09-12-2013, 10:15 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: haryana in fatehabad Age: 36
Member: 1503356 Status: Offline Thanks Meter: 110 | samsung s5292 flashing successfull by hwk Regions : Austria,Benelux,France,Germany,Hungary,Italy,Spain ,UK Language: de,en,es,fr,hu,it,nl,pt(cs,da,el,fi,no,pl,sl,sv,tr ) Release : 2013 February Rev: 2 MSL Patched OK: 00:00 Insert USB Cable to Phone Without Battery IF_USB: XGOLDxxx IF_SBL: XGOLD230, Ok IF_EBL: CATFISH2230_PCM_1.9400_M1S1 1.9400, Mode: BB FL_ID : F0110000, Micron PCM 2WA91 1024Mb S5292XXMB2_BSY.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x40000000 - 0x4001FFFE, Erased: 00:00 Write Area: 0x40000000 - 0x4001FFFE, Written: 00:00 Flash File: CATFISH.fls Erase Area: 0x40020000 - 0x42EFFFFE, Erased: 00:20 Write Area: 0x40020000 - 0x42A03212, Written: 00:18 S5292XXMB2_CDS.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x42F00000 - 0x42FFFFFE, Erased: 00:00 Write Area: 0x42F00000 - 0x42F6B64E, Written: 00:00 S5292OXEMB2_CSC.dffs FLASH BUNDLE: Flash File: temp_GT-S5292_OXE.dffs Erase Area: 0x43000000 - 0x47E7FFFE, Erased: 00:25 Write Area: 0x43000000 - 0x45CE14AE, Written: 02:14 ShutDown Done All Done, Time: 03:32 Make [Reset MMI] or Use *2767*3855# at First Start ! |
The Following 3 Users Say Thank You to r4raja007 For This Useful Post: |
09-12-2013, 10:18 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Pakistan
Member: 1771086 Status: Offline Thanks Meter: 2,410 | how can you 3 file i think this mobile flashing with 5 files then you how can do it |
The Following User Says Thank You to fahad ali khan For This Useful Post: |
03-17-2014, 11:09 | #6 (permalink) |
Insane Poster Join Date: Jan 2014
Member: 2103284 Status: Offline Thanks Meter: 15 | Hello! Please, help me. I can't flash S5292. I use Samsung Tool 2.3.0.3. Micro-USB to RJ45 handmade, all as in documetation "UFSx Cable Schemas". Phone connect with battery and without - nothing. Please, tell me how correctly connect thease phone to ufs-3. |
03-18-2014, 03:23 | #7 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Hate stupidity
Member: 904530 Status: Offline Thanks Meter: 517 | use usb flashing with normal cable press flash and insert USB cable to phone without battery |
The Following User Says Thank You to Major-T For This Useful Post: |
06-17-2014, 15:02 | #9 (permalink) |
Freak Poster Join Date: Jan 2012 Location: kerala
Member: 1710992 Status: Offline Sonork: nibu Thanks Meter: 25 | s 5292 flashing done hwk UFST Boot v1.2 (c)SarasSoft 2012, Id: 54 4D 1 0 UFST Core v1.3 (c)SarasSoft 2013, Sn: 15753942 HID: 2B7BEEE742600098, HWK: A1.04-PRO1 SID: 235D8E58D9F7AE09C21C2250736591565325F769 XID: AE84D0F118E95089BF386E1D2343278CB104B8BF Licence: True AppVers: SAMSUNG TOOLS (HWK) v 2.3.0.3 by SarasSoft Test v20 LogFile: .\_!_LOG\15753942_2014_06_17_18_45_00_LOG.txt Loaded Settings from: Sams.ini <<< STOP >>> Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2013 May Rev: 1 MSL Patched OK: 00:00 If used non Auto-Ignition cable, press Power-On button No Response from Target MSL Patched OK: 00:00 If used non Auto-Ignition cable, press Power-On button No Response from Target MSL Patched OK: 00:00 If used non Auto-Ignition cable, press Power-On button No Response from Target MSL Patched OK: 00:00 If used non Auto-Ignition cable, press Power-On button <<< STOP >>> MSL Patched OK: 00:00 If used non Auto-Ignition cable, press Power-On button IF_SBL: XGOLD230, Ok IF_EBL: CATFISH2230_PCM_1.9400_M1S1 1.9400, Mode: BB BAUD_R: 3000000 FL_ID : FF000000, Unknown 1024+32Mb S5292DDME1_BSY.