11-28-2010, 15:27 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Algeria
Member: 237474 Status: Offline Thanks Meter: 53 | ..:E1105F Unlock solution:.. -select E1105T -read E2p save it -Chk E2P file and enjoy you have the Unlock code Connect Cable to Switched Off Mobile (with battery) Preloader Ok 54, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N6433ATM [NOR 64Mb] MCU Read Done, 524288 byte(s), Time: 00:06, 0 E2P Info: HMEI: 352904-04-129451-0 IMEI: 352904-04-129451-0 REG.FIRMWARE: 9 SIMLOCK STATUS: 0000 MCC-MNC: 4F0-100 E2P Saved as C:\Program Files\SarasSoft\UFS\UFS_SAMs\E1105T\E1105F_352904-04-******-0_E2P.bin Image File: E1105T_352904-04-******-0_E2P.bin File Size: 524288 byte(s) [0x00080000] E2P Info: HMEI: 352904-04-******-0 IMEI: 352904-04-******-0 REG.FIRMWARE: 9 SIMLOCK STATUS: 0000 MCC-MNC: 4F0-100 Extended: SIMLOCK STATUS: 0001 MCC-MNC: 604-01 MASTER: 42952460 #SIMLOCK*NET*92286610# #SIMLOCK*SUB*00000000# #SIMLOCK*SP*00000000# #SIMLOCK*CP*00000000# good luck |
The Following 3 Users Say Thank You to elvase For This Useful Post: |
04-28-2011, 20:51 | #5 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Algérie Age: 47
Member: 744421 Status: Offline Sonork: box Thanks Meter: 5 | Connect Cable to Switched Off Mobile (with battery) Preloader Ok 54, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N6433ATM [NOR 64Mb] MCU Read Done, 524288 byte(s), Time: 00:06, 0 E2P Info: HMEI: 352904-04-240533-9 IMEI: 352904-04-240533-9 REG.FIRMWARE: 9 SIMLOCK STATUS: 0000 MCC-MNC: 4F0-100 E2P Saved as C:\Program Files\SarasSoft\UFS\UFS_SAMs\E1105T\E1105T_352904-04-240533-9_E2P.bin Image File: E1105T_352904-04-240533-9_E2P.bin File Size: 524288 byte(s) [0x00080000] E2P Info: HMEI: 352904-04-240533-9 IMEI: 352904-04-240533-9 REG.FIRMWARE: 9 SIMLOCK STATUS: 0000 MCC-MNC: 4F0-100 Extended: SIMLOCK STATUS: 0001 MCC-MNC: 604-01 MASTER: 81823940 #SIMLOCK*NET*02969260# #SIMLOCK*SUB*00000000# #SIMLOCK*SP*00000000# #SIMLOCK*CP*00000000# good hwk |
The Following User Says Thank You to sid_ch For This Useful Post: |
09-28-2011, 14:57 | #6 (permalink) |
No Life Poster Join Date: Dec 2004 Age: 50
Member: 95476 Status: Offline Thanks Meter: 185 | unlock e1105t by selecting..........e1100t Selected model: E1107T Selected com port: COM15 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone IMEI: 35914303106847 Phone SW: E1105TJXIE2 Phone BT ADDR: 0000-00-000000 Phone SN: RUEZ260659 Deactivated MSL - TRUE [FREZEE]: 94276600 [NET Lock]: 03723640 [Subset Lock]: 00000000 [SP Lock]: 00000000 [CP Lock]: 00000000 [Sim Lock]: 00185201 [Phone Lock]: 00000000 Read info - ok Elapsed time: 11 second, sw ver: 3.5.0027 ------------------------------------------------------------------------------- |
01-13-2012, 10:57 | #7 (permalink) |
Freak Poster Join Date: Apr 2008 Location: some where in europe
Member: 752357 Status: Offline Sonork: miker cellular centre Thanks Meter: 22 | Listen it easy to unlock e1105f with hwk 1.select type of phone e1105f 2.read ep2 3.patch msl 4. Mobil info u'll get the code i've done it many times. |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
