Samsung SM-B312E Flashing And Unlocking Samsung SM-B312E Flashing And Unlocking Stil Give Me Error While Flashing And Patch MSL I Try Already With USb N UART Change Boud Rate Stil Same Error Need Unlock Simlock Software: B312EDDNG3/B312EODDNG4 Regions : India Language: en(bn,gu,hi,kn,mr,ms,pa,ta,te) Release : 2014 July Rev: 4 ProdCode: SM-B312EZWDINS IME1: 354791-xxxxxxxxxxxx IME2: 354792-xxxxxxxxxxxx S/N : RZ1F82J3CA BTID: F884F2-EB7BDA ULCK: 00000000 Level Of Lock: 00h Use Patch MSL, if Want to Read Codes or do IMEI Operations Or Untick [AT Info Mode] to Read Codes Insert USB Cable to Switched Off Phone IF_USB: XGOLDxxx IF_SBL: XGOLD213, Ok IF_EBL: XMM1180_14.10_MKEYSKEY 14.10, Mode: BB IFXFR_ERR_NO_RSP IFEBL_ERR_CONFEBL: Please Do NEED Full Thank You. |
w8 bro i upload file n solution for u |
sorry bro i check file i have solution of samsung B310E n u need B312E is diffrent |
sm-b312 e simlock problem Quote:
i have same problem anyone have the solution for b312e simlock |
pls help..... solution for b312e simlock how to flash ?:confused: |
Samsung SM-B312E Remove Sim lock Done Quote:
After Show Connect phone in flash mode Then 2 Press & Hold Ok Button(Center Button) 3 Connect USB Cable Her is The Log : Selected model: SM-B312E Selected port: COM15 Z3X BOX Serial Port Selected port speed: 921600 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 220800EC Reading security... OK Writing security... OK Rebooting phone... OK If phone not powered ON - turn ON phone Searching Samsung modem... detected COM69 Reading phone info... Model: SM-B312E Country code: AA55 Factory SW: B312EDDNF1 Unique number: 0514133052594F14 Memory phone: AA55 Software version: B312EDDNF1/B312EODDNF1 IMEI: 35007007007007 Bypass MSL... OK Unlocking... OK Done with Samsung Tool v.18.7 |
Its working But when I insert the sim card I get the message''incorect sim card''. Quote:
my b312e blinking how to flash. hwk flashing supported or not plz help me |
thanks 07;10848276][COLOR="YellowGrthankk you brother 10000000000000000000%working een"]1 Click to Unlock Button[/CnkOR] After Show Connect phone in flash mode Then 2 Press & Hold Ok Button(Center Button) 3 Connect USB Cable Her is The Log : Selected model: SM-B312E Selected port: COM15 Z3X BOX Serial Port Selected port speed: 921600 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 220800EC Reading security... OK Writing security... OK Rebooting phone... OK If phone not powered ON - turn ON phone Searching Samsung modem... detected COM69 Reading phone info... Model: SM-B312E Country code: AA55 Factory SW: B312EDDNF1 Unique number: 0514133052594F14 Memory phone: AA55 Software version: B312EDDNF1/B312EODDNF1 IMEI: 35007007007007 Bypass MSL... OK Unlocking... OK Done with Samsung Tool v.18.7[/QUOTE] |
Samsung SM-B312E Flashing And Unlocking volcano box Samsung SM-B312E Flashing And Unlocking volcano box |
flash mode = key 1+3 its okkkkkk |
Same problem for my sm-b312e,still simlock input password..anyone can give this solution?Thank you |
HOW TO FLASH SAMSUNG B312E FLASHTOOL https://drive.google.com/open?id=0B0...nUyR3o1S1AyNEU https://www.youtube.com/watch?v=D7vEFO47q1U |
Thank you very much it's working for me |
sim lock solution flash via z3x or flash tool then use zex box 1st boot phone read codes press menu key for boot wait for some time when asking modem port after make modem port its auto read master code. done... insert master code in phone goto setting /security/phone lock/off sim lock again input master code for disable sim lock.. BR RIZU007 |