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x40000000 - 0x4001FFFE, Erased: 00:00 Write Area: 0x40000000 - 0x4001FFFE, Written: 00:01 Flash File: CATFISH.fls Erase Area: 0x40020000 - 0x42EFFFFE, Erased: 00:21 Write Area: 0x40020000 - 0x42C61212, Written: 06:45 S5292DDME1_CDS.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x42F00000 - 0x42FFFFFE, Erased: 00:00 Write Area: 0x42F00000 - 0x42F6B64E, Written: 00:04 S5292ODDME1_CSC.dffs FLASH BUNDLE: Flash File: temp_GT-S5292_ODD.dffs Erase Area: 0x43000000 - 0x47E7FFFE, Erased: 00:20 Write Area: 0x43000000 - 0x45AE11EE, Written: 08:18 ShutDown Done All Done, Time: 17:26 Make [Reset MMI] or Use *2767*3855# at First Start ! |
09-03-2014, 09:26 | #10 (permalink) |
Crazy Poster Join Date: Jul 2012 Location: india Age: 40
Member: 1780708 Status: Offline Sonork: 62645 Thanks Meter: 7 | s 5292 flash done with ufs Insert USB Cable to Phone Without Battery IF_USB: XGOLDxxx IF_SBL: XGOLD230, Ok IF_EBL: CATFISH2230_PCM_1.9400_M1S1 1.9400, Mode: BB FL_ID : F0110000, Micron PCM 2WA91 1024Mb S5292XXMB2_BSY.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x40000000 - 0x4001FFFE, Erased: 00:00 Write Area: 0x40000000 - 0x4001FFFE, Written: 00:00 Flash File: CATFISH.fls Erase Area: 0x40020000 - 0x42EFFFFE, Erased: 00:20 Write Area: 0x40020000 - 0x42A03212, Written: 00:18 S5292XXMB2_CDS.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x42F00000 - 0x42FFFFFE, Erased: 00:00 Write Area: 0x42F00000 - 0x42F6B64E, Written: 00:00 S5292OXEMB3_CSC.dffs FLASH BUNDLE: Flash File: temp_GT-S5292_OXE.dffs Erase Area: 0x43000000 - 0x47E7FFFE, Erased: 00:23 Write Area: 0x43000000 - 0x45CFB2EA, Written: 02:14 ShutDown Done All Done, Time: 03:36 Make [Reset MMI] or Use *2767*3855# at First Start ! |
10-19-2014, 13:59 | #13 (permalink) |
Junior Member Join Date: Mar 2014 Location: phaltan maharashtra
Member: 2152338 Status: Offline Sonork: 1653962 Thanks Meter: 5 | samsung 5292 flash done z3x boot key vol down Selected model: S5292 Selected port: COM10 Z3X BOX Serial Port Selected port speed: 921600 Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 11F000FF Erasing flash... OK Sending BIN/BSY (CATFISH.fls)... OK Erasing flash... OK Sending BIN/BSY (CATFISH.fls)... OK Erasing flash... OK Sending CDS (CATFISH.fls)... OK Erasing flash... OK Sending CSC (temp_GT-S5292_ODD.dffs)... OK Flashing done (time - 00:05:26) Done with Samsung Tool v.18.2 |
10-25-2014, 11:20 | #14 (permalink) |
Junior Member Join Date: Feb 2013 Location: varansi
Member: 1883835 Status: Offline Sonork: [email protected] Thanks Meter: 0 | plz help us samsung s5292 flash file link |
12-16-2014, 14:51 | #15 (permalink) |
Freak Poster Join Date: Jul 2013 Location: KARNATAKA INDIA
Member: 1982397 Status: Offline Thanks Meter: 17 | samsung s5292 flashing success by hwk Insert USB Cable to Phone Without Battery IF_USB: XGOLDxxx IF_SBL: XGOLD230, Ok IF_EBL: CATFISH2230_PCM_1.9400_M1S1 1.9400, Mode: BB FL_ID : F0110000, Micron PCM 2WA91 1024Mb S5292XXMB3_BSY.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x40000000 - 0x4001FFFE, Erased: 00:00 Write Area: 0x40000000 - 0x4001FFFE, Written: 00:00 Flash File: CATFISH.fls Erase Area: 0x40020000 - 0x42EFFFFE, Erased: 00:22 Write Area: 0x40020000 - 0x42A033AA, Written: 00:21 S5292XXMB3_CDS.fls FLASH BUNDLE: Flash File: CATFISH.fls Erase Area: 0x42F00000 - 0x42FFFFFE, Erased: 00:00 Write Area: 0x42F00000 - 0x42F6B64E, Written: 00:00 S5292OXEMB4_CSC.dffs FLASH BUNDLE: Flash File: temp_GT-S5292_OXE.dffs Erase Area: 0x43000000 - 0x47E7FFFE, Erased: 00:30 Write Area: 0x43000000 - 0x45CE27CA, Written: 02:21 ShutDown Done All Done, Time: 03:45 Make [Reset MMI] or Use *2767*3855# at Firs |
