09-30-2013, 12:00 | #64 (permalink) |
Freak Poster Join Date: Jul 2013 Location: PKD
Member: 1987269 Status: Offline Thanks Meter: 190 | Try These...http://forum.gsmhosting.com/vbb/f311...ution-1721267/ ...:::boy:::... |
The Following User Says Thank You to Major Boy For This Useful Post: |
10-03-2013, 08:27 | #65 (permalink) | |
Crazy Poster Join Date: Sep 2009
Member: 1119195 Status: Offline Thanks Meter: 34 | try this bro try this bro..................... Quote:
10-04-2013, 07:38 | #66 (permalink) | |
Freak Poster Join Date: Jul 2013 Location: B.A.N.G.L.A.D.E.S.H Age: 28
Member: 1986151 Status: Offline Thanks Meter: 376 | Quote:
10-08-2013, 15:17 | #68 (permalink) |
Banned Join Date: Aug 2011 Location: India
Member: 1642979 Status: Offline Sonork: 100.1613407 Thanks Meter: 183 | use this setting plz 100% ok but imei will be 00000000000 http://forum.gsmhosting.com/vbb/f351...ready-1721612/ |
11-04-2013, 12:26 | #70 (permalink) |
Freak Poster Join Date: May 2012 Location: india \westbengal / katwa Age: 37
Member: 1762926 Status: Offline Sonork: 1619564 Thanks Meter: 83 | PROD_ID: EAD4C2750E712A02 SCROM_V: PNX6729 V.01.10 CHIPSET: 3C11 FL_VERS: 7.5.3 FL_CHIP: Samsung K522H1HACF [NAND 2G] NAND Read Done, 131072 byte(s), Time: 00:02 BOOT Ok, 921600 Baud Partition IMAGE Erase Done, 6 block(s), Time: 00:00 Partition LCDACT Erase Done, 1 block(s), Time: 00:00 Partition MAIN Erase Done, 144 block(s), Time: 00:00 Partition PAGED Erase Done, 64 block(s), Time: 00:00 Partition a Erase Done, 424 block(s), Time: 00:00 Partition b Erase Done, 264 block(s), Time: 00:00 Partition c Erase Done, 900 block(s), Time: 00:00 Partition d Erase Done, 160 block(s), Time: 00:00 Partition sysv File not Exists, Skipped Partition sysv_bk File not Exists, Skipped Partition IMAGE Write Done, 786432 bytes(s), Time: 00:15 Partition LCDACT Write Done, 131072 bytes(s), Time: 00:02 Partition MAIN Write Done, 15104000 bytes(s), Time: 04:49 Partition PAGED Write Done, 4501484 bytes(s), Time: 01:26 Partition a Write Done, 40713024 bytes(s), Time: 13:35 Partition b Write Done, 8971776 bytes(s), Time: 02:59 Partition c Write Done, 9073152 bytes(s), Time: 03:03 Partition d Write Done, 145728 bytes(s), Time: 00:03 Partition sysv File not Exists, Skipped Partition sysv_bk File not Exists, Skipped Partition BOOTNAND Write Done, 37120 bytes(s), Time: 00:00 samsung s5610k blink repair done |
03-22-2014, 12:40 | #72 (permalink) |
Junior Member Join Date: Feb 2013 Location: rajkot
Member: 1885408 Status: Offline Sonork: [email protected] Thanks Meter: 0 | nokia c2-01 all keypad notworking solution |
03-22-2014, 14:06 | #73 (permalink) |
Member: 1986151 Status: Offline Thanks Meter: 376 | okia C2-01 Keypad Malfunction Repairs: 1. Clean the keypad matrix including the keypad membrane. 2. Trace the connection line paths of a certain keys that doesn't work. 3. Check/replace the Keypads EMI filter IC or you can bypass it by applying a jumper wire on the open test point or spots as shown on the picture above. It will work too. only thank button |
10-28-2014, 17:44 | #74 (permalink) |
No Life Poster Join Date: Sep 2007 Location: chattisgarh,India
Member: 578941 Status: Offline Thanks Meter: 108 | written e2p in s5610k but after that imei has changed & rebuild imei failed when i tried to rebuild .... dose any one have any solution for this |
