10-07-2012, 14:22 | #1 (permalink) |
Freak Poster Join Date: Jul 2010 Location: Manama Bahrain
Member: 1344255 Status: Offline Sonork: 1659066 Thanks Meter: 131 | Samsung SGH-A847 lock on at&t done by HWKuFs Micro Samsung SGH-A847 lock on at&t done by HWKuFs Micro Status Tools Z3x no lock HWKuFs Micro Done !! USB Cable 1st Option Procedure 1. Power on phone. 2. Type *#197328640# -> common -> usb config -> Qualcomm mode 3. Connect USB cable, setup drivers. 4. Choise qualcomm diagnostic port in port settings. 5. Choise unlock method: Read codes or Unlock. 6. Press Unlock button. Logs Code: Count supported models - 319 Searching Samsung USB Modem... Detected (COM34) Model: SGH-A847 SW: A847UCJK2 IMEI: 358369046544505 Model: SGH-A847 Country Code: ATT Factory SW: UCJK2 Unique Number: 55030002008153 Memory Phone: K5R2G1GACE(A847)S Checking Phone On COM35... OK Reading Phone Info... OK Model: SGH-A847 Country Code: ATT Cal Date: 2010-12-13 Factory SW: UCJK2 Unique Number: 55030002008153 Memory Phone: K5R2G1GACE(A847)S Phone S/N: R21C64ZVV9 Build: SBAM6290A-KPVZL-2.6.014022_1S IMEI: 358369046544505 Done with Samsung Tool ver 12.7 Reading Phone Info... OK Model: SGH-A847 Country Code: ATT Cal Date: 2010-12-13 Factory SW: UCJK2 Unique Number: 55030002008153 Memory Phone: K5R2G1GACE(A847)S Phone S/N: R21C64ZVV9 Build: SBAM6290A-KPVZL-2.6.014022_1S IMEI: 358369046544505 SW Version: A847UCJK2 Searching SysInfo... OK Reading SysInfo... OK Please Wait, Calculating Codes... OK (time - 00:00:00) For check lock status: *#7465625# Done with Samsung Tool ver 12.7 2nd Option Procedure 1. Power on phone. 2. Type *#197328640# -> common -> usb config -> Qualcomm mode 3. Connect USB cable, setup drivers. 4. Choise qualcomm diagnostic port in port settings. 5. Choise unlock method: Read codes or Unlock. 6. Press Unlock button. Logs Code: PING: OK, COM28 - QCDI Software: A847UCJK2 Regions : Cingular - USA Language: en,es Release : 2010 November Rev: 2 Hardware: REV0.1 IMEI: 358369-04-654450-5 BTID: 0C71:5D:E38404 S/N : R21C64ZVV9 PRID: SGH-A847 CSID: ATT SWID: UCJK2 DATE: 2010-12-13 UNID: 55030002008153 FLID: K5R2G1GACE(A847)S AXID: 1108-000337 Sysinfo Saved as: A847UCJK2_358369046544505_R21C64ZVV9_55030002008153_B743D168_Sys.sec FLAG: 00000001 PROV: 001001001010310150310170310410311180310980999990999991999992999993999994999995999996999997999998999999 PROV: 001-001 MAST: 03907195 [UNFREEZE] NET : 19241835 [#SIMLOCK*NET*19241835#] |
09-19-2014, 20:57 | #3 (permalink) |
No Life Poster Join Date: Apr 2010 Location: lagos nigeria
Member: 1278793 Status: Offline Thanks Meter: 68 | Licence: True AppVers: SAMSUNG TOOLS (HWK) v 2.3.0.5 by SarasSoft Build 37 LogFile: .\_!_LOG\87256_2014_09_17_14_16_22_LOG.txt Loaded Settings from: Sams.ini Ports: COM33: Qualcomm HS-USB Diagnostics 9002 (COM33) COM34: Qualcomm HS-USB NMEA 9002 (COM34) Modem: COM35: Qualcomm HS-USB Modem 9002 PING: OK, COM35 - MODEM Product : SGH-A847D Software: A847TLJK4 Regions : Telus - Canada Language: en,fr Release : 2010 November Rev: 4 IMEI: 355831-04-216376-5 PING: OK, COM33 - QCDI Software: A847TLJK4 Regions : Telus - Canada Language: en,fr Release : 2010 November Rev: 4 Hardware: REV0.1 IMEI: 355831-04-216376-5 BTID: 18E2:C2:ACE9E9 MSLA: R21C53GQHH MOB_INFO Failed Sysinfo Saved as: A847TLJK4_355831042163765_R21C53GQHH__0DC3A7D7_Sys .sec FLAG: 00000009 PROV: 30222021407021407121407221407321407421407521407621 40772140782140790010100010110010120010130010140010 15001016001017001018001019999990999991999992999993 999994999995999996999997999998999999 PROV: 302-220 Canada MAST: 84739513 [UNFREEZE] NET : 19196194 [#SIMLOCK*NET*19196194#] SP : 19196194 [#SIMLOCK*SP*19196194#] |
