08-04-2013, 08:37 | #17 (permalink) | |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | Quote:
08-08-2013, 09:44 | #18 (permalink) |
No Life Poster Join Date: Feb 2008 Location: +919304287474 Age: 41
Member: 714710 Status: Offline Sonork: offline Thanks Meter: 1,017 | Samsung S3770k Blinking Problemes Solved Write S5610k E2p File With Hwk After flash Again 100% tested solution |
The Following 6 Users Say Thank You to DHEERAJ_SHARMA For This Useful Post: |
08-09-2013, 16:58 | #19 (permalink) | |
Product Supporter Join Date: Jun 2008 Location: TURBHE JANTA MARKETNAVI MUMBAI Age: 45
Member: 787829 Status: Offline Sonork: 100.1615114 Thanks Meter: 917 | Quote:
bro if still your problem not solved then try this new E2P S5610K_E2P.rar_links readed from working phone try and post result here .! | |
08-10-2013, 07:14 | #21 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: INDIA BHUBANESWAR
Member: 641849 Status: Offline Sonork: 100.1619689 Thanks Meter: 44 | Quote:
The Following User Says Thank You to RICKY great For This Useful Post: |
08-10-2013, 07:39 | #22 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | Br, i can't find model S5610 at swift platform. i use ver. 2.2 this time not possible update 2.3, cause internet is temporary close. so, what can i next ? please reply. thanks mahir |
08-10-2013, 14:39 | #24 (permalink) | |
Freak Poster Join Date: Nov 2008 Location: Tamilnadu,India
Member: 906348 Status: Offline Sonork: 100.1624118 Thanks Meter: 30 | Quote:
08-15-2013, 16:15 | #29 (permalink) |
No Life Poster Join Date: Jul 2007 Location: earth
Member: 540512 Status: Offline Thanks Meter: 340 | S5610K restart solution 100% work fine LOG Started: 81420133_5148 --------------------------------- Please Wait ... UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: ***** HID: 1E0BE********* HWK: A1.******* Licence: True LogFile: .\_!_LOG\*****_81420133_5148_LOG.txt Loaded Settings from: Sams.ini E2P File: S5610K_2D160DB6A2710E3A_E2P.bif PROD_ID: EF96C43D81751226 SCROM_V: PNX6729 V.01.10 CHIPSET: 3C11 FL_VERS: 7.5.3 FL_CHIP: Samsung K522H1HACF [NAND 2G] BOOT Ok, 460800 Baud Partition E2P Erase Done, 26 block(s), Time: 00:00 Partition E2P Write Done, 3514376 bytes(s), Time: 01:45 PROD_ID: EF96C43D81751226 SCROM_V: PNX6729 V.01.10 CHIPSET: 3C11 FL_VERS: 7.5.3 FL_CHIP: Samsung K522H1HACF [NAND 2G] NAND Read Done, 131072 byte(s), Time: 00:04 BOOT Ok, 460800 Baud Partition IMAGE Erase Done, 6 block(s), Time: 00:00 Partition LCDACT Erase Done, 1 block(s), Time: 00:00 Partition MAIN Erase Done, 144 block(s), Time: 00:00 Partition PAGED Erase Done, 64 block(s), Time: 00:00 Partition a File not Exists, Skipped Partition b File not Exists, Skipped Partition c File not Exists, Skipped Partition d File not Exists, Skipped Partition sysv File not Exists, Skipped Partition sysv_bk File not Exists, Skipped Partition IMAGE Write Done, 786432 bytes(s), Time: 00:24 Partition LCDACT Write Done, 131072 bytes(s), Time: 00:04 Partition MAIN Write Done, 15099904 bytes(s), Time: 07:45 Partition PAGED Write Done, 4501484 bytes(s), Time: 02:19 Partition a File not Exists, Skipped Partition b File not Exists, Skipped Partition c File not Exists, Skipped Partition d File not Exists, Skipped Partition sysv File not Exists, Skipped Partition sysv_bk File not Exists, Skipped Partition BOOTNAND Write Done, 37120 bytes(s), Time: 00:01 Partition Table: S5610KOJPKJ1.ptt Regions : Arabic Language: ar,en,fr(fa,ur) Release : 2011 October Rev: 1 PROD_ID: EF96C43D81751226 SCROM_V: PNX6729 V.01.10 CHIPSET: 3C11 FL_VERS: 7.5.3 FL_CHIP: Samsung K522H1HACF [NAND 2G] NAND Read Done, 131072 byte(s), Time: 00:04 BOOT Ok, 460800 Baud Partition IMAGE File not Exists, Skipped Partition LCDACT File not Exists, Skipped Partition MAIN File not Exists, Skipped Partition PAGED File not Exists, Skipped Partition a Erase Done, 424 block(s), Time: 00:00 Partition b Erase Done, 264 block(s), Time: 00:00 Partition c Erase Done, 900 block(s), Time: 00:00 Partition d Erase Done, 160 block(s), Time: 00:00 Partition sysv File not Exists, Skipped Partition sysv_bk File not Exists, Skipped Partition IMAGE File not Exists, Skipped Partition LCDACT File not Exists, Skipped Partition MAIN File not Exists, Skipped Partition PAGED File not Exists, Skipped Partition a Write Done, 40717248 bytes(s), Time: 19:48 Partition b Write Done, 8971776 bytes(s), Time: 04:28 Partition c Write Done, 9073152 bytes(s), Time: 04:31 Partition d Write Done, 145728 bytes(s), Time: 00:04 Partition sysv File not Exists, Skipped Partition sysv_bk File not Exists, Skipped Partition BOOTNAND Write Done, 37120 bytes(s), Time: 00:01 |
The Following User Says Thank You to naizersky For This Useful Post: |
08-15-2013, 17:12 | #30 (permalink) |
Member: 787829 Status: Offline Sonork: 100.1615114 Thanks Meter: 917 | Samsung S3770k download working e2p from here :- S3770K__E2P.rar_links |
The Following 4 Users Say Thank You to .::jagdeep-Gupta::. For This Useful Post: |
