08-31-2009, 11:35 | #16 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: I N D I A
Member: 336212 Status: Offline Sonork: 100.1585000 Thanks Meter: 4,912 | Quote:
i will post hear flasher and flash file use this opti flasher flash it this file i will post hear than unlock with hwk Opti Flasher C140 FlaSh File Wbr .::AZEEM::. | |
The Following 3 Users Say Thank You to .::AZEEM::. For This Useful Post: |
09-03-2009, 06:09 | #17 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Living with mobile phones
Member: 856803 Status: Offline Sonork: 100.1592550 Thanks Meter: 151 | Quote:
How to use this bro,kindly tell me step by step procedure | |
09-03-2009, 11:59 | #18 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 57
Member: 60668 Status: Offline Thanks Meter: 69 | AIRTEL provider modified the firmware of their service unit like NET10 and Tracfone, so it is necesary to flash the phone with original firmware, then do unlock. HWK can flash this phone using TP cable w/out battery connected. |
The Following User Says Thank You to KMHON For This Useful Post: |
09-13-2009, 15:57 | #19 (permalink) |
Member: 856803 Status: Offline Sonork: 100.1592550 Thanks Meter: 151 | Mobile was Unlocked successfully,Specially Thanks for AZEEM and KMHON After unlock this mobile have autoanswer problem when incoming call(used firmware=c140xxge1_s3.s3t) |
09-25-2009, 07:12 | #20 (permalink) |
Major Poster Join Date: Jan 2007
Member: 426145 Status: Offline Thanks Meter: 7 | Action: unlock Device: C140 Phone must be powered-On Connecting... device found: C140RAGC2 phone connected, working... software version: C140RAGC2 hardware revision: MP 0.800 hardware id: C140 imei: working... operaton finished Ok Finished, time used: 16 sec Remove/Install battery now ! Last edited by sanjeevkumarbr; 09-25-2009 at 07:15. Reason: not able to unlock Airtel gid-a sim |
09-25-2009, 07:55 | #22 (permalink) |
Member: 426145 Status: Offline Thanks Meter: 7 | Action: unlock Device: C140 Phone must be powered-On Connecting... device found: C140RAGC2 phone connected, working... software version: C140RAGC2 hardware revision: MP 0.800 hardware id: C140 imei: working... operaton finished Ok Finished, time used: 28 sec Remove/Install battery now ! same problem |
09-17-2010, 13:19 | #28 (permalink) |
No Life Poster Join Date: Oct 2005 Location: INDIA Age: 38
Member: 186840 Status: Offline Thanks Meter: 103 | bro read codes option is not available on c140 model with hwk what to do? info log is here Software: C140RAGE3 Regions : RA Release : 2007 May Rev: 3 Hardware: MP 0.801 IMEI: 353712-01-882412-1 MSL : Active S/N : R7WP511525 MSL : Deactivated Lock Level: 00h SProv Code: ffh ffh ffh ffh ffh ffh ffh ffh 00h e1h 18h ffh ffh ffh ffh ffh ffh ffh ffh ffh IMSI Mask : 00h 00h 00h 00h 00h 00h 00h 00h PCK : 00000000 NCK : 00000000 SCK : 00000000 SPCK: 00000000 MCK : 00000000 |
09-17-2010, 13:36 | #29 (permalink) | |
Member: 186840 Status: Offline Thanks Meter: 103 | Quote:
09-17-2010, 14:17 | #30 (permalink) |
Member: 186840 Status: Offline Thanks Meter: 103 | done successfully i only flashed with this file C140XXGE1.zip and phone unlocked now log is here Region: 1, 0x00000000-0x000006D3, Length: 1748 bytes Region: 2, 0x00004000-0x000068BF, Length: 10432 bytes Region: 3, 0x00020000-0x00020003, Length: 4 bytes Region: 4, 0x00021000-0x0065019B, Length: 6484380 bytes 1st Boot Ok, McuId: 000603EE, Rom: 00004B45, 5-1.0 (Trident 2) 2nd Boot Ok, McuId: 000603EE, Rom: 00004B45, 2-1.1 Fll Boot Ok, Vers: 5.11, fl_sceptre3_nice_std_v24.sre Flash1: Fl_Id: 00B00000_008D0000 - Sharp LRS18CK Baud Rate Set: 460800 bps MCU File: C140XXGE1_s3.s3 Flashing NOR part... Write Done, 6496604 byte(s), Time: 04:37 |
Samsung F679 unlock possible on hwk | ..::MOBILES::.. | HWK | 0 | 08-19-2009 16:50 |
IS possible unlock 6120c on hwk? | drjaved_akhter | HWK | 2 | 11-18-2008 13:05 |
Is CE500 unlock possible on HWK | bowei | HWK | 0 | 08-02-2008 23:53 |
Is Nokia 1112 unlock possible with HWK? | Sharpharp | HWK | 3 | 11-06-2007 01:49 |
