 Level Of Lock: 00h Use Patch MSL, if Want to Read Codes or do IMEI Operations Or Untick [AT Info Mode] to Read Codes |
which model selected and which cable |
s5222 unlock select c3750 on hwk sams load firmware files untick AT info mode tick erase userdata tick patch msl select usb0 write flash switchoff mobile insert usb after flash reset MMI switch on mobile with unaccepted simcard(etisalat) connect with hwk again tick ATinfo mode read mobile info now you can see unlock codes enter code and press sent key unlock done Software: S5222XXLAF/S5222OXELAE Warning, Wrong Product Selected [C3750] Regions : EL Release : 2001 May Rev: IMEI: 352274-********* S/N : RZ1C60M8V3 BTID: 58C38B-DD4D0E ULCK: 0000 Level Of Lock: 00h NCK : 00000000 [#0111*00000000#] SCK : 00000000 [#0121*00000000#] SPCK: 00000000 [#0133*00000000#] PCK : 1475 [#0141*1475#] MCK : 17278720 [#0199*17278720#] enjoy G-tech |
first flashing then unlock and read code via ufs or z3x and enter codes problem solve |
Thanks sir unlock done with hwk model selet c3750 and s5222r |
samsung s5222 rest code or read code frm ufs Quote:
yes all is done after flash so u must flash first |
thanks its work ................. |
thanksssssssssssssssssssssssss |
I have tried to unlock this model before but failed |
not booting brother not boooting brother what have to use either usb cable or rj45 cable :) |
my problem s5220 all flash patch write z3x spt and hwk but imei damaged 000000000/01 no repair msl failure how to solve this problem help me Software: S5220XXLC3/S5220OXALB2 Warning, Wrong Product Selected [C3750] Regions : Austria,France,Germany,Italy,Netherlands,Switzerla nd,UK Language: de,en,es,fr,it,nl,pt,tr Release : 2012 February Rev: 2 IMEI: 000000-00-000000-0 BTID: 1C66AA-60BA83 ULCK: 00000000 Level Of Lock: 00h Use Patch MSL, if Want to Read Codes or do IMEI Operations Or Untick [AT Info Mode] to Read Codes |
