08-29-2009, 15:21 | #1 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Living with mobile phones
Member: 856803 Status: Offline Sonork: 100.1592550 Thanks Meter: 151 | samung C140 unlock possible on HWK? so need to unlock it If possible unlock on HWK,Need procedure how to unlock it |
08-29-2009, 17:44 | #5 (permalink) |
No Life Poster Join Date: May 2007 Location: InsidE AndroiD Age: 37
Member: 503161 Status: Offline Sonork: 100.1584069 Thanks Meter: 473 | it is simple unlock ur fone pressing unlock button if u hav cable for sgh c-140 |
The Following 2 Users Say Thank You to azeem781986 For This Useful Post: |
08-30-2009, 07:14 | #9 (permalink) |
No Life Poster Join Date: Feb 2006 Location: P A K I S T A N Age: 42
Member: 237155 Status: Offline Thanks Meter: 415 | you are wrong brother....it is 100% possible.....i tried many times for this model....use tp cable and 3.7 volt power at battery points...turn on phone...it will be connected in a second....take info and then press unlock....that,s all.....GOOD LUCK......... |
The Following 2 Users Say Thank You to quasim0438 For This Useful Post: |
08-30-2009, 19:37 | #12 (permalink) | |
No Life Poster Join Date: Jul 2008
Member: 811779 Status: Offline Thanks Meter: 242 | Quote:
cable for c140 and similer cell called TP cable it is 100% RJ45 cable for more please read user pdf manual which is in your sarasoftware carefully it will solve your problum about cable 100/100 gurantee br, | |
The Following User Says Thank You to metals For This Useful Post: |
08-31-2009, 08:18 | #13 (permalink) |
Member: 856803 Status: Offline Sonork: 100.1592550 Thanks Meter: 151 | Already i tried to unlock using unlock button It shows like this MSL : Active S/N : RW2P217192 MSL : Deactivated Clear SPLocks Done, Time: 00:02 Clear SimLock Done, Time: 00:01 Clear UserLock Done, Time: 00:01 Unlock Done, Time: 00:05 But Mobile not unlocked |
The Following User Says Thank You to ..::MOBILES::.. For This Useful Post: |
08-31-2009, 08:24 | #14 (permalink) | |
Major Poster Join Date: Sep 2006 Location: Leyte, Phillipines Age: 36
Member: 357476 Status: Offline Thanks Meter: 26 | Quote:
then enter to phone manually... post result... br | |
The Following User Says Thank You to cristafari007 For This Useful Post: |
08-31-2009, 08:45 | #15 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Quote:
try flash than unlcok samsung c140 dirct unlcok not pasible use spcial file to flash fone than unlock it 100% tested all boxes flash files get in support eare | |
Samsung F679 unlock possible on hwk | ..::MOBILES::.. | HWK | 0 | 08-19-2009 16:50 |
IS possible unlock 6120c on hwk? | drjaved_akhter | HWK | 2 | 11-18-2008 13:05 |
Is CE500 unlock possible on HWK | bowei | HWK | 0 | 08-02-2008 23:53 |
Is Nokia 1112 unlock possible with HWK? | Sharpharp | HWK | 3 | 11-06-2007 01:49 |
